Question about Maytag MAH8700A Front Load Washer
Won't power up
Have a Maytag Neptune® MAH8700A with bases, it's just over one year old(we should not have bought it) on a spin cycle it walks all over the place and shakes very bad. Store replaced it once and the new one does same thing. In Augest 2005 Maytag sent a factory service person to check it out and he told us the machine was O.K. must be the floor of our new house was not solid enough. Today put a load in it to wash, pushed power button and nothing happened, I checked the breaker (not tripped) and cycled it. Other things pluged in to the same outlet works fine. Does this machine have a reset button some place, or did it shake it's self apart, any ideas? Thanks, Don
  • Don Rasmussen Nov 06, 2006
    Thank you Catriver for the information about the model re-design. I can't get the panel to work due to the lack of power to test for error codes, machine was unpluged over night and still no power at the controll panel.
    I'm going to call Maytag to check if they will update our unit before I open it up to check if CN5 and CN6 are loose. I'll post after I talk to Maytag.
    Have a great day,
    Don
  • Don Rasmussen Dec 14, 2006
    Thank you Catriver for your help with this problem, due to your input, I called Maytag and knew what to tell them, to make them send me what I needed to update our machine. Maytag's customer service people kept trying to tell me to call for service from local repair shop. Maytag rep's finely sent us the required parts, than sent out a service person to install the parts; we where very lucky as the repair person could find the real problem as to why the machine wouldn?t power up and make the repair when he was there. Of course all of this took well over a month and many trips to Laundromats.
    FYI, the machine would not power up due to broken or loose wire in the door switch circuit.
    Thanks to all and Happy Holidays,
    Don
    President:
  • 878 Answers
Don, going by the model number you posted I see they had some issues with the vibration and shaking. TDL-0117-B, the rear tub was redesigned changing the over all weight of the outer tub. This change required new software in the board. TDL-0092c-b, a new board was introduced. The new software was designed to distribute unbalanced loads more efficiently. The motion sensor communicates with the board regarding unbalanced loads versus the previous detection based on monitoring motor torque. You might be covered under these bullitens for labor, all your parts are warranteed for 2 years. You did not mention if you were getting any error codes. Try unplugging the unit for 1 minute and see if it comes to life. If not you will need to check harness's CN5 and CN6 on the board to see if they are loose. You can try to put it into a test mode by pressing Chimes and xtra rinse together for 3 seconds. Then press spin for input tests and spin speed for output tests. You do have some recourse with these service issues. Catriver..post back.
Posted on Nov 06, 2006
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune Front load washer walks in the spin cycle (MAH8700A*
I had this problem solved by changing this control board:
Whirlpool Part Number 34001494: CNTRL-ELEC I bought this from AMAZON for under $ 200, was able to change myself, good luck
May 26, 2014 | Maytag MAH8700A Front Load Washer
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
Maytag Neptune Loud Spin Cycle
im sorry,load spin cycle may be a bad spin bearing.remove lower back panel.look behind large black pully.if see rust ,water.metal fragments.thats it.cost a bunch to repair.ive done them 4 400 to 500$.God bless you ,tom
Dec 28, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Dec 06, 2008 | Maytag Neptune Washer
Maytag Neptune MAH400AWW
rear tub bearing is going out, must be replaced, causing too much drag. labor intensive repair.
Mar 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Won't Run
The humming usually means the motor is trying to start but can't either because of weak windings or not enough electrical power. Need to check the motor control.
Mar 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH6500
Sounds like some sort of broken support or spirng underneath. Flip it over and look. Expect a little water to run out though.
Feb 28, 2008 | Maytag Neptune MAH6500A Front Load Washer
Maytag MAH8700A Front Load Washer Logo
101 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
