Question about Canon imageCLASS D880 All-In-One Laser Printer
Canon MP470 - Paper starts to feed and twists then jams
My daughter bought a printer that is only 3 months old and when it tries to print the paper starts, then looking from the front of the printer the left side continues to feed and the right side does not causing the paper to krinkle and jam. The problem is it still wants to print. Can anyone tell me how to fix it or is this just a lost cause and needs to be junked and start over. Thanks for any assistance.
I had the same problem, mine went into the printer fine and started to tilt. all i did was check the paper input slot and there was a necklace stuck in it, it was an easy fix after all, just had to pull it out. too bad there are more problems than it is worth tho, right now mine wont feed lol
Posted on Dec 14, 2008
How to fix Canon Pixma MP470 printer that does not feed paper properly to print from Windows PC
Open up the printer and see if there is a small piece of paper that is interfering with the paper path. You may have to use a flashlight to see it.
Sep 10, 2014 | Canon PIXMA MP470 All-in-One Printer
Hi I have a cannon mp470 and it will not pull paper through to print. It either doesn't catch at all, or it will jam to one side.
Hi
There is something stopping the paper feed process. Try the following
1. Check and make sure nothing is fallen inside the paper tray
2. Remove anything stuck
3. Even if you are not able to see anything stuck tray to use a air blower and blow air in the tray this will remove anything stuck.
Jul 15, 2011 | Canon PIXMA MP470 All-in-One Printer
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
Oct 07, 2009 | Canon PIXMA MP470 All-in-One Printer
My MP470 Pixma won't feed paper, it pulls right
Based on instructions from your website I pushed a letter sized piece of thin cardboard backwards through the paper feed rollers then shook the printer while holding it upside down. A Q tip fell out, problem solved.
Jul 19, 2009 | Canon PIXMA MP470 All-in-One Printer
When the printing starts the paper jams in the paper tray
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 22, 2009 | Canon PIXMA MP470 All-in-One Printer
Canon MP470 says "paper is jammed" but there is no jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Jan 18, 2009 | Canon PIXMA MP470 All-in-One Printer
Paper feed
Your printer is politely asking you to please get a torch, and open the lid of unit and thoroughly check inside all over for a tiny jam of paper or something else. I am willing to bet you will find some jam. I would also switch it off, and wait a while before turning on and printing again. Good luck
Aug 31, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon imageCLASS D880 All-In-One Laser Printer Logo
221 people viewed this question
old marine
old marine
