Question about Durabrand CD/MP3 Player, CD-968 Personal CD Player
My green headphone jack is jammed inside the casing
Last week I put my phones in the jack and I couldn't hear sound, I took out my phones and the green jack hole was stuck up under the casing. Now the only way to listen to music is if I force down the phones with tape. Please help me.
0 characters
1 Points
I can't turn it on, the batteries are good I just don't know how to use it
Place a cd inside the tray and close the door. If there is a power button on the side shift it to power on. Now the display should ccome on and the cd must start turning. If you get a reading and the clock counts then plug in the headdphone jack into the small headphone socket and increase volume. If none of these happens you will have to check from thebegining. check your bateries, clean your head and check. If no display , you have a failure in the board, if display come and no reading, your opticcal unit is faulty/. I hope this helps you. Good day
Jun 03, 2010 | Memorex MD6451R Personal CD Player
Volume too low - don't have headset that came with it - I have various headsets, but only one works - can I buy just a headset?
yes you can, but that should not be the problem. make sure you are not plugging it into the line out this does not tie into the volume switch. if your plugging it into the headphone jack and believe its just faulty headphones go to walmart and buy new ones.
Apr 12, 2010 | GPX C3976 Personal CD Player
I bought my husband some wireless headphones. The
All you have is to connect the 3 wires from the cable that is for going to the phones jack, at the pins 1,3,4 of the scart a/v of the tv. Mention that the shield of the cable (the one is going at the big outer metal of the phones plug) must connect at the pin 4.Here is a pinout of the a/v pins
I suppose that a euro a/v (or scart a/v) to RCA or mini jack adaptor is posible to be found at your market so you don't have to make one by yourself.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Feb 24, 2010 | RCA Personal MP3/CD Player
I want to know the output jacks identifacation teac hmx-750
Not sure exactly what you are asking for, but:
The output jack is a headphone jack that is 1/8" diameter with the following pinout: tip = left channel, ring (next contact) is the right channel, sleeve (third larger contact area is the common/return for the left and right audio.
Sep 13, 2009 | Personal CD Players
I want to open the cd player to replace the jack connector. I took out all the screws, but something inside is holding everything together.
if it is in guarrantee Don' t open it! you may cause damage in it's mechanism! refer servicing to qalified every engineer says
Jul 05, 2009 | Coby CX-CD1112 Personal CD Player
Audio output from my TV
take a red and white audio rca cable and cut off one end of the jacks. on the end you cut, solder a headphone output plug on. can also solder on the lines of a pair of headphones (where you've cut off the 1/8 in jack) directly to the rcv jacks.
Nov 07, 2008 | RCA Personal MP3/CD Player
Sound problems on my D-NE720
!st, try a different pair of headphones. If the problem persists, the jack is breaking from the PCB and will need to be resoldered.
Sep 17, 2007 | Sony D-NE720 Personal CD Player
Sound only comes from left earphone (taking the cover off the headphone jack)
Hello. The problem could be the jack itself, more exactly it has a bad contact with the main board. If you have a soldering equipment you should try to resolder the jack to the main board. Or you may try to go at a service center, to have the jack replaced just to be shure. It isn't an expensive repair and can be done in half hour at max. I don't recomand you to try to dissasemble the jack because it may get damaged even further. check the connections with the main board, it may even be a broken pin. Good luck, feel free to ask further questions and don't forget to rate any answer received from this site :)
Mar 03, 2007 | Sony Walkman D-FJ61 Personal CD Player
Personal CD Players Logo
Top Durabrand Personal CD Players Experts
Todd Zettlemoyer
Todd Zettlemoyer
Are you a Durabrand Personal CD Player Expert? Answer questions, earn points and help others
