Question about Maxon HCB-10C CB Radio
Why Can i not talk to anybody but i can hear them
I have a Maxon Cb radio which is a moblie unit and i like being able to listen to everybody but i would like to be able to talk to them to. I have the same problem for my Midland 40 cannel emergency cb transciever. plz help!!!!!!!!
  • olbanjoe Nov 12, 2008
    I don'thave a manual. is there anyway to go onlineand look at one for it. Please expalin on what you mean by mode???
  • olbanjoe Nov 16, 2008
    I still can't get it to work. Thanks for trying though. I did what the book had said. I did it for both of my cb radios. I turned the squelch up just a little more so that it was quiet but so i still could hear the people. The only thing is is if somebody is at my house and they have a walkie talkie or moblie cb radio, i can talk to them just everbody else i cant talk to.thanks anyway. If you have any other suggestions plz post.
  • 85 Answers
Posted on Nov 12, 2008
  • 85 Answers
Check your manual on wich channels are shortwave and wich are for going the distance.also what mode are you in
Posted on Nov 11, 2008
My Maxon 30 cb want pick up signal when i want to talk
throw it away and get a real radio.I have a maxon 45 that I am trying to repair for over three years and Every time I come close ,it not the problem.Radio is to old just save it for parts or junk it but get a new one.
Jun 17, 2014 | Radio Communications
MAXON MCB45W will not recieve
I have one that doesn't transmit between the two we could have one radio but who's.. you should try to tune the receive cans but with no schematic you can't because if you turn the wrong one you could kill the radio. I would buy another radio like a radio shack trc - 503 or something in that line if you're into small radio's. Some of them can be opened up to talk like a big radio.
Feb 21, 2014 | Maxon MCB-30 40-Channels Base CB Radio
Can't talk to anybody, but can hear them just fine.
Could be a few things.One as simple as a bad soilder on the board or your voltage regulator could have went out. If you take the top cover off and talk in the mic and its starts transmitting then you have a bad soilder to check the regulator is a little harder and not for just anyone to do.
May 06, 2010 | Cobra 25 WX-NW-ST 40-Channels Base CB...
ICAN HEAR EVERYBODY BUT I CANT GET OUT I SWITCHED MIKS AND STILL CANT GET OUT people can hear me but when they talk to me all i hear is static
You said that you can hear everybody and then you said all you can hear is static. Which is it?
If you can hear everybody and you have switched to a known good mike, then you either have a bad antenna or you have a bad final amplifier caused by a bad antenna or by having transmitted at sometime without an antenna at all.
May 27, 2009 | Cobra 29 LTD CB Radio
I have a Maxon handheld cb - it squeals when keyed can not talk.
sounds like you are getting a feedback squeal.. try taking a wire and attaching to you handheld and grounding it to something.. that might work.. i know i have to have my mic on my cb grounded to my radio or i get a feedback squeal...
Jan 02, 2009 | Maxon HCB-10C CB Radio
When I Press the mic to talk, others hear me key down, but no sound is transmitted
Hello lummox30,
Check you mic first to see if it is indeed working. Then if it is the below advice is applicable.
It sounds as if your TX audio amplifiers might be malfunctioning or the TCXO might be bad. If you have a background in Electronics I would suggest that you open up the unit and using a dummy load on the antenna check the two TX audio amps to see if when you key the mic and speak into it the amplifiers are amplifying your voice and sending it to the modulator. If the problem is not amps or the filters in between the amps, the modulator and the VCO buffer are suspect. If the TCXO is being modulated I would check the PPL IC and the Drive amp to see if the modulated signal is getting through. The last two checks I would perform are on the final amp and the TX switch prior to the antenna jack.
If you do not have a background in electronics, still check your mic, but the rest of the above advice can be done by a qualified Radio Technician.
I hope this helps,
Thank you,
Shuttle83
Oct 01, 2008 | Maxon MCB-30 40-Channels Base CB Radio
Maxon model 27SP Handheld 40 channel CB
well it appears to have a BNC connector, so that shouldn't be hard at all.
Jun 05, 2008 | Maxon HCB-10 40-Channels Handheld CB Radio
Earphone/mic for Maxon 27MCB radio
I recall the combo unit as I used to sell them. I am about sure they are no longer avaidable. You never know, you might see something on ebay/auction sights that might be to your liking. Good Luck.
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Maxon MCB-30 40-Channels Base CB Radio
Maxon MCB 10 A
I'm not sure about your particular model but many CB radios use the microphone push-to-talk switch to kill the speaker while the radio is transmitting. If you don't have the correct microphone or if the cord has a broken wire it can cause the radio to have no sound. Another possibility is that the speaker is bad. There is probably an external speaker jack on the back of the radio. You could try plugging a different speaker or even an earphone in the jack to see if you get sound there.
Mar 07, 2007 | Maxon SP-100G (4 Channels) 2-Way Radio
Maxon HCB-10C CB Radio Logo
307 people viewed this question
Top Maxon Radio Communications Experts
Steve
AnyMHz.com
AnyMHz.com
Mike Charette
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
