Question about Gateway EV 910 19" CRT Monitor
Display not showing reds
My reds on my display come in and out sporadically. Right now I have no red but all of the other colors are fine. When I try to adjust the contrast, brightness, etc., directly on the monitor, the reds come out clearly on the monitor pop-up menu but still not on the actual monitor window. Can you provide any help?
  • Cre8ive1
    Cre8ive1 Nov 14, 2008
    Thank-you! This seems to have taken care of the problem!
    Guru:
  • 859 Answers
This sounds like it is specific to the display adapter in your PC and not the monitor. Specifically, the area that usually is affected causing a problem like this is the connection of the heavy cable running from your Monitor to the back of your PC. At the back of the PC, check to see that the knobs are screwed in tightly and the plug is not loose in the socket. In some cases the cable also screws into place on the back of the monitor, but this is more common on flat screens, check it anyway.
Otherwise, should this continue after you check the connection, I would need to know if the heavy cable from the monitor screws in to the back of the PC near the keyboard and mouse connector or is further down, much further down and connects at the back of a slot. If it is a slot, the slot is occupied by a display adapter card inside the PC. This adapter card may be loose enough to cause the problem. You would have to shut the PC down, unplug the power, remove the side cover and look for the adapter itself. It should be noticeable by the socket it has that the cable connects to. You may have to unscrew a screw holding it in place, carefully remove it from its slot (there may be a hold down release at the back end of the card furthest away from the slot itself, release that) once the card is removed, reinsert it firmly and completely, screw it back down, replace the side cover and hook everything backup and see if that hasn't resolved your problem. If it hasn't let me know, so we can proceed to another step in this process.
Regards,
Worldvet
Posted on Nov 11, 2008
How to Fix display problems ( red display, or only for about 2 seconds display)
There are two problems, screen goes black after 2 seconds, red only. The problem is in the video processing board located on the back of the picture tube, it is well shielded against outside interference.
Apr 07, 2012 | IBM J156-1702 17 in.CRT Conventional...
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
Color loss
Hi, right click on an empty area of th e desktop, select "Properties," next, pick all areas that will apply: Windows Color and Appearance, Display Settings... make the adjustments, "resolution etc. "Rating the solution is appreciated, thanks."
Apr 13, 2010 | Acer AL1916W 19" LCD Monitor
My new monitor will not display RED. All the
Check for a bent pin in the VGA connector. Each color, Red, Green, and Blue has its own pin for the signal. If its pin is bent then no color!
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 29, 2009 | Samsung SyncMaster 930BF 19" LCD Monitor
Viewsonic VP930b color problem - Red tint
Go to the setup menu on the LCD panel by pressing button 1 on the front. See if there is an option to reset the lcd to factory settings. Reset it and report if it helps not.
Jul 29, 2009 | ViewSonic VP930b 19" LCD Monitor
Hp pavillion mx70 stopped showing red, etc
Right-click on any open space on your desktop. Click on properties and the Display properties will come up. Click on settings and make sure the resolution slide is all the way to the right. And Color Quality is set to 32 bits on the small window.
Jan 01, 2009 | HP Pavilion MX70 17" CRT Monitor
Screen flickers for about 20-30 seconds sporadically
Try looking at the LCD screen at a sharp angle to see if ghost-like video can be seen during the 'off' time of the flicker.  If video is still present even though not that visible, then either the backlight or its power supply are failing. The color problem could also be caused by a backlight lamp that is not ionizing completely.
Dec 14, 2008 | Acer AL1912B 19" LCD Monitor
Smearing of colors
I have a red tint on the left side of my display at all times. also red smear after any white boxes in display. Has anyone else had this problem?
Feb 19, 2008 | Planar WS231 23.1 in. Flat Panel LCD...
No video display
It is the problem of video amp. ic plz chage it.If only red colour is miss then check red driver transistor and cable
Jan 12, 2008 | LG Studioworks 45 14" CRT Monitor
Gateway EV 910 19" CRT Monitor Logo
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
