Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
External harddrive (MyBook) not recognize
My external harddrive is suddenly not recognized by my computer. It is stating that it needs to be formatted. I don't want to format it as I have data on it I don't want to lose.
  • sedengiray Nov 27, 2008
    First the files started to gibe cyclic redundancy error. Now when I plug this in I get the message "This drive is not formatted. Do you want to format it now?" I don't want to format it because I have valuable data on it.
  • 22 Answers
Okay, here is what you can do to just verify that you haven't lost all the data on the hard drive (HDD failure, due to the manufacturer or a drop or heavy shake). Download a copy of Slax Linux www.slax.org 32 bit version will work, and burn the ISO they give you to a CD. I would recommend using Alcohol 120 www.alchoholsoft.com. Boot in Slax, and see if you can get the computer to recognize the HDD. If so, backup your important data onto other hard drives or thumb drives. Then when you have enough data backed up, you can format the hard drive.
Now, to get really fancy, lets say you have a somewhat corrupt formatted hard drive, and enough data free to encompass the data you have on the hard drive. Well, what you can do is download a program called "partition magic" and do a partial non-destructive re-partition. Respond if you need to get to that point so I can get you a link to the program.
Posted on Dec 12, 2008
My WD Book was spinning and clicking constantly, so i unplugged the USB and the power source from my laptop. After plugging back in, it is no longer recognized on My Computer -- I've rebooted 2x. My...
Let's hope the spinning and clicking was caused by a bad circuit board in the WD Book, and not the Harddrive inside it.
To explain;
Inside the plastic external enclosure (Case) of the WD MyBook is an ordinary harddrive as used in a laptop, or desktop computer.
There is a small circuit board inside the case, that the harddrive plugs into. (Or there are wires from the small circuit board, to the harddrive)
The other end of the circuit board, has a USB cable attached to it.
The circuit board is an Interface Board.
It is this small interface circuit board that USUALLY goes out.
Harddrives are pretty tough, but they are a mechanical device, and are rated in hours of usage. They can fail.
What I would suggest is to buy an economical external enclosure.
Has the circuit board, USB cable, and everything needed, just needs the Harddrive.
Installing is easy. There are instructions included.
Now we come to the technical portion.
What size harddrive is it, and what technology does it use?
Size:
1) There are two sizes of Harddrives. They are measured across the Width.
A 2.5 inch harddrive is a laptop size harddrive.
(2 and a half inches across in width)
A 3.5 inch harddrive is a desktop size harddrive.
Once you open the WD MyBook case, and measure, you will know.
Pretty easy.
Technology:
Looking at the harddrives label, will tell you if it is an IDE (PATA) model, or a SATA model.
If no nomenclature is readily apparent looking at the label, there will be a model number on the label.
Put the model number in your search bar.
Example:
WD2500BEVT
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136387
250GB SATA harddrive. Also is a laptop size harddrive.
(2.5)
If you cannot find the information, just post the Model Number in a Comment, and I'll find out.
Example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
Example of a 3.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
Example of a 2.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1086960&CatId=2781
Example of a 3.5 IDE (PATA) enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1337265&CatId=2779
The information on how to open a WD MyBook case, is not something the external harddrive manufacturer states.
For this we'll have to rely on videos that are made,
1) http://www.youtube.com/watch?v=6FlySnyJ0CQ
There are also other related videos to the right.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 09, 2011 | Computers & Internet
My WD External harddrive is not being recognized by my computer
Need more information about the problem. Your computer type and operating system and also if your hard drive came with any power source?
Sep 02, 2011 | Western Digital 250GB MyBook External USB...
My sata external usb western digital 320 gb drive only shows up as an unknown USB device. Is there any way to get my computer to recognize it. I have a laptop using windows xp. Ive tried unplugging...
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Jun 25, 2010 | Western Digital 320GB MyBook External USB...
Computer not recognizing MyBook when plugged in
Have a look at this article on external hard disk troubleshooting. Could be that you need to delete the USB root hub devices in the Device Manager to force Windows to recognize the device.
Jun 24, 2010 | Western Digital 320GB MyBook External USB...
Wdc 320 gig MyBook external hd is not recognized anymore. I have attempted to access the files on several different computers (laptops). The HD is powered on (light is on). I do hear a clicking sound when...
If you hear a clicking sound then that might be the sound of a defective harddrive. You could try removing the harddrive from the case and installing it directly into the computer to see if it is working. If it does then it could be the hard drive case power supply is defective. But the clicking sounds like a defective drive. If it is still under warranty then you could get it repaired by western digital...if it is still under warranty then do not open the case or you could void it.
Nov 20, 2009 | Western Digital 320GB MyBook External USB...
Windows XP will not recognize my WD 250GB Harddrive
Just plug your USB HDD directly into your MBoard's USB port...
Feb 09, 2009 | Western Digital 250GB MyBook External USB...
Computer suddenly not recognizing relatively new WD MyBook 640GB
Just a shot in the dark, but ..., shut down your computer and unplug the drive. Turn the hard drive off, then back on. Plug it back into the computer and restart. If it doesn't pop up, restart your computer this time with it plugged in.
Is there any noise coming from the drive? Is the green light on the front?
The same thing happened to me and the same drive, but 500gb. I did the above and it fired right back up again. You may have to delete the trial version from the drive if it on there, or from your computer if you had originally installed it.
Jan 07, 2009 | Western Digital 320GB MyBook External USB...
External HD not starting properly
my 500 gig mybook is clicking and not showing up at all, I am going to serioulsy lose my mind WTF!!!!
Sep 13, 2008 | Western Digital 320GB MyBook External USB...
External harddrive
yea this is a hard one you will need a recovery program something good that will go in deep and find all the shadow programs on your (HDD) Hard drive. if your computer does not recognize this HDD or memory stick this means u have reformatted a computer and the HDD or memory stick has been taken out half way through the format process. if you get a recovery program this means u will not get everything off it will only take the shadows of all your programs and files.
I hope this helps
From the best man
Jun 26, 2008 | Western Digital 320GB MyBook External USB...
HP Computers using XP will not show drive to which Western Digital 320GB external harddrive is connected
Your usb device could be finished or your USB ports may not be strong enough/ enough power to run the device.
Jan 13, 2008 | Western Digital 320GB MyBook External USB...
Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
356 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
