Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftman garage door opener, will not go all the way up.
This only happens when the temperature drops. During the summer months never had an issue. This happened last year during the same time period
  • 12 more comments
  • Anonymous Nov 18, 2008
    My doo opener is about 12 years old. Same problem; only happens when it gets too cold, like today in Michigan.
  • Anonymous Nov 20, 2008
    I have two 139.53824 SRT 1/2 hp openers that were installed at the same time. One works in cold weather and the other doesn't. This has been going on for many years now. Weird.
  • winkie nood Nov 30, 2008
    Craftsman 1/2 HP  garage door spring type will not open all the way in cold weather
  • binky 1 Dec 03, 2008
    When cold door opens a little then stops. I have to push the remote or wall unit numerous times to get it up. No problems going down.
  • bjaeger Dec 05, 2008
    This happened to us and it was a 'little cracked plastic piece" of the safety sensor kit. (cheap)
    Good luck trying to get a replacent part from Sears with your "guaranteed warranty" on parts. They will tell you they have to have a technician cone out which costs $ 69.95- more than the part itself!
    Sears is a rip-off and a store where I will never shop again! They do not care!
  • Anonymous Dec 06, 2008
    We have the same problem also. Only when the temp drops. My husbans discovered if you press the inside remote twice quickly it continues all the way up
  • ben624 Dec 06, 2008
    Same problem. When it's warm, it opens OK, when temp drops, it stops halfway and I have to hit the remote again - sometimes it stops again, and I have to hit the remote again.
  • Anonymous Dec 31, 2008
    In the cold weather my craftsman garage door opener will not open all the way up.
  • Anonymous Jan 08, 2009
    test
  • smokem Jan 08, 2009
    Have the same problem, started about 1 month or so when it got colder. Usually have to hit the button and wait a minute or so then it will work. Otherwise the unit just clicks. Tried adjusting the Force screws, no help. Also, sometimes the door will stop while moving. Disconnected the door, no help.
  • Anonymous Jan 15, 2009
    will not go all the way up. Stop a quater of the way then go back down
  • dmelz606 Jan 16, 2009
    I have a similar problem. With the cold weather upon us, the door will only open/close a few inches and then go back up. We have both a keypad and a button inside. I finally got it to close by holding down the 'doorbell' button until it closed and then let it go. I'm not going to use it until I figure this out. Any ideas anyone??????
  • simmons2 Jan 18, 2009
    me too. It goes up about 40% of the way.
    If I disengage it, the garage door easily lifts all the way.
    And it will automatically re-engage and closes fine.
  • dufree72 Jan 18, 2009
    i have the exact same problem. i have tried moving the rail away from the door because i thought there was an obstruction when i gets cold and it stil stops.
    Sniper:
  • 98 Answers
1.Check to see if the door is running correctly.
  A. Run the door down and pull the emergency release. See if the door will run easily by itself.
    1. If it runs hard by hand try lubricating the rollers and hinges with silicone spray or some form of               lubricant (not WD 40)
    2. If the door is heavy and falls back to the ground, you probably have a spring issue (either broken           or needs more tension) in this case call a professional door repair company in your area.
  B. If the door runs fine then check the up force on your operator (the box that hangs from the ceiling          and reads Craftsman). If the light(s) on your operator go from front and/or back, the force                      adjustment screw is on the back of the operator. If the lights are on the sides of the operator then          the force adjustment screw is on the right side (looking from the back of the operator and facing            the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
Posted on Jan 01, 2009
I had the same problem on a Sears GDO. I adjusted the Force Control Adjustment Screw on the side of the unit up a bit to increase the power when lifting the door. It works fine now.
Posted on Jan 19, 2009
  • Joe Carnemolla Jan 04, 2013
    After years of frustration, your solution just fixed my door. Thank you.
On the back of the door opener unit, where the motor is, there are some adjustment screws. One is for down force, another for up. you should be able to adjust these to overcome the problem, which is caused by cold grease offering too much mechanical resistance to the motor's sensor (which is normally meant to keep the door from crushing someone caught under it).
