Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Rangemax-internet only works when comp directly connected via LAN
I set up my Rangemax WPN824v3 exactly the way it said in the manual. I have internet when the ethernet cable is connected to my laptop but when I disconnect it to make my laptop "wireless", my computer connects with an excellent connection to the router but when I bring up the IE, it has the cannot display page. The mac address, cables, IP, WPA key and internet network are all set up correctly. How can I get the internet to work without having to have my computer plugged into the router directly?
    Scholar:
  • 84 Answers
It sounds like you have the wireless connection to the WAN disabled. Go through the wireless settings on the router and check to make sure it's not being blocked from the WAN/Internet connection.
Posted on Nov 11, 2008
How do i connect my netgear rangemax wireless router
You should have a manual/setup guide.
BUT, the basics of setting a wireless router are.
Connect an ethernet cable from your MODEM to the WAN port on the rear of the ROUTER.
Connect an ethernet cable from one of the LAN ports (usually 4) to your computer.
You now log on to your router via your web browser, set your wireless security (using WPA2) choose your password.
Save and exit from the router setup, disconnect the ethernet cable from your computer to the router and try and connect wirelessly
Your support page is here, choose which version of the router you have and download your manual
http://kb.netgear.com/app/products/family/a_id/1299
Aug 11, 2010 | NetGear RangeMax WPN824 Router
No internet connection
Check if you can , by pass the wizard and set the connection manually. Let me find more details for you
Thanks
proton
Jul 24, 2008 | NetGear RangeMax WPN824 Router
Have a new desk top bought the wireless-g usb adapter wg111 to pick up my netgear range max wireless router wpn824v3. After installing the wireless-G picked up internet once but after the system was shut...
I have the WPN824v3 and it can be balky finding and connecting to a network sometimes. It works best (and gets the best range) using the Netgear RangeMax Wireless USB 2.0 adapter (WPN111). The router and this adapter are (according to Netgear) specifically designed to work with each other, thereby maximizing both the range and the speed of the router.
Feb 02, 2010 | NetGear RangeMax WPN824 Router
I just bought a Sony Bravia TV and am trying to connect it to the internet via my WPN824v2 LAN - it's not working and the LAN lights never light up on my router. Wireless connections are fine - even new...
I spent the last day trying to solve this, what worked was:
Home
Settings
Network
Refresh Internet Content
Wait (a while) until it Authenticates
Normal Internet service resumed :-)
Jan 11, 2010 | NetGear RangeMax WPN824 Wireless Router...
NetGear NETGEAR WNDR3300 RangeMax Dual Band router
The Netgear wireless router wireless settings need to be configured and the the wireless card in the computer and XBox needs to be configured with the Netgear wireless settings.
Follow these steps. : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 11, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Not able to configure and connect to internet using router
Try 192.168.0.0 which would be the default address to access your modem. This should allow you to go into the modem and adjust changes. I know on the bottom of my router there is an administrator default password that can e used to access the mainframe of the modem. Check out these features in there. I would start first by connecting via LAN again and then try to conntect to it via a WAN but again see if you can access the modem using the 192.168.0.0.
May 18, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Netgear wpn824v3 slow connection, etc
MTU Adjustment
1. Access the web-based utility of the router.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
2. Adjust the MTU setting.
a. Click on the WAN Setup under Advanced tab.
b. Lower down the MTU size to 1492, 1400, 1358 or 1300.
c. Click on the Apply button.
Note: You may verify from your ISP the recommended MTU size you can use.
May 02, 2009 | NetGear RangeMax WPN824 Router
Help
yes,that's very possible.you can connect directly the wii to your lan if your wlan is having some kind of a glitch that will not allow you to connect to the internet.now,once connected via lan,you can browse on opera per the message you've been getting and see if you can follow their instructions to solve the matter.later on if you still can't connect,you might want to set-up again you wii connect settings.make sure your router is working properly and is set to detect/accept your wii.also,your wep or wpa password should exactly be the one you need to key in on your wii internet setting.if it's wpa,try to select AES.no guarantees.hope this helps.
Apr 27, 2008 | Nintendo Wii Console
Can't connect a PC to internet via rangemax
Sounds like the network card on the 3rd computer might be set to a manual ip address. Is the rangemax router the dhcp server? if so is the network card on the 3rd computer set to obtain an ip address automatically?
can you tell me the ip address of the rangemax router?
whats the ip address of the 3rd pc?
Thanks,
Brad
Feb 21, 2008 | NetGear RangeMax WPN824 Wireless Router...
Can not connect to router via a wireless connection.
You could try to manually set your IP address in the TCP/IP, the gateway and your ISP DNS
Jan 23, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
146 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
