Question about Soleus LX-120 Air Conditioner
1st Problem: Doesn't evaporate the water. 2nd: Power will not stay on.
I used to use it all the time. First problem I had that it started leaking water (big puddles). I checked the manuel to see if I was supposed to be draining it regularly and it said there was no need. After I got tired of it leaving puddles I hooked up a hose to the drain plug. That worked, just had to dump the five gallon bucket every coule days. Now the new problem it wont stay on. After running for about 10 mins it just shuts off. And you have to push the reset button on the plug. And the same thing happends. I called Soleair customer service. And they me a number to somebody's who works there's voicemail. And they wont call back.
  • 1 more comment
  • Adamyhy Nov 06, 2007
    The problem ids that it won't stay on. After running for about 10 or 15 mins it just shuts off. And i have to unplug it , plug it and power it. And the same thing happends. It indicates also ''water full'' but when i check the internal reservoir ( water collector ), it's empty !!! Even when i connect the external reservoir, the same problem occur. The only solution , is to open the drain plug ( the water is flowing from there ) and connect it to a reservoit thru a pipe. hat way it don't stop working. So, please can any technician give me the solution to this problem. Thanks.
  • Anonymous Jun 01, 2008
    big puddles everywhere
  • muddy dog Jun 01, 2008
    Water is everywhere. It is leaking puddles. Drained the hoses, turned off, still leaking water.
    Problem Solver:
  • 7 Answers
First thing to know is that most window or portable A/C units use the water from the evaporator to cool the condenser. If the condensor is not cooled down it will cause high head pressure on the Compressor causing it to overheat and shutdown. First thing is to make sure nothing is plugged which will keep the water from reaching the condensing fan, which slangs water on the condenser. If this is a portable unit it may only have a condenser and uses the water to cool it.
Posted on Nov 10, 2006
Do it the way he told you to!!!!!!
Posted on Jul 11, 2007
4 Suggested Answers
kstfas
  • 75 Answers
SOURCE: Heater will not work, trips the reset button constantly. No help from manufacturer.
First of all I would make sure that you have it set up as instructed by the manufacturer guide or owners manual. If the plug is getting warm, replace the receptacle or try it in another outlet. Do not use an extension cord unless it is rated at the current that the unit is suppose to draw. If problem persist,contact Soleus International at contact@soleusair.com (888) 876-5387. They promise a 1 year warranty. http://www.soleusair.com/Consumer/index.htm If you are not satisfied with the unit and their warranty, contact the place you bought it from and try them. Report them to the BBB if still unsatisfied. Good luck. kstfas
Posted on Oct 23, 2006
SOURCE: Soleus LX-140 leaking problem
We have a 1-year PE3-09R-03 that just started dripping water on the floor. The red "tank full" light never came on. I opened it up to investigate, and I believe the problems are caused by dust. The plastic float that trips the "tank full" switch appears to have gotten stuck due to the combination of water and dust in the tray. Once I loosened it up and cleaned the guide tube it rides in, it would trip the switch when the tank was full. The reason the tank was filling up was a little less obvious. There is a 2-piece plastic tray that sits underneath the evaporator and above the condenser. The tray is supposed to distribute the water that's dripping from the cold evaporator coils onto the warm condenser coils so it can evaporate and be blown out with the warm exhaust air (note that "evaporator" and "condenser" are referring to the refrigerant - the terms appear backwards when referring to what's happening to the water on the outside). The tray and its lid have a series of tiny holes that were - guess what - plugged by dust. The tray is relatively easy to remove, just two screws and a spring clamp on the overflow hose. The tray lid is heat-staked onto the tray, you should be able to clean it without separating the lid. I cleaned and reinstalled the tray and verified that water would flow properly. I then reassembled the unit and fired it up, and it's been running without a puddle for over a day in humid weather.
The unit has a filter for the recirculating room air, but there is no filter for the outside air loop. Adding a filter would obviously help keep the dust out, but it could also reduce the cooling efficiency of the unit.
DO NOT use one of these on a floor you care about without some sort of emergency catch tray underneath!
Posted on Aug 17, 2009
  • 661 Answers
SOURCE: Soleus LX-140 Portable Air Conditioner The drain
Hi Jcamer6,
If the new pipe that you have got leaks , then all you need to do is add up O ring or rings to near the mouth of the hose pipe and you would find that the leak has stopped.
Many a times just because of an absence of an O ring we have such hose pipes leaking.
Hope this helps ..:)
Posted on Jun 27, 2011
Ran hot & out of water. No water in the oil. Only turns motor 1/4 as should. Has fire,won't start.
Hi Michael, The links below are two short youtube videos that shows how to fix a car that doesn't start,
The 1st link is a car that won't crank over and the 2nd link is a car that cranks over but won't start...CHEERS..
