Question about Vizio L32 32 in. LCD HDTV
Goes off suddenly then restarts a few seconds later
This has happened several times in the past month or so.  Now it has gone off completely.  Yellow/Green power light now flashes wildly between yellow and green, but TV will not come on.
  • Anonymous Nov 20, 2008
    how much is the board?
  • Lou Labetti
    Lou Labetti May 11, 2010
    Does the LED (TV Screen) power up at all?
  • 104 Answers
You need to replace your main board.
Posted on Nov 15, 2008
1995 dodge van stalls. Then will restart later. Seems like an ignition shut off?
It could be an overheading situation with the ignitor coil or the spark arrestor. I have seen this on Chevy Vans as well.
You won't see smoke, as it will just overheat internally and create a break in the electric connections.
Sep 06, 2016 | OEM 1995 Dodge B2500 VAN Radio / CD Player...
What is the yellow flashing light
In the cross-sections, when there is a yellow flashing light "a driver may proceed through the intersection or past the signal only with caution."
Mar 21, 2013 | iBuyPower Gamer Computers & Internet
Temp gauge goes up to hot then back down only a few times
This is a sign that the thermostat is sticking shut and then opening after the temp gets past a certain point. If the heat gauge goes to high and then drops down suddenly, this is the likely culprit and you need to replace the thermostat - again.
I have had them arrive from the parts store and be defective.
May 18, 2017 | 2001 Pontiac Aztek
To: crg_912: 2001 XK8 V* Convertible with 28500 miles car stalls then ABS warning and Traction Control System warning comes on.Also, Complete Enine Failure message' Car goes into limp home mode. When...
Having a restoration shop and running several newer Jaguars I have seen similar situations. Intermittent multiple errors such as these can be caused by a low battery (or corroded connections) that "fool the computers". Also had a '99 XJ8 VDP have exactly the same issues over several months. Issue was a manufacturing fault in the sensors on the throttle body that caused the "limp home" mode - usually in stop and go traffic. Jaguar had an inspection and recall on the throttle bodies but that vehicle had gone through 3 different Jaguar dealers for service and none looked at TSB/Recall or performed the necessary checks on the throttle body. Tried cleaning the throttle several times (per Jaguar TSBs) but no change. Had to replace throttle body & problem solved (over 30,000 miles since then). Recommend making sure all air connections to throttle are clean and open and cleaning the throttle area to see if that helps.
On newer Jaguars (and other Al bodied cars) similar problems occur when the "ground" connections to the body become poor (usually through corrosion but sometimes through collisions). Connections may look perfectly normal but have high resistance. Careful when working with the connections - the posts are usually very loosely fastened to the bodies. Good luck.
Aug 31, 2017 | Jaguar XK8 Cars & Trucks
My playstation 3 console wont turn , when i try to it stops and a blue then yellow light flashes , what can i do to fix this.
source: http://www.edepot.com/playstation3.html#PS3_Model_Differences Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 10, 2010 | Sony Playstation 3 (PS3) Console
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
  • Beeps Three Times
  • Red Light Flashes
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
Yellow light of deth
  • Beeps Three Times
  • Red Light Flashes
2007 Tahoe LTZ wiper washer gone crazy
Try replacing the wiper module.It is the part on the wiper motor that does all the functions when you push or turn on the wipers.To replace it you remove the cover from the wiper motor and you will see the circuit board.you can just pry it out with a small screw driver.Most dealerships have these in stock.When you replace it make sure and use a silicone sealer on the cover to keep the water out.Good luck.
Dec 07, 2009 | 2007 Chevrolet Tahoe
Vizio L32 32 in. LCD HDTV Logo
295 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
