I just called the Dlynk tech. support and tried to get my wireless connected due to a new ISP. I could still not log on to the internet and she told me to go to this site to get further information. I need my wireless to get connected to the internet please.
    Brigadier General:
  • 6,966 Answers
Initially, a couple of ideas, checks, queries:
  • have you tried a reset;
  • what were tried with the D-Link support;
  • what is you OS;
  • how is your PC connected to the D-Link;
  • have you consulted you ISP.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 11, 2008
I cant get internet from my rouder
Wired or wireless? Shut down the computer. Unplug the NetGear. Unplug the ISP modem, remove battery, if applicable, Check ALL cables and connections, reseat ALL connections. plug in the ISP modem, wait for selftest. Plug in the NetGear, wait for selftest. Reboot the computer. Try connecting with a Ethernet cable if you are trying to connect wirelessly to verify. If that fails, contact your ISP to verify signal comming in. Have a ISP tech come out to analyze the signal.
Jan 06, 2013 | NetGear Computers & Internet
My HP G60 laptop with Vista won't connect to Netgear router
Usually there are 2 types of wireless connections, 2.4 GHz and 5 GHz. Your laptop may not be able to connect to one of these connections, so it may be incompatible with your router. You can try buying a USB networking card (no more than $20). It will plug into one of your USB ports and should allow you to connect to your router. Hope this helps!
Jun 22, 2017 | NetGear N600 Wireless Dual Band Router
Fitted a Linksys-g 2.4 ghz pci adapter to my kids pc, take make their PC wireless, installed the correct drivers after researching what these were on the internet and all ok. Changed ISP and no longer...
If your modem(the device given by your ISP) connected the linksys router on WAN port just power down all devices and power on modem and make sure all lights are on and then power on linksys router. This should fix most problems. If no luck connect your computer to modem directly and check if you are able to log on to internet! If your modem is not working then your ISP is the best option to call!
Sep 11, 2011 | Linksys 2.4 GHz 802.11b Wireless - B PCI...
I have attached my DI-524UP to a new modem but now I can not use the internet. the wireless is working as it conecets but the internet is not connected. The lights are flashing on the front of the unit...
Your D-Link DI-24UP needs to "log into" your ISP's network again - by switching it to a new
(DSL? cable?) modem, your router lost its "login" with the ISP.
Solution: power cycle the router. This will force it to log back into your ISP's network, at which
time you'll have to supply (probably manually), your account name and password that your account
has with your ISP.
Jul 20, 2011 | D-Link Computers & Internet
I have an Emachine t5226 and have several external drives, a modem (speedstream 5100), and a netgear router attached. I was moving the externals, modem and router to a different area. I shut down...
Hello, Unfortunately, ISP techs often try to put blame on their clients equipment as much as possible. If your computer is showing limited connectivity, then this means that it is able to successfully connect to your wireless router, meaning that its probably not your adapter. Limited connectivity usually is a sign that you cannot reach the internet. This could be caused by multiple issues. In order to isolate the problem, try connecting your computer directly into your modem using the cable from the wireless router. If you can connect to the internet, then it is a configuration problem with your router. If not, then it is something with your connection to your ISP, in which case you need to call your ISP back and explain that situation. If you do happen to connect to the internet, then please reply, and we can go from there.
Feb 17, 2011 | Computers & Internet
My Netgear adsl router is not getting connected to Internet in pppOe mode ..
POPE configuration is logs into your ADSL system and connects to your ISP provider server to link , so one of the reason why it dosent is due to either password and username not correct. Log unto IP address of your Router and go to WAN configuration , Check your username and password and reset to the initial password and username your ISP provider gave you , when you signed up with them. Then apply changes , off your router for 1 min and then power it , then wait for the ADSL light on the router to be stable , connect to the IP address of your router again and "Volla" , it should be fine , if not , contact your ISP provider....
Oct 07, 2010 | NetGear DG834G 802.11G Wireless ADSL...
Netgear dg834gt connected to isp but not no internet
Via Wi-fi or Ethernet? Eithewr way, you must run the network wizard for either the cable (Ethernet) connection or the wireless connection wizard. Check your local area connection status window (Right click the computer icon on the lower right hand corner of your screen -usually-). If you are connected but, can not log in and, you are absolutely sure your modem is connected properly to both ISP and your Computer, try calling a tech from your ISP. Be very nice and maybe they will guide you through the process. If , on the other hand, you want to be absolutely sure it is a router issue. Connect directly to your modem and see it you can surf.
Nov 24, 2009 | NetGear DG834G Router
Linksys wireless connected to router, signal fine, no web pages
First thing i would try is power cycling your equipment. Unplug the router and the Modem-
Plug the modem in first and once all the lights come on- plug in your router- then restart your computer.
Apr 09, 2009 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
David Payne
David Payne
