Question about E-Machines eMachines Desktop PC
My E drive is missing from my computer....
I click on my computer to access my e drive(its a hard drive)... i am totally surprised to find it gone!! is it because some cables are disconnected... pls help...there are alot of important files... I Have done nothing Different with my computer but some how my E: Drive Got Messed Up it won't read any disk and I can't even play dvds on it what can I do to make it work again!!!!!
    Scholar:
  • 112 Answers
I am confused as to what the drive is. Are you talking about the hard drive (stores data), optical drive (reads and writes data on a disc). Please update your post.
Posted on Nov 11, 2008
    Sergeant:
  • 395 Answers
Start Menu - COmputer - right-click - Manage - Storage - Disk Management
What do you see ???
Posted on Nov 12, 2008
Hi, I have WD 1TB Elements SE. When I checked the usage space on the partition after I plug in the drive, it shows a total capacity as 1,000,200,990,720 bytes (931 GB) and it shows 921,753,505,792 bytes...
If you have a 32bit system, it is expected to have miscalculations, a 32 bits can only go up to 4Gb for calculations (that is, 2^32 = 4'294'967'296 bytes) a 64bit system can make calculations to 2^64 bytes this is also why you couldn't copy a file larger than 4Gb in a 32bit operating system...
So, if you are running a 32bit OS, you should expect a discrepancy for the total space of the Hard Drive and the amount it shows (that's the 93Gb you are missing as total capacity).
Another reason why it can show you incorrect calculations are damaged sectors on the hard drive it-self. These will present themselves either as occupied memory or missing memory.
So, you should expect some miss calculations and you can expect some damaged sectors on the hard disk (a external drive spins on and off too often, eventually damaging sectors... its a problem of physical drives).
In the end, your disk might be fragmented, so run a disk analysis and a defragmentation on the disk so it can recalculate.
A note: A disk is like a shelve, you put things where there is space, if you remove things, that space will be open, and if you want to put something there it has to be the exact size or small enough to fit there. This effect, when things are small enough leaves blank spaces unusable, consuming space on the hard drive and making the access of files slower, this is fragmentation. In order to expand your disk life expectancy you should run defragmentations...
To run a defragmentation, go to START, write "Disk Defragmenter", choose your disk and run and analysis and defragmentation.
Jun 24, 2011 | Western Digital Wd Elements Se 1tb...
Tip
How to back up a offline disk folder
<p>Backing up your computer in a folder on the hard disk that goes offline, because sometimes surprisingly simple for the Windows Sync Center. You have a network available offline. Your computer will copy the backup of the hard drive of your computer's hard drive when you're online. The folder will appear as if it were accessible online, because the files are copied to the folder on your computer and then sync when the device is online. <br /> <p><br /> <p>1. Click "Start", "computer" and open the folder with your backup folder. Right-click the backup folder and click on "always available offline." <br /> <p><br /> <p>2. Waiting for the files in the directory so that the copy on your computer available offline. <br /> <p><br /> <p>3. Right-click again on the backup folder and click on "Map Network Drive". Click "Finish". <br /> <p><br /> <p>4. Click Start, Control Panel, System and Security "and" Backup and Restore. "Click" Create Backup.<br /> <p> <br /> <p>5. Select the mapped drive that you defined earlier in the Drive list. Click "Next" and follow the steps to complete your backup to adjust. Click Save Settings and perform the backup. " <br />
on Jun 22, 2011 | Computers & Internet
Drive only reports 56gb to partition - missing 100gb! How do I access the remaining space?
Click Start
Right-mouse click "My Computer".
Click "Manage".
Expand the "Storage" part of the tree.
Click "Disk Management".
View the diagram for your disk-drive.
Does it show the 56GB partition, followed by 100GB of "unallocated" space,
or does it show one (approximately) 160GB partition?
If the former, backup all the files in the partition (copy to an external disk-drive, or copied to DVD-recordable disks, or to another computer).
Then, use "Disk Management" to delete that "small" partition, and to define a new partition that "spans" the entire volume, and to initialize the partition.
Then, copy the "saved" files back onto the drive.
Dec 18, 2010 | Western Digital Scorpio WD1600BEVS 160 GB...
MISSING STORAGE SPACE
HARD DRIVE NEVER SHOWS TOTAL.ITS BECAUSE OF A CONFLICT CONCERNING WHAT SOME SAY IS A GB. ITS NORMAL AND YOUR DRIVE FINE.RELAX AND ENJOY.RICHARDM69
Dec 06, 2008 | SimpleTech 320GB SimpleDrive External by...
Cannot access hard drive after putting in external box
First, retrace your steps.
Make sure that the hard drive in the ext. casing is set to Drive 0 or master. If it is a Western Digital, take off any jumpers. If it Maxtor or Seagate it needs a jumper on the master pins. The legend on the hard drive will show you where.
Then, make sure that the IDE cable is on correctly. Or like many enclosures, you have to push the hard drive onto the connector.
When you power the unit up, listen to the hard drive and hear if it is spinning up.
Then see if it works.
I would also try a different USB port.
Did the enclosure include an AC power source? If not , the USB may not have enough power to run the unit.
If it still shows as an unknown unit, I would set it up as a secondary internally on your new PC to see if it is in fact the hard drive that is bad.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 12, 2008 | Computers & Internet
How can i erase all infomation and reformat this external drive
Hi
Right click on the related drive letter under "My Computer" choose "Format" and proceed. That will start several minutes progress depending on the access speed. After format complete it will be totally erased.
Good Luck
Sep 08, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Cannot see my hard drive
first download and install Drive Rescue. Click on Find lost drive, select the drive you miss and click "findlogical drives". Now you should access all of your files. Save them toanother drive and format the hard disk.
hope to be helpful
Riccardo
Aug 03, 2008 | Western Digital Passport WDXML800UE...
3 partitions missing on a 250gb SATA hard disk
i think you just got corruption. possibly heat related. or rootkit. uhh dynamic isn't right i think its logical .. right click the drive letter lower section and convert is best bet. i also dabbed with ptedit32 from bootable cd ubcd4win.com to fix lost partitions in prior experience.. but it was 1 partition and i found lba and other settings on drive sticker.
Jul 09, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
is e drive a partition or another hard drive solutions are different for both
Sep 05, 2007 | E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz...
E-Machines eMachines Desktop PC Logo
364 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
