Question about GE Spacemaker JVM1640SJ Microwave Oven
Not heating properly
I think the magnetron is not working and wonder if it is worth fixing or just buying a new one?
I have a GE over the range space saver microwave that was only 18 mos. old when it stopped heating. GE replaced the magnetron for us at no charge but since we did not have a service contract - they charged us $200 to install it. It only cost $375 new installed. Your choice.
Posted on Jan 02, 2009
Stopped heating
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts, then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Jul 17, 2010 | Amana LD10 1000 Watts Microwave Oven
Does not heat up properly. Seems it lost it's
Assuming the turntable works maybe your magnetron isn't working properly. Cheaper to buy new microwave then to fix it.
Apr 30, 2010 | Kenmore Microwave Ovens
LMV1680WW will not cook/heat food; everything else seems to work fine. Where to look/fine problem and can this be fixed or do I junked?
the magnetron is bad, if you can install a new one by yourself its worth it if not buy a new one
Feb 04, 2010 | Microwave Ovens
GE Spacemaker Microwave XL1400- No heat
The problem could be anything from a defective control circuit board or a burned out magnetron tube. Either fix is quite expensive and you'll have to evaluate whether you think the repair is worth the cost vs buying a new microwave.
Bear in mind that a fixed microwave is still a used microwave. So to get an apples-to-apples comparison you have to ask yourself, would I pay $XXX (substitute XXX's with actual repair cost) for my used microwave?
Oct 10, 2009 | Microwave Ovens
I believe the magnetron just went out
Make a few phone calls and get the actual costs-then decide. You cant normally fix microwave ovens yourself though. Generally when the magnetron goes its time to buy a new micro unless its under warranty.
Oct 03, 2009 | GE JVM1410 Microwave Oven
Will not heat food
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food. The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing. There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however. Benjamin
Jun 15, 2009 | GE JVM1650 1000 Watts Microwave Oven
Sharp microwave losing cooking power
If the supply voltage is low it will take long time to heat foods. The second reason is the Magnetron. Since it is in the warranty period you can call at the sharp authorised service center. They will do it free of coast.
May 04, 2009 | Microwave Ovens
Give out a buzzing noise with a burning burning smell. Is it worth fixing or should we get a compatible replacement since this model is no longer available. Thanks
This is a common symptom of a failed magnetron, or defective wave guide assembly. The price of a new magnetron is about $120. The waveguide (if defective) cannot be purchased without buying a new unit. Your choice. Do you think its worth repairing? You can purchase a new magnetron, but if the waveguide is damaged, the unit will still exhibit the same symptoms you are experiencing. Its not often that I give advice NOT to fix something, but in your case, it may not be the best choice.
May 03, 2009 | GE JE1640 Microwave Oven
Will not heat
Magnetron probably the cause, not worth fixing in most cases. You are better off buying a new microwave because the cost of fixing isn't that much better than buying a new one usually.
Benjamin
Apr 25, 2009 | Microwave Ovens
Re: microwave does not heat
Is very unlikely that there could be any other electrical failure since everything else seems to be working.
If you are able to fix it yourself then is way more cheaper just to buy the magnetron.
Click here to find the magnetron.
Before you do any work on this device, please click here to know how to discharge the high voltage capacitor and other safety concerns when working with devices that generate high voltages.
I would say is not worth it to spend more then $100.00 for a 5+ years old microwave.
Good Luck.
Jul 16, 2008 | Whirlpool MH6150XM Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
74 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