Fixing Car That Does Nothing When You Turn The Key
https://www.youtube.com/watch?v=064Ilsz8Fzg Fixing Car That Cranks But Doesn Start Up
Apr 14, 2016 | Cars & Trucks
Internet connection failed
Well the first thing to do is try to isolate the problem. Before we start make sure the 1st PC will give the same network cable unplugged error if it too is unplugged. Once that is done start by unplugging the network cables from the PCs and switch them. Does the problem stay with the 2nd PC or does it move to the 1st? If it stays with the 2nd PC then the problem is with the PC network card or more likely its configuration. The network card should be configured exactly as the 1st one, probably to obtain the IP and DNS addresses automatically. If you need help with this let us know the operating system you are using. If the problem moves to the 1st PC that indicates the problem is with the cable and/or the router. Now switch the cables at the router end, if the problem stays on the 1st PC then that network cable is your problem. It could be a ?cross-over cable or simply damaged. If it doesn?t move then the problem would be in your router. Either that router port is bad (try using another port) or the one port that works is configured uniquely. You?ll need to take a look at how your router ports are configured and look for the differences. Let us know what you find and we?ll go from there.
Jul 30, 2007 | Linksys Instant Broadband EtherFast...
Water is leaking from time to time in the front of the refriderator. It's not the water feed.
Your problem is likely that your freezer has a blocked drain which doesn't allow the water to drain to the bottom of the evaporator pan under the fridge. The lower backing INSIDE the freezer needs to be removed and the plughole cleared. Best to use a hairdryer and your fingers to remove he pool of ice buildup. Try not to use sharp objects as this can dislodge or break essential plastic pieces. Water should now drain from condensor coils during defrost mode out the drain and into the evaporator tray under the fridge. (melted water is simply evaporated away by the warm air which comes from your compressor and out of the front bottom of your fridge.)
I Hope this helps. Good luck
Apr 16, 2011 | Admiral 26 cu. ft. Side-By-Side...
Sub zero 561, evaporator is icing. 1st tech came in and after checking gas pressure told us that evaporator is leaking. we called in secong tech, he filled up gas and it started cooling fine but couple...
It may be leaking but I think more likely is that you have a problem with the defrost system and it is not defrosting properly... that can give the same symptoms as a low charge or leak condition...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 23, 2010 | Sub-Zero 561 / F
We had 2 new units installed 2 yrs ago and now it's sweating
1st of all the pan under your unit should not have water in it unless the primary drain from the evaporator coil is plugged.
2nd the secondrary drain pan underneath the unit should go to some kind of drain, along with the drain
from the evaporator coil. They should not be hooked
together until they reach the proper drain.
Check to see if they are hooked up together, if one is
plugged the other one will be to. The drain line could
be to small as well, check to see if they ran the condensate drain in 3/4inch pvc pipe or hose minimum.
It could very well be that they did not insulate the plenum, if it is sweating on the outside, insulate it.
Jun 28, 2010 | Heating & Cooling
My fzr 1000 is leaking gearbox fluid by the looks of it ,i start it up and when i put it in 1st gear it cuts out before i even let the clutch out. but if i put it in 2nd gear it doesnt cut out,, is this...
that's a bad neutral safety switch...it's a shop repair...now, the reason it goes bad:
the 1st gear is for getting the bike moving, period...you "never" wind out in 1st gear...ever...high rpm and going from 1st to 2nd is very bad for a transmission...think about how much movement is happening to go from the bottom, past neutral, to 2nd gear...that's where most trans damage occurs...once you start moving, go to 2nd, then rev it out... remember...1st gear is for getting moving only...
Apr 18, 2010 | Yamaha FZR 1000 Motorcycles
Kenmore side by side with water occasionally leaks water at bottom front. About every 2nd day. Whzt could cause this?
Most cases, your freezer evaporator drain hole is frozen, every time it goes into defrost, water backs into the bottom of the freezer and leak on the floor. Try turn off the freezer for approx. 48hrs with door open, afterward turn it back on, most cases it will reset by it self, if no,t check door gasket, evaporator fan motor or debris in the drain hole. Good Luck.
Mar 03, 2010 | Refrigerators
I can not shift out of 1st and 2nd. I can shift from 1st to neutral, and 1st to 2nd, but I can not go from 2nd to 3rd. When I depress the clutch and pull up on the shift lever to go from 2nd to 3rd it is...
Sounds like a bent shift fork of broken dog gear. Try cleaning the inside of trans with part light oil and solvent. (not fuel) Rock bike a few times and shift gears, Do not start. Keep doing so untill shifting gets easier. If this does not work. Try starting it one time and shift easy. Do not force. Still no luck - Split cases and repair
Oct 13, 2009 | 2003 Yamaha YZF-R1
Nor-Lake walk-in cooler water leak
The evaporator drains into pan with a coil from the discharge line. The design is intented to sub-cool the liquid refrigertant as well as evaporate the condensation from the coil. Unfortunately the engineer started as career a shipping clerk and never received any further training.  There isn't enough heat or running time to evaporate the condensation from the coil.
The solution is fairly simple
A plastic tube  drains water out of the evaporator in the pan. You can extend the tube and add a defrost pan handled by your refrigeration wholesaler. Wire it so it is on whenever there is power to the unit.  This should get rid of the excess water. These pans are also used on some self contained coolers and freezers. They come in either 120 volts or 220 volts. kasgirls@tds.net
Jul 12, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Soleus LX-120 Air Conditioner Logo
867 people viewed this question
Top Soleus Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Dennis Boxerman
Craig Butler
Craig Butler
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
