Question about Canon BubbleJet i560 InkJet Printer
Used ink tank
My printer does'nt work anymore The printer status display next message: "The used ink tank is full. Cancel printing and turn the printer off and then back on. If this doesn't clear the error, see the printer manual for more details." I can't find any information in the printer manual! Is there any solution possibl? Many thanks in advance for anny help. Rontech
It seems there is no solution except to buy a new printer. if anyone responds with a solution, please let me know. When it first came up I took it outside and turned it upsidedown to to try to drain out the tanks. did not work I am going to know dry desperate stuff that will probably destroy the printer altogether, which is probably what they want us to do anyway.
Posted on Aug 29, 2007
Shows code U165
This section explains the way to confirm the ink status and the procedure to replace ink tanks. When ink runs out or other errors occur, an error message is displayed on the LCD to inform you of the error. See "An Error Message Is Displayed on the LCD".
When printing from your computer, error messages appear on your computer screen as well.
NOTE
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder.
The machine will not print if an ink tank is installed in the incorrect position.
With the LCD of this MachineMake sure that the machine is turned on, then press the COPY, FAX, SCAN, or MEMORY CARD button. The current ink level will be displayed on the LCD for a few seconds.
g0011480_tcm14-605381.png(A) Confirm whether any symbols are displayed here.
g0011482_tcm14-605375.pngColor or black ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011483_tcm14-605376.pngColor or black ink may have run out. See"An Error Message Is Displayed on the LCD".
REFERENCE
The ink status information is also displayed on the screen that appears during printing.
An error message may be displayed on the LCD during printing.
g0011494_tcm14-605377.pngMachine detected ink out condition. See "An Error Message Is Displayed on the LCD" and take appropriate action.
(B) Empty ink tank.With the Ink LampsYou can confirm the status of each ink tank by the ink lamps. Open the Scanning Unit (Printer Cover) of the machine to confirm how the ink lamps light or flash.
  • Ink lamp is on
The ink tank is correctly set and there is enough ink remaining to print.
  • Ink lamp is flashing
Flashing slowly (at around 3-second intervals)
Ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.
Flashing quickly (at around 1-second intervals)
The ink tank is inserted in the wrong position or it is empty. Ensure that the ink tank is in the correct position as directed by the label on the Print Head Holder. If the position is correct and its lamp flashes, it is empty. Replace it with a new one.
  • Ink lamp is off
The ink tank is not set properly or the function for detecting the remaining ink level is disabled.
If the ink tank is not set properly, press the g0009324_tcm14-605384.png mark on the ink tank until the tank clicks into place. If it does not click into place, make sure that the orange protective cap has been removed from the bottom of the ink tank.
If the function for detecting the remaining ink level is disabled, replace the ink tank with anew one. See "Replacing Ink Tanks".
If the lamps are still off after reinserting the ink tanks, there has been an error and the
machine cannot print. Check the error message displayed on the LCD. See "An Error
Getting the Clear Ink Status InformationClear ink is used only when printing on plain paper.
When Plain paper (Cassette) is selected for Media type and printing begins when clear ink (PGI-9Clear) is low, a message will be displayed in the LCD.
g0011497_tcm14-605385.png(A) Confirm whether a symbol is displayed here.
g0011502_tcm14-605378.pngThe clear ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011503_tcm14-605379.pngThe clear ink tank is empty. See ""The clear ink tank is empty. Replacing the ink tank is recommended." U045" and take appropriate action.
NOTE
  • The ink status information is also displayed on the screen that appears during printing.
  • Clear ink is used only when printing on plain paper. Therefore, it is possible to print on photo paper, or any type of paper other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
The following error message will be displayed on the LCD when the clear ink has run out during printing on plain paper.
g0011506_tcm14-605380.pngRefer to "Replacing Ink Tanks"If you continue printing under the clear ink out condition, see ""The clear Ink has run out. Replace the ink tank." U165/U166" and take appropriate action.When the clear ink hasrun out, printing on plain paper from the Cassette is not possible. The fax, which is received under the clear ink out condition, will be stored in memory.
NOTE
It is possible to print on photo paper, or any media type other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
Oct 01, 2011 | Canon PIXMA MX340 Wireless Office...
