Question about Frigidaire FGF316 Gas Kitchen Range
Oven does not heat
The range is only 2-1/2 years old and the oven quit working about 6 months ago. The top burners still light and work correctly but when the oven knob is turned on, the oven does not heat at all. It seems to be getting gas, but will not light or heat.
  • 4 more comments
  • dea-nile Nov 13, 2007
    My oven is doing the same thing. All the top burners work fine but no matter what temp. you set the oven to - it only gets warm.
    Hi - one more question - If the problem is the ignitor, is there a temporary solution (such as manually lighting)? Son's b-day is tomorrow can I light it just to bake cake?
  • infiniti Jan 22, 2008
    i just bought my whirlpool stove a year and 6 months ago and the oven does not work at all but the stove on top does it seems like maybe its a defect because i checked the fuses and the igniter and everything looks fine.
  • Anonymous Sep 02, 2008
    when i turn my oven on it does not heat up
  • Anonymous Dec 22, 2008
    I to have a Frigidaire and it just did the same thing stove works great oven just won't light HELP it's almost christmas. I have tryed lighting it with a lighter along gas line in oven seems like there's no gas.
  • maggiemaggie Dec 26, 2008
    The stove top works fine. The oven only gets so hot no matter what temperature you set it to.
Dont know if this will help but i just discovered there is a switch for oven. you need to lift up the hood by the burners and in the far far back right corner a square metal box where the gas line goes into u will find a up down switch (black so u cant see it too well of course ) this switch needs to be in the up position, it feeds the gas to the oven. check this out if u have a glow lite it will take a little bit before the oven lites between 3 min and 5 minutes. hope this helps you
Posted on Nov 08, 2008
I am having the same problem right before the holiday...can this be by myself or do I need a technician??
Posted on Dec 16, 2007
    President:
  • 878 Answers
Gowen, more than likley it's your ignitor that failed. Remove the ovens bottom panel by removing the 2 screws in back and lifting up. Remove the nut from the flame spreader and you will see the ignitor. Now turn the oven on and look at the ignitor, does it glow. Even if it does, it needs to draw at least 3.2 amps to open the gas valve. Part number for the ignitor is 5303935066. Easy job. Catriver...post back.
Posted on Nov 06, 2006
We have an 8 year old Frigidaire electric range. When going to use the oven a few nights ago, we discovered that neither the top or bottom oven burner was heating at all - tired both Bake and Broil. The...
You will have to check that the switch is is working ok , with a vault meter check for voltage at the burner , if none check at the switch and so forth back to the wall switch, if there is vaults at the burner it is faulty .
May 27, 2017 | Frigidaire FEF339E Electric Range
Our 6 year old Kenmore Electric Range's oven just quit working. The stove top burners work fine, the light in the oven comes on and the breakers in the main house panel are all fine. It just quit heating...
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Aug 07, 2010 | Kenmore Kitchen Ranges
Oven too hot and uneven heat
We had the same trouble with our electric range a few years ago. We had the thermostat replaced and it has worked great ever since. Douglas
Jul 10, 2010 | Premier Kitchen Ranges
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Oven not cooking at correct temperature & loses heat
Had a similar issue - but my unit is eight years old. Turns out my issues were my oven ignitors were failing and one of the burners had corroded causing the flame to only light on one side. To fix I replaced two ignitors (apparently they are to be replaced every 3-5 years) and cleaned the burner with a brass wire brush. If you are handy the ignitors are easy to replace - one screw and two wires each. Burner was one screw to remove.
Ceramic ignitors if wearing out can cause delayed lighting of the oven burners and/or reduce the gas flow - hence not heating up.
That was my experience ....
Jan 11, 2010 | Viking VGSC366-6B Gas Kitchen Range
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
Top burners often wont light if oven is already lit
I have fix that problem before, the oven heat is soficating the top burners, you will have to adjust top burners with the oven on, so that they will light by them selfs.Or put a shield under the cook top section on the back, so that the heat will not come to the burners where they get the oxigen.
Dec 07, 2008 | GE JGBP28 Gas Kitchen Range
Oven does not heat up
there is a fuse that controls the oven functions.. try replacing it.. good luck!
Dec 02, 2008 | Frigidaire FGF337EC Stainless Steel Gas...
No heat in oven or on range
when you turn on the top burners do you hear the ignighters clicking please hold my rating for now as i need to ask a few questions
Jan 11, 2008 | Frigidaire FES367 Electric Kitchen Range
Frigidaire FGF316 Gas Kitchen Range Logo
558 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