Posted on Oct 17, 2010
  • mommydba Oct 19, 2012
    I know that this post is dated, but THANK YOU THANK YOU THANK YOU!!!! It worked! I've been bugging my husband to address this for over 4 years now. Finally, I just googled my issue and this popped up.
During the summer , we leave the garage door open about 6" to vent the garage-since having a new spring installed , we cannot do this as the garage door literally falls all the way shut,
Posted on Jun 12, 2009
Possible interim solution. Or dumb luck. I just finished posting an I-have-same-problem statement on this site. Problem being: GD won't close when temp dips below approx. 40 degrees F. (Garage is not attached to the house.) This has been plaguing us for two years. My wife suggested using her hair drye on the drive unit; you know, the box where all the guts are located. Outdoor temp is 37 F. here in Eastpointe, MI. I directed the heat from her hair dryer all around the box -- back, front, sides, bottom -- for maybe three minutes. I was disapppointed when the door still would not close immediately afterward when I pushed the button on the remote. However, a few minutes later, after I got in the house, I pressed the button again and the door closed.
Posted on Nov 30, 2008
Is the freezer being outside causing motor problems
Hello Donna F - Typically freezers are not recommended to be located outside because if the garage temperature is above 100 degrees, it will have difficulties performing optimally due to un-circulating air. Some manufacturers have garage kit design to help with this issue. It is design to solely be used during the winter to provide heat to the coils which trigger the compressor to come on. During the summer months, generally it is not needed.
Oct 08, 2012 | Frigidaire 9 cu. ft. / 255 liter Chest...
My garage door is a craftman . The problem is the door opens fine but won't close unless u hold the button till its completely closed. I noticed this only happens when its cold out any suggestions !!!
If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit.
Dec 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftman Garage door opener model # 41a3493-1. Does it have auto reverse?
That isn't the model number you give it is the part number for the logic board. The model number is on the opposite end of the motor unit and starts with 139. If you are asking if the opener should reverse when it hits an obstacle the answer is yes. If it doesn't it is not adjusted correctly or is faulty.
Dec 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftman Garage Door Opener Quit Working.
It could be a bad logic board especially if you have had any electrical storms in the area. I would remove and check the logic board for burnt or missing traces on the printed circuit board.
Sep 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Temperature varies over time. Cleaned coils.
During hot summer months and frequent openings this will happen - it is normal for temperatures to vary when you add in warm food or open the your refrigerator often and for a long time, if it is not your case, then the next thing I could think of is that cold air is escaping, you have a leak somewhere - check your door gaskets using the dollar bill trick - slide in a dollar bill in different areas of the gasket, shut the door, pull on the bill, if there is no resistence and the bill slides out easily, you have a gasket leak.
Aug 17, 2009 | KitchenAid Refrigerators
When we open the freezer door, a lot of steam/smoke comes out. A lesser amount comes out when the fridge door is opened.
If the fridge is working and keeping things cold and frozen, you don't have a refridgerant leak that is producing vapor that might appear as steam or smoke.
The steam/smoke is actually water vapor being made visable due to the temperature difference between the freezer/fridge temperatures and the air temp in the room (or garage) the appliance is in.
It's nothing to worry about and is normally more likely to happen when the outside or house air temp is very warm (Summer months) and when the air is humid.
What's happening is the very cold and cool air is hitting and mixing with the much warmer and much more dense air (humid air contains microscopic water particles) when you open the doors, and is instantly being cooled. Thus it appears as thou the fridge is steaming or smoking.
Have a great day an hope this explains the situation. Best regards.
Jul 30, 2009 | GE Refrigerators
Craftman Garaged Door Unit Stopped Working
This sounds like you will have to replace the logic board. Whether you repair or replace get a surge protector 900 joules or higher unless you want it to happen again. You can get replacement parts at searspartsdirect.com. Thanks BB
Oct 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
10,941 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
