Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool Diswasher did not drain
I found your comment and would like to learn how you fix your Diswasher. Please help and email me at henry77024@yahoo.com. Thank you in advance.
Comment by tnl76, posted on Sep 09, 2008 I have a Quiet Partner II that will not drain after a complete cycle. The dishes are clean but water remains after cycle. When I hit cancel/drain it will drain at times but not all the time. Please help.
  • 6,784 Answers
HI, this seems to be an obstructed hose(drain). i recommend inspecting the hoses before replacing the pump.
To access the drain hose remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
The drain hose connects to the pump and runs to the sink drain (or to the air gap on top of the sink). The pump has a second hose that recirculates the water back into the dishwasher. The drain hose is roughly 1 1/2 inches in diameter. While inspecting the drain hose, check the recirculation hose as well.
When checking for blockages, disconnect the drain hose from the pump, pinch the wire clamp with pliers and slide it up the hose. Place a shallow pan beneath the pump to catch any spillage. Remove the hose from the pump; wiggling the hose may help to loosen it.
Check the hose and nipple to the pump for any debris. The only way to be certain the drain hose is completely clear is to disconnect it from the sink and run water through (such as spraying a garden hose through it at full pressure). Disconnect the recirculation hose and check it in the same way.
Reconnect the hoses and replace the clamps. Replace the lower panel and restore electricity to the dishwasher. If there are no obstructions found or debris, this will confirm a damaged pump and, it should be replaced.
Posted on Jul 28, 2009
We have a built in diswasher MDBH969 AWQ which is less than 2 years old. Suddenly the Door to the washer drops down quickly rather than what appeard to be spring loaded and would drop slowly before.
Bbeldenjr, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Bbeldenjr), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 23, 2017 | Whirlpool MDBH969AWS Builtin Dishwasher
My whirlpool quiet wash plus diswasher is not draining water. How do I fix it?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 14, 2011 | Dishwashers
Hi , im getting the a10 error code on the whirlpool washing machine. I checked the hose and its not krinked or blocked. It seems fine at the begining but stop's at the rinse/drain cycle and the error...
Gfontanelli, we're sorry to learn that you're receiving an error code on your Washer. Thank you for your review. We would like to discuss this further with you. Please email us at Whirlpool_Reviews@Whirlpool.com at your earliest convenience with your user name Gfontanelli , name, address, a phone number and best time to reach you along with your model and serial number.
Oct 31, 2017 | Whirlpool WFC7500VW Washer
I have Frigidaire FDB956RBC1 diswasher. I have to turn off the water to fix the faucet. When I turned the water back on, water did not go to the diswasher when I used it. The diswasher runs normal except...
FRIDG... EXPERT HERE
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 19, 2011 | Frigidaire FDB956RB Built-in Dishwasher
The clean light is blinking diswasher won't start
Push these buttons in this order High temp wash > Heated dry>High temp wash >Heated dry all the lights will come on and this will reset the board and run it through a short test cycle but more than likely it will come up again,It's a failure in the heating cycle either the heater itself or the turbidity sensor which sits mounted up into the tub right behind the drain pump...hope this helps
Sep 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Water not draining from dishwasher
1.attache the drain hose to the bottom of contertop.
2. drain back valve is not work properly.
Dec 20, 2008 | Whirlpool Dishwashers
Dishwasher will not drain water. Put Drain-O in did not work,ran short cycle water on floor. HELP
My Whirlpool Diswasher did not drain water. The same water has been recycling from washing thru rinsing and sitting there after done.
Model: S62NXPLP-7624
Oct 03, 2008 | Dishwashers
WHIRPOOL DISHWASHER WILL NOT DRAIN
I had this problem too & found the discharge hose was clogged. To fix it I had to pull out the diswasher , disconnect the drain hose and blow it out.
Mar 24, 2008 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
177 people viewed this question
Dan Webster
Dan Webster
Sal De
