Question about Canon FAXPHONE B640 Plain Paper Bubblejet
Check printer error
Fax machine doesnt work...tried unplugging it, hitting stop button as manual suggests. Check printer keeps flashing on the screen.
    Problem Solver:
  • 16 Answers
Check to see that nothing is blocking your cartridge assembly from moving laterally. Unplug the A/C cord from your B640 and manually move the cartridge to the center of the rail. Close the front door which houses the cartridge assembly. Plug the A/C cord back into your unit. The unit should reinitialize and after doing so rest the cartridge to the far right end of the rail. This may not fix your problem, but it will confirm whether there is a cartridge transport problem. This is just the beginning in troubleshooting your problem.
Posted on Nov 15, 2008
Our Canon jx210p fax keeps saying "chk printer
CHK PRINTER 5100 / SEE MANUAL
Cause Action Movement of the Holder is blocked. Clear the paper jam or foreign object that is preventing the Holder from moving, then turn off the machine and turn it back on again. There may be an obstruction that is not allowing the Holder mechanism to move. Check for any obstruction (paper clip, small object, etc.) and also that the protective tape are removed from the FINE Cartridge. Check also for a paper jam and clear the jam if necessary . Then press [Stop/Reset] and start again. The FINE Cartridge may be defective. Press [Stop/Reset]. Reinstall the FINE Cartridge (see Prepare the Machine ) and start again.In either case, if the error does not clear, try unplugging the fax. Wait several minutes, then plug it back in. Also, try replacing the FINE Cartridge with a new one. An error requiring servicing might have occurred. Turn off the machine, and unplug the power cord of the machine from the power supply. After a while, plug the power cord of the machine back in and turn on the machine. If the same error occurs, contact the service center.
Jul 26, 2011 | Canon FAX JX210P All-In-One Inkjet Printer
F11 code flashing-washer stops
hi!!!!
try to unplug it end then check the control timer if it is broken !!!!
or open it if you know and fix it may be the spring that pull back the pause botton
might be broken go check it?
Sep 19, 2008 | Kenmore Elite 45986 Front Load Washer
Fax alarm is flashing and says check printer, fax in memory.I unplugged and rebooted.Any help is apreciated.
Please give me the error it shows on the screen when it says check printer!Check printer is a serious error!Thanks
Mar 26, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
Canon MP730 alarm light continues to flash: "Check printer press resume key" tried it doesnt work. Unplugged it disconnected everything and re-connected same problem. Ink cartridge doesnt return either.
Hi you can try this.
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you will need to clean out the waste ink it inside the printer all got to be open up to do this.
Ok I have put a MP-Tools in my website for you to try out this tools are for reseting your inks plus it can do much more.
Click on the link to download it.
Click Link = http://www.4all2sell.com/reset-tools/MPTool.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Sep 11, 2009 | Canon MultiPASS F80 All-In-One InkJet...
I have a error 133-290 and can not get it to clear
Make sure the line has a dial tone with a regular old 20th century analog phone plugged into the FAx line. Once that's verified, unplug FAX line from printer. Unplug Printer power. Wait 60 seconds. Insert FAX line again. Plug in printer. As it warms up, keep hitting CLEAR ALL and STOP buttons to skip the status page printing.
If that doesn't work, turn off printer and then hold CLEAR ALL and STOP buttons (at the same time) while turning on printer. Once the display gets into the calibration mode, keep tapping those two buttons. This should free you to get to the menu.
Do NOT pay the $360 XEROX wants to fix this common glitch on this poorly-designed printer. This is not a serious problem in 90% of the cases, but a glitch in the software that runs the printer.
Jul 09, 2009 | Laser 3115cn All-In-One Printer
Can't receive or send fax on my lexmark X4270
In this case first we need to chk whether there is any dial tone on ur fax machine for that u need to Hit the Options button till u find an option saying On Hook Dial now hit select and it should give u a dial tone if it doesnt check the Phone Line Connections........... If it gives u a dial tone........... Unplug the Power Supply from the Printer........ Press and hold the Stop/Clear button and while holding the Stop/Clear button insert the Power Supply back to the Printer........ It will say clearing and then display a page where u need to Selct ur Country and the other details........ and as soon as this is done u can send and recieve faxes....... Thanku
Jan 12, 2009 | Lexmark X4270 All-In-One InkJet Printer
CHECK CARTRIDGE
when trying to copy or receive a fax machine will flash printer error and send out blank page i replaced the ink cartridge and blue air tho it but nothing seems to help
Oct 03, 2008 | Sharp INKJET FAX UX-A1000
IntelliFAX 4750E - Printer Busy
The printers memory may be full depending on the type of documents they are printing. The first and most simple step is to unplug the power cord from the back of the unit for 30 seconds, put your finger on the stop key while plugging the unit back up and continue holding the stop key until the time and date are back on the display of the Brother unit.
If that does not work unplug the USB cable from the PC. Unplug the power cord from the unit again. Put your finger on the menu key first and then plug the unit back up. You want to hold the menu key unit the until the LCD says maintanence and all the lights are flashing. Let the menu key go and press the number 82 and will give you an error code. If the error code is 00 then there are no errors. If there is an error code record it and contact brother or check a service manual if you have one. Most laser products all have the same error codes with Brother.
To reset the unit press stop and then 91, this will reset the unit and all faxes or print jobs will be lost. This should clear the issue.
Jan 02, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
"Install Yellow" Error - Machine is frozen.
Check all other carts. It might be that one (or more) carts are empty, too. Thats why the machine refuses to work properly.
Unplug from power, wait  two minutes and replug again.
If it doesnt come up correctly the maincircuit baord might be defective due to a defective electrical part.
Do leave the machine always on power connection. You can turn it off by pressing the stand-by-fax button, but you have to keep the machine with power supplied. Set date and time. The machine runs some automatic cleaning cyles every 20 days to keep the nozzles alive and that prevents the permanent ph from drying out!
Dec 31, 2007 | Brother MFC 240C All-In-One InkJet Printer
Error message 714
hi RESET !! first clear all files from the memory cards (if there is) enter "001" and press "set" to delete all files enter "1" (page 143 ) http://service.us.panasonic.com/OPERMANPDF/DX2000AU.PDF take the battry out (page 196) unplug the device for a day and assemble it hope it works good luck
Apr 04, 2006 | Panasonic DX-2000 Plain Paper Laser Fax
Canon FAXPHONE B640 Plain Paper Bubblejet Logo
85 people viewed this question
old marine
old marine
