Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 stops every time with 1 second to go
My washer goes through the cycle, Havent actually wacthed it because it is in another room but every time i go to empty it it still has 1 second to go and i have to turn it off. When i open it the clothes havent spun. I have put it back on and it used to finish the second time around , but now it wont go any further than 1 second and the clothes still wet no matter how many times i try. I would be grateful for any suggestions as my washing is piling up if its something my husband could repair.
  • Anonymous Feb 22, 2008
    same prob. but can verify that heater is good & will not pickup speed and spin in any selected final spin
GARBAGE
Posted on Feb 22, 2008
This problem is caused by the heating element not working.The machine won`t spin & finish because the machine knows it hasn`t heated the water during the wash programe but clock will still count down.this is what we were told by a hotpoint engineer.the callout charge is £89.98 from hotpoint this includes parts & labour. 27/7/07
Posted on Jul 27, 2007
Hotpoint ultima WDD960, My washer dryer has stopped mid wash cycle annd is displayinh F:o5
  • F05 - Pressure switch jammed on full - Check pump for blackages.
  • The best thing is to see if it is filling and draining properly
Oct 28, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WF860 drum not turning. Belt checked all ok, no error codes it just fills with water and goes through the cycle filling and emptying when it should and the drum stays still. Can someone help?
ours did the same as this........ it needed a new control board after checking everything you have mentioned. it was a couple of years ago and at that time it was a hotpoint part only. but they can be picked up on ebay for around 30-40 quid.
Oct 18, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint washer will not start when you press
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
May 23, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a Hotpoint Ultima 1200 - WM75. At the end
Check the filter and the actual pump itself for blockage.unless you have already done so, also pump itself could be faulty.
Mar 29, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WF860 Cycle does not end
could b presure system blocked up find this on side of filter long plastic *****
Nov 29, 2009 | Hotpoint Ultima WF860 Front Load Washer
Every time we try to wash it comes up test and goes through a test cycle. Will not wash. Hotpoint WF860
Nov 26, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima 840
hold child lock button down for 2 seconds you will then hear a beep done.
Jun 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima WT9 60
the internal circuit board has come loose, switch off power take the top off and tighten the connections on the plugs inside
Feb 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
280 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
