Question about Samsung HCN653W 65" Rear Projection Television
Looks 3D
My picture all of a sudden looks like i should be wearing 3D glasses in order to see clearly. Also the picture is bowed at the top and bottom of the t.v. Is the problem the convergence board?
  • 2 more comments
  • RDRCLASOF99 Nov 15, 2008
    SAME PROBLEM
  • tigreyes2u2 Nov 22, 2008
    Kinda odd that the same problem in same month, just about the same time. I noticed mine last week as well.
  • unkeloz Dec 31, 2008
    same issue.  the red and green lamps seem out of alignment.  the green light seems to be the culprit as when i block it off, the bow in the picture goes away.  Any ideas?
  • jmcdougall4 Feb 04, 2009
    red and green dont line up on sansung hcn653w 65" rp hdtv can adjust with mute 183 but cant save settings need help
I had a repairman replace the convergence boards. The picture is fine now however red & green colors are messed up.
Posted on Dec 26, 2008
I turned My tv on and the top of the screen has red, green, and blue swirl lines, and the rest of it looks like watching a 3D movie without glasses, and the picture looks as if you took out the screen and...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or pictures look like 3D?Yes,than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-$350 for parts and labors.
Aug 11, 2011 | RCA D52W19 52" Rear Projection Television
Picture is bowed inward and looks like a 3d image without the glasses. I also have a green, red, and blue line curving across the top of the picture.
Looks like the focusing lens may have moved a bit or the projector lamp has gone weak. Get a technician to check up the projector.
There's very little you can do here.
Mar 05, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture looks like 3d i have ajusted screen but keeps going back to 3d and picture is bowed
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 25, 2010 | RCA P56923BL 56" Rear Projection...
Looks 3d,bows in the middle
You must replace conversion IC's (2)
Part number: STK 392-xxx
Also check resitors in circuit for>>open
easy repair!
May 19, 2010 | Sony KP-43HT20 43" Rear Projection...
My RCA big screen TV picture now looks like 3D without the glasses. The picture also bows in at the top and bottom in the middle of the screen. What would cause this?
Go to menu then setup if you donot see convergence on menu then you have a blowed Fuse FL231 it will be on Bottom board to left side onthe righht side of FBT flyback transfomer there is 3 of them in a roll small brwn rectangler looking caps But are fuses the one in the middle is it. Call Mats for fuse 1-800-628-1118
Sep 26, 2009 | RCA Televison & Video
3d picture and looks like bow tie
Bad STK ICs replace both ICs will have part number on them STK392-110s if this is what you have upgrade to 150s! ICs are Big black ICs also ck 2.7 ohm resistors near ics.
Sep 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Screen showing lots of colors caving in on top
You have no power to your convergence circuit. Depending on what model RCA you have will determine which parts are bad. Will cost about $200-$300 for a repair shop to repair.
Jul 08, 2009 | Televison & Video
Picture is all distorted ,colors dont match up need 3d glasses to watch
HI, this is basic convergence failure. the convergence board controls the RGB stream and , if its malfunctioning or, the convergence chip set is damaged, it will distort the entire display and the colors will not be regulated correctly as you are experiencing at this time.
simply replacing the convergence board in this unit will fix your issue.
May 18, 2009 | RCA Televison & Video
Hitachi ld328700 picture and colour gone faulty
there was another guy on here that had the same problem and he ended up throwing the tv away because it cost too much to repair, you migt call a repair man in and see what they quote you on yours
Jan 08, 2009 | 2000 Ford Focus
Picture looks like 3D without 3D glasses on???
The cost I don't know, but this can be fixed. I'd say shop around a bit. Make sure the repair person is certified for your TV's manufacturer. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Dec 30, 2008 | RCA HD52W59 HDTV Projection Television
Samsung HCN653W 65" Rear Projection Television Logo
237 people viewed this question
Henry  Thomas
Henry Thomas
