Question about HP OfficeJet 6210 All-In-One InkJet Printer
6210 printing bottom half
I have the same problem, any luck in finding a solution?
    Master:
  • 638 Answers
Replace the cartridges.or the ink in the cartridges is getting blocked from the upper side.clean the cartridges.
Posted on Nov 14, 2008
Carriage jam print cartridge stalled HP 6210 Officejet. It started all of a sudden and I can't fix it
Press "ON" till green lite appears. The display will indicate "Initializing..." and then lift upper half of the printer to access cartridges. Cartridges should move all the way to the right. If they don't, inspect the carriage belt for any obstructions.
Nov 06, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Prints only top half of photos on top half of
I suggest that you go into the printer properties section on control panel. There Will be a section which allows you to tell the printer the type of paper, size desired, orientation of photo to horizon and etc. There is also likely a selectable setup procedure on the printer's own display to do the same... It sounds like a basic setup format issue....
Apr 02, 2010 | HP OfficeJet 6210 All-In-One InkJet...
I can't cancel a document on my hp 6210, so it won't let me print. I shut down my system in the middle of printing yesterday and it won't work now. please help
Suggestion. Leave the printer OFF.
Power up the PC and when it is set to go, look at the bottom right side of the scree and see if there is a small printer icon. If there is, then double click on the icon.
This opens the print queue. With the print queue, highlight the print job that is causing the problem and then cancel it.
Don
Dec 03, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Pictures not printing but half
cartridge gone dried, expired or used non standared ink
Oct 31, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Bottom of fonts is missing
Try to check the print preview of the document your trying to print.
Aug 03, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Upper half line missing
http://h10032.www1.hp.com/ctg/Manual/c00238458.pdf
manual here in link
sounds like the ink cartridges need to be aligned and cleaned there is an alignment button or in software for this
Apr 17, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Lowest part of every line won't print
Even though your cartridges are newish it sounds like some of the nozzles are blocked. If you go through the menus on your printer and hp driver on your machine and try to find something like a nozzle check (all inkjets have them) and see if the graph prints out perfectly. If there are any gaps (particularly at the bottom) then you have blocked nozzles. These can be fixed usually by running a few printhead cleans which can usually be found in the same menu as the nozzle check.
Feb 11, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Lightning Strike
I was unsuccessful in finding any parts for your printer but I did find some pretty cheap on ebay. It might even be worth looking on there for broken printers for parts. Here is one of them that I found that right now is at $24.99 http://cgi.ebay.com/HP-OFFICEJET-6210-ALL-IN-ONE-PRINT-COPY-SCAN-Q5801A-ABA_W0QQitemZ230165068772QQihZ013QQcategoryZ70824QQcmdZViewItem
Aug 26, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
Ben Johnson
