Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis Washing machine makes noise during Spin cycle
My Kenmore Oasis Washing machine is very loud during the spin cycle. Could this be the bearings going out? What could be wrong?
  • 2 more comments
  • debloomfield Nov 13, 2008
    Found an appliance repair company that was willing to diagnose the problem at no charge. They told me that the tub bearings are going out and that just the bearings cannot be replaced. The tub and shaft assembly comes as one unit and must all be replaced. If you think this sounds expensive then you are correct. I'm no repair guy but I am willing to give it a go instead of paying the $470 quoted by the repair company. Can anyone tell me how to go about changing the tub & shaft assembly?
  • Anonymous Mar 12, 2014
    Kenmore washing machine will not wash or spin??
  • Anonymous Mar 23, 2014
    running oasis HE through cleaning cycle
  • Anonymous Mar 28, 2014
    The motor bolt unscrewed part way for repair but not all the way. just spins.
    Sergeant:
    Champion:
  • 324 Answers
With the machine empty see if you can lift up only the tub and see if it drops down.check to make sure there is nothing between the tub and outer tub have you gotten an f-51 error?
Posted on Nov 11, 2008
  • are you brave? and have a buddy that can help you?i have done a couple of these.first off i would also inspect the inner tub this would be a great time to replace. make sure you have plenty of room to change it.if you can take pictures as you go along.
    the way i did it was first take of the top and take out what you can see the top flips up with 2 clips in the front just pry gently
    then carefully tip the machine back and pull everything you can out from the bottom.take out the motor and leave the wires with the tub when you finally get the tub out put it side by side with the new one and take off what you can here. when you take off the cardboard pieces and mark them so you can put them back on right.(this is kind of a difficult job with no washer experience may take you 4 hours,just a warning)Its not hard if you got patience. like i said if you can take many pictures as you go along it will be good so you can have reference.any questins just ask.
  • Djuana Long
    Djuana Long Jan 25, 2014
    Could it be the bearings?
Cabrio washer wtw5500xw0 loud spin and grease on floor
FIXED Cabrio has loud noise during spin - ApplianceBlog
www.applianceblog.com/.../16339-Cabrio-has-loud-noise-during-spin
Aug 21, 2009 - 10 posts - ‎5 authors
Help Jake I have a Whirlpool Cabrio model WTW6600SW2 it is almost 2 ... a week just started making a very loud noise only during spin sounds like ... size washer (110.297) (loud whirring and grease splatter) and am trying to ...
How to tell if your bearings are bad on a Whirlpool Cabrio ...
? 1:01
https://www.youtube.com/watch?v=5rHn13lKjzc
Jan 19, 2012 - Uploaded by RenewAppliance
http://washerdryerrepairhelp.com/whirlpool-cabrio-maytag-bravo-and-kenmore-oasis- ... My floor under the washer machine hasgrease/oil marks. ... and make the suspension bad when it spinsmine has been like this for about 2 months now ... Noisy WhirlpoolCabrio washer during spin - Duration: 0:54.
Jan 16, 2016 | Washing Machines
There is grease coming from uner the washing machine and it makes a loud noise when it is spinning? Sometimes the washing machine will get hung up on the spin cycle?
Oil usually from the leaking transmission. a clutch not engaging might make a noise but u will get no real spin and clothes remain wet? if it was bad motor coupler if u have direct drive u would also have no spin or wash cycle. I suspect a bearing prob withing the tranny SORRYYYYYYYY :(
Oct 17, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Loud noise during the spin cycle
Did you have an oil leak at the bottom of the washer? If yes, chances are your transmission oil leaked and your transmission needs changing or repairing.
Jan 15, 2014 | Kenmore Washing Machines
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
Noisy when in spin cycle
This could be the drum baring and probably will need professional engineer to do it.
Jun 01, 2017 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore Elite Oasis HE washer model #27092600. It is making a loud noise before and during most of the spin cycle when it is trying to drain. What would cause this. I have had this machine since...
Mine was making a high pitch sound, thought a rock got under drum.... now it stopped yesterday full of water ... and won't spin or drain. What can I do here at home to fix it?
Apr 04, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Excessive noise during the spin cycle. we have owned the washer for 16 months. problem started 1 wk. the machine is level.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 03, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Noise during spin after changing clutch / kenmore elite washer
The clutch is likely failed again - or the coupling this time.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
1,410 people viewed this question
Sal De
fordexpert
Robert Rankin
