Question about RCA R52WH73 Projection Television
Menu button disabled
I have an RCA commercial monitor receiver which currently only gets 59 stations. when i push the menu button on the t.v. it displays MENU DISABLED.My universal remote has a menu button when pushed nothing happens. How can i enable my menu button on this t.v.
  • RCA Master
  • 5,138 Answers
Press and hold at same time with TV OFF Vol- and CH- wait till tv comes back on release buttons, you should now be in factory Menu for settings.
Posted on Jan 08, 2009
Auto adjust in progress
1. Push the menu button at the front side of your Dell monitor. The icon looks look like a miniature version of your monitor.
2. Push the menu button again. This will exit the monitor menu and launch the OSD (On-Screen Display) menu.
3. Use the down arrow button on your monitor to select "Factory Reset."
4. Push the menu button.
5. Use the down arrow button to select "All Settings." Press the menu button to save changes.
6. Push the menu button twice to exit from the menu. Your Dell monitor will go back to its factory settings default, and its auto-detect feature will be disabled.
Oct 10, 2014 | Dell E171FPb 17" TFT LCD Flat Panel...
Tip
How to get OSD on TV for a Pioneer Receiver
OSD for on your TV for a Pioneer Receiver setup menu. (It doesn’t matter what make your TV is).
Connect the MONITOR OUT video jack on the receiver to a video input on your TV. Use a standard RCA video cable to the composite video jack.
Turn your TV on and put your TV onto AV3. Turn your receiver on, then on your remote control push the receiver button (this is not the on/off button, there is another button with receiver written on it) then push the setup button on your remote control. You should get the OSD menu on your TV for the settings for your receiver.
on Jan 03, 2010 | Audio Players & Recorders
RCA HDTV Monitor; menu popping up and volume going down
The small signal board needs replacement. You can get replacement small signal boards from www.tvrepairworld.com
Jun 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
My rca tv reads function disabled when I push the menu button on the front of my tv. how can I enable it?
easy. some rca tv's have a disable function for the buttons on front of tv. keeps little children from changing channels and going into menu. you need a remote to access the menu. then go into parental child lock function in menu. hope you are not the child and your parents locked the front buttons. hehe
Nov 08, 2009 | RCA Televison & Video
1999 RCA mm36100 TV The buttons on the front panel are all messed up sometimes they work and sometimes not. The menu keeps popping up from time to time randomly and sometimes runs though the menu items all...
Bad push button board, best thing to do is just unplag the board and use remote to operate TV, board is mounted under front cover where button are.
Aug 09, 2009 | RCA MM36100 36" TV
DTA800 do not receive UHF
I am not from that part of the country, so I can't say for sure, but check the following:
1) Are the UHF channels local and small stations? If so and under a certain power level, they are not required to broadcast in digital. THere may not be digital UHF channels local to you.
2) The changeover is required by law to occur by Feb 2009. Not all stations have made the change yet. You could still be in an area where the stations have not yet converted to digital broadcasts.
Make a few calls to find out which category yuo fall under above. If you don't fall into either of the above, update this and we'll look elsewhere for the problem.
Dan
Jun 16, 2008 | RCA Audio Players & Recorders
Closed caption
Have you verified that the programs you're viewing have closed-captioning service? Some programs and stations do not support CC on programs and commercials. The closed captions are accessed on the HD52W56 by pressing Menu > Preferences > Closed Captions on the remote control and following the onscreen instructions. Select CC1(the first choice for caption); this is the format most stations send in. Good luck!
Jan 25, 2008 | RCA HD52W56 52" Rear Projection HDTV
LCD Monitor will not switch input selections
NOTE: You can also lock or unlock the OSD by pushing and holding the Menu button for 15 seconds. In this mode All buttons will be locked including the "Menu" button. You can unlock by pushing and holding the Menu button for 15 seconds.
Reference:
http://support.dell.com/support/edocs/monitors/2005FPW/En/setup.htm#Using%20the%20OSD
Oct 16, 2007 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Fax number
Press fuction 7 1 key in date & time press set
May 22, 2007 | Panasonic Panafax UF-560 Plain Paper Laser...
RCA R52WH73 Projection Television Logo
402 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