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
HI,
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
Tip
How to reset an HP printer waste ink tank aborber (only work on certain models)...
Press and hold the “left arrow” key.
Press the “Setup” key and release both keys.
Display should say “Enter Special Key Combo”
Press and release the “OK” button.
The Display should say “Support” and display the FW rev (something like R0616R)
Press and release the right arrow button until the display says “System Configuration Menu”.
The display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
The display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears.
DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
Turn the unit on. The printer may display the message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”.
Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
on Jan 02, 2010 | Office Equipment & Supplies
My HP Photosmart C6280 asks me to replace the light blue ink cartridge and says it is unable to print until we replace the ink cartridge. We have replaced it three times and the same message appears. The...
Follow the below steps on the front panel of the All-in-One printer:
A. - Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons.
Display should say "Enter Special Key Combo"
B. - Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
(try both and see which one will get you to system config menu )
display says "enter special key combo"
1. Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
2. Press and release the right arrow button until the display says "System Configuration
Menu".
3. Press and release the "OK" button.
4. Display should say "Hardware failure status". If not there already, Arrow Key over to
5. Press and release the "OK" button
6. Display should say "Hardware failure status: Clear. Press OK to clear".
7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared.
Press Cancel to continue".
8. Press and release the "CANCEL" button as many times as necessary, so that, either the
"Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears.
PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the
it is now powered down and unplugged.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the
11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer
will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do
13. To verify printer functionality print a SELF TEST PAGE.
Aug 31, 2011 | HP Photosmart C6280 Printer
Hello i have a problem errore in printer hp 8253 errore 0xc18a0206 plase help me tanks
A. - Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons. Display should say "Enter Special Key Combo"
1. Press and release the right arrow button until the display says "System Configuration Menu". (on C8100 use Touch Screen)
2. Press and release the "OK" button.
3. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
4. Press and release the "OK" button.
5. Display should say "Hardware failure status: Clear. Press OK to clear".
6. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
7. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
Oct 31, 2010 | HP - HP Photosmart 8250 printer
HOW DO YOU RESET THE ERROR MESSAGE 0xc18a0207 on an HP 6100 series all in one ?
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
C. - Press and release in sequence the “1”, “2” and “3” buttons.
1. Press and release the “OK” button.
2. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
3. Press and release the “OK” button.
4. Display should say “Hardware failure status: Clear. Press OK to clear”.
5. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
6. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
7. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
8. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
9. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
10. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
11. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
If the error is still there, or reoccurs replace the unit
Jul 26, 2010 | HP Photosmart C6180 All-In-One InkJet...
Ink system failure. States ink system has failed, unable mto print. Error 0xc18a0201
Try the following tricks:
Press and release the “Ok” button Press and release the right arrow button until the display says “System Configuration Menu”.
Press and release the “Ok” button.
Press Ok to clear”.
Press and release the “Ok” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “Cancel” button as many times as necessary, so that, either the “Welcome to
Photosmart Express” screen appears, or, the “Ink System Failure” screen appears.Please do not try to Print at this stage.
Using the Power Button, turn the unit Off and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
Turn the unit on. The printer may display message “Use only the power button to shut down the printer” followed
by “Press Ok to continue”. Press Ok. If the printer has already initialized, then go to the next step. If not, the printer will start the
“One time ink initialization process”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
To verify printer functionality print a Self Test Page. If Self Test prints, then printer is ready for use.
Good luck, Thanks for using FixYa.
Jun 03, 2010 | HP Photosmart C6280 Printer
Can print...ink system failure - followed process but it wont wor
release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
2. Press and release the “OK” button.
3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.
5. Display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
13. If the error is still there, or reoccurs replace the unit
Aug 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
Status Monitor informs of Ink levels requiring me to press resume button during and after each print job.
What it means is the tank to collect waste ink (from cleaning etc) is full.
Canon suggest you return ther printer for replacement of the absorbant mat, suggest you scour the web for DIY cures.
Oct 19, 2007 | Canon i9100 InkJet Photo Printer
Canon BubbleJet i560 InkJet Printer Logo
166 people viewed this question
old marine
old marine
