Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Our Bosch dishwasher will not drain. Model number is SHY56A05UC/23. Help!
  • Anonymous Nov 26, 2008
    The Bosch dishwasher will not drain. My wife broke a stem glass recently which shattered nicely in the machine while removing it. I found a piece of glass inside the strainer/ filter. Is it possible glass is preventing drainage somehow?
  • sakinzel Dec 11, 2008
    My dishwasher doesn't drain
    Sergeant:
    Champion:
  • 324 Answers
Can you hear humming?try taking out the screen filter and there is a torx screw that you can see, remove the screw and see if there is anything in there when you remove the panel.you will see the drain impeller try turning it by hand. if it is siezed then you will have to replace it.try putting it back together and try it again.
let me know.
Posted on Nov 11, 2008
Error 23 in bosch dishwasher
E23
Winding resistance of drain pump fault.
The controlled has detected a break or short in the drain pump wiring. Many of these dishwashers use this pump which is a cheap compatible one.
Dado
Jan 29, 2015 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch dishwasher shy56a05uc 14
I would assume it would leave water in the machine. some machines have this as a function. it is used to keep water in the drum to stop items becoming excessively creased. it is mainly used if you are not going to empty the machine for a while. you should be able to press the cancel button again to start the draining process.
Dec 13, 2013 | Dishwashers
How do you check for error codes on a Bosch SHY56A05UC/23 Dishwasher? My dishwasher runs continuously in the drain mode and the "cancel drain" feature does not work.
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Jan 29, 2011 | Bosch 24 in. SHY56A05 Stainless Steel...
My SHY56A05UC Basch dishwasher runs and dose not shut off
The dishwasher is stuck in drain mode because there is water in a catch leak area underneath, it may have been caused by soap suds over flow or disposal backup. Remove bottom kick plate and vacuum out any water, then run dishwasher again and look for water leaks.
May 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Wont drain check everything push drain botton still wont drain
i call a repairman in it was the drain pump thank you for your help NOT what a joke this site is have a good day boys
May 18, 2009 | Bosch 23 in. SHU33A Built-In Dishwasher
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch SHY56A05UC Drain Pump Replacement
It's not easy. I just look at my sister-in-laws and I think the tub needs to come off. I plan on working on it this week.
Bruce
Jan 13, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch SHY56A05UC/14
There is a pass through the lower back side of the dishwasher that also has a restraining device to prevent drain hose from being pulled off of drain pump. After passing hose through this opening, connect hose to drain pump. Note: there is another restraining device built into lower plastic housing which has a finger notch to accept hose and keeps the drain hose engaged in to drain pump by not allowing hose to back out of drain pump/ hose interface.
Dec 01, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
259 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
