Question about HP OfficeJet K80 All-In-One InkJet Printer
Replacing dislodged paper motor encoder disc on hp officejet k80
Ink was all over the inside of my printer so it just was not working . my it guys gave up on it. I decided that I had nothing to loose so I took it apart and cleaned it up bit by bit it seems to be good again exept that during the opperation the PAPER MOTOR ENCODER DISC came loose. I dont know what possition it should be in. it has numbers on it like a clock face 1TO 12. Please advise
part # is C4557-80019
THANKS
ELVIS MCKOY
ST.KITTS
  • HP Master
  • 685 Answers
Http://www.printerworks.com/Catalogs/DJ9xx-Catalog/222_9xxFeedRollerPivot.html here is a site for u
Posted on Nov 11, 2008
Problem with printer or ink system
PDF]HP Officejet Pro X476 and X576 MFP Series ... - Parts Now
www.partsnow.com/.../Officejet%20Pro%20X476%20X5...
Parts Now LLCFigure 2-6 Printer status report-determining genuine HP ink usage . ..... Thesecartridges are linked by flow connections to the rest of the printbar and supply the ink..... The left door can be opened for jam clearance and has a hall effect .... The document feeder will not function when the document feeder cover is open.
db:: 4.32::Printer door will not close after printing 8p - Hivmr
www.hivmr.com/db/8p83f78d97fk8c883x9p9za3mf993scf
On the 50.8 error message, if power cycling doesn't fix the issue you may need to ...Opened printer cartridge access door and removed paper. ... HP Officejet Pro L7580, the latch to the ink cartidges broke, so the door won't close. ... Can not close the printer door on my HP B210a, after cartridge replacement need help?
Re: Do u need Help? -HP All-in-One's(Officejet,Psc's)
www.fixyourownprinter.com/posts/28357
Also, when reinstalling the HP it does print a test page, but will not print from ...Encoder Strip has been cleaned with water (had some ink residue). ..... when opening the door the cartridge does not move to the middle so i can remove it, clean it ...... Iopened the covering part of the scanner (with the glass) nad cleaned all the ...
HP Officejet 6210- repeated ' FixYourOwnPrinter
Dec 28, 2015 | HP Officejet 6600 e-All-in-One -...
I have proplem with paper jam , so I replaced motoer of model 510 with motor of model 500 . I printed one copy but it didn't complete seccessfully , what should I do ???? The motor of model 510 d
Both Disc encoder & Motor same for 500 & 510... But its not motor fault,
1. Clean Media sensor P/N:C7769-60168
2. Clean disc encoder.
3. Clean drive roller encoder PCB P/no:C7769-60172
Pl share the error message after doing this activity..
Jan 09, 2013 | HP DesignJet 500ps (42 in.) InkJet Printer
HP 6110 Printer jams after 1 sheet
Thanks for contacting Fixya.com
Please try the bellow mentioned troubleshooting steps to help elliminate the paper jam and noise issue for your printer:
Things that cause a carriage jam error:
Dirty encoder strip.
Damaged encoder strip.
Encoder strip spring mount out of position so strip is slack.
Encoder strip not threaded through the emitter/detector that reads the lines on the strip. (just fixed a 5550 with this problem)
Emitter/detector that reads the lines on the strip is bad, this is part of the carriage PCA, (board).
Carriage stuck on side because service station is not releasing it.
Carriage stuck due to being tilted at wrong angle, if it's stuck a few inches from the right it needs to move farther to the right to be released, stuck a few inches from the left end move it farther to the left. (instructions probably on HP web site, they are there for the DeskJet 5550)
Carriage binding on rail due to ink build-up or lack of lubrication, (be careful what you use to lube).
Bad carriage motor.
Bad carriage drive belt.
Some machines have a timing disc on the service station motor and may indicate a carriage jam if the service station motor does not turn.
The cause could also be a loose cable connection on a small circuitboard inside the printer (The one that controlled the paper jam sensors) I fixed it by saudering the leads to the board until I had a good connection again.
Thank You and best of luck,.
Jul 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP K80 paper jamming during fax
Did not resolve issue, but was looking for free advice at the time. Will look in to your product later.
Thanks
K
Sep 16, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
OfficeJet K80 All In One
Hello ,
This printer is quiet an older version of the Office Jet printers of HP. You just have to plug it in to the MAC and it gets installed automatically. It has inbuilt preloaded drivers into it. Otherwise just follow the simple steps to Add a Printer in MAC.
Apr 12, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Hp K80 printer
I cleaned the vertical centerpost (you'll see it when the cartidge is out)with a small amount of acetone (nail polish remover) on a Qtip & it works fine now....must be some kind of circuit that needs to be closed and the ink on it kept it open....
Dec 19, 2007 | HP OfficeJet K80 All-In-One InkJet Printer
Multiple paper feed
The paper separator pad is worn out and will need to be replaced. It's a rubber pad that rests behind the paper pickup roller and is supposed to prevent what you're experiencing. Contact your nearest authorized HP repair center.
Apr 13, 2007 | HP OfficeJet K80 All-In-One InkJet Printer
Telling me that the cover is open and cartridge jam.
Suggest you read your manual! Fax use standard phone line not internet connection!!!!!!
Mar 06, 2007 | HP OfficeJet K80 All-In-One InkJet Printer
You may want to start from the begining. Unplug the printer from the wall and computer for atleast 2 or 3 minutes 5 to 10 wouldn't hurt. Remove the cartridges. Sometimes the computer thinks for the printer when it comes to ink levels. Before rehooking the printer to the computer. Turn the printer on, reinsert the cartridges, then hook the printer to the computer and reboot. The printer will hopefully work for you at this point. If not try the same, but uninstall all software and download the newest from HP. Let me know what happen. Good Luck, Tim
HP OfficeJet K80 All-In-One InkJet Printer Logo
137 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
