Bosch E25ErrorThe drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glass or debris near or where thewater drains-out.Remove and clean the sprayarms, they may have food debris jammed, rinse in hot running waterMaintainer Wash Run a wash with a tablespoon of powder, without any dishes on thehottest setting e.g. intensive, 65C, if you have a 70C this will be moreeffective.It can bequite common for a dishwasher to not drain because either the drain hose or theair gap (if the unit has one) is clogged up. Drain hose clogs commonly occurwhere the hose is attached to the main household drain line, or where the hoseconnects with the garbage disposer. Turn mainswater off and disconnect mains power Tryremoving the drain hose to unclog any debris. Don't forget to reattach the hosebefore you start your dishwasher again.The drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glass or debris near or where thewater drains-out.Remove and clean the sprayarms, they may have food debris jammed, rinse in hot running waterMaintainer Wash Run a wash with a tablespoon of powder, without any dishes on thehottest setting e.g. intensive, 65C, if you have a 70C this will be moreeffective.Turn the main water supply and main power offE15 error means the anti-flood system as activated; you havehad an overspill of water into the base plate below the sump.
If you take the kick plate off from below the door youshould be able to access the base to remove any excess water.Behind your kick board is a plate below the door. Remove theplate.
With the power off push a rag into the base plate to soak up the water.
Failing that pull out the dishwasher onto the floor and tilt the machine backto allow the water to run outSwitch the water and power back on and restart the programto test.If the appliance is less than 2 years old Neff/Bosch Groupguarantees it
Please see this fault guide, the above or first solution was sent in error
E15 error means the anti-flood system as activated; you have had an overspill of water into the base plate below the sump.
If you take the kick plate off from below the door you should be able to access the base to remove any excess water.
Behind your kick board is a plate below the door. Remove the plate.
Failing that pull out the dishwasher onto the floor and tilt the machine back to allow the water to run out
Switch the water and power back on and restart the program to test.
If the appliance is less than 2 years old Neff/Bosch Group guarantees it
