I cannot record a show onto a blank vhs tape in my vcr??
    Brigadier General:
  • 6,966 Answers
Initially, pls verify that the coaxial cable is connected to the ANT/Cable/RF IN of the VCR. Thereafter the built-in tuner of the VCR would be used to select the desired channel to be recorded. The VCR in turn maybe connected two (2) ways to the TV:
  • Audio/Video using yellow, red & white RCA cables/connectors using AV1 or Video1;
  • RF patch cord from RF OUT of VCR to ANT/Cable/RF IN of TV using either Channels 3 or 4.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 11, 2008
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
http://resources.jvc.com/Resources/00/01/15/LVT2016-001B.pdf
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
How to convert VCR to DVD
no easy way to do this unfortunately. You either need to connect your VCR to a DVD recorder and record it directly onto DVD or use a device such as this http://www.dx.com/p/easycap-usb-video-capture-adapter-5707 to connect your VCR to your computer and record it onto your computer that way.
Feb 23, 2015 | Zenith XBR616
Can the Magnavox Dvd player/VCP DV200MW8 record shows onto VHS's
unfortunately the machine is not a recording machine IE: it is a player only. However in todays day and age you can pick up a good used one at the goodwill for around 10-20 bucks that can record. hook up is easy, one cable in one out and presto you can record on a blank tape. just remember the begining of a blank tape always has a few seconds of nothing on it so dont hit rec just as you are watching it start the machine about ten seconds early.
hope this was helpfull.
Dec 27, 2008 | Philips Magnavox DVD/VCR Dual Player
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
May 24, 2008 | Zenith VCS442 VHS VCR
Recording
Coax out from box into cable in on VCR. Coax out from VCR to Cable in on TV. Set TV and VCR to ch 3. Put in blank tape. Start show on DVR and hit record on VCR. Hope that works for you.
Feb 07, 2008 | Arris DCT6200 DTV Receiver
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Need Help recording television onto vhs
Probably cabled wrong.
Make sure the VCR is getting a signal to record.
Put in a movie and get the TV set up to watch it.
Now put in your blank tape and switch the VCR to what you want to record and make sure you can see it on the TV.
Dec 17, 2007 | Televison & Video
How do you copy from one vcr to another
ok hear u go
recorder vcr all rc pin go in vidio in audio in .
play back vcr all pin goes out audio out vidio out ..
blank tape gos to recorder
hope that help u
Nov 30, 2007 | Sanyo VWM-950 VHS VCR
Tapes not playing
Hey do the tapes play at all? sometimes some tapes recorded
on other machines won't play on others. maybe you need to adjust the tracking on the VCR you are playing it on. If the tape
was recorded on a VCR that is misaligned it might not play back
on another VCR. Also the tape may have been recorded on a
super VHS VCR in et (extended definition) mode if so they won't play on just any VCR. If the picture looks scrambled like a
premium channel on analog cable then it's probably recorded in et.
and if its recorded on super VHS tape it may eject out of your VCR.
They don't make these S-VHS vcrs anymore but people still
have them around. There is also Digital VHS they're not
compatible with VHS either. A VHS recorded in et mode will
play on some more expensive vcrs it should say so on the box
or instructions.
Nov 14, 2007 | RCA VR634HF VHS VCR
How to record from KS 4110 DVD payer to VCR
Connect your DVD player to your VCR ( the out put from the dvd player is connected to the input of the vcr) then connect your vcr to the tv( the output from the vcr is connected to the tv)
Set your tv to what ever channel you connected your vcr to and hit the tv/vcr button on your vcr remote until you get the vcr displayed on the tv.(ensure your vcr is on when doing that)
now when you get your vcr displayed on the tv , turn on your dvd player and set your vcr to what ever channel you got the dvd player connected to(e.g INPUT 1 etc)
you dvd player should now be visable on your tv
simply insert a blank vcr tape and play your dvd and hit record on your vcr
Aug 26, 2007 | Koss KS4110 DVD Player
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
