Question about Whirlpool Ultimate Care II GSQ9669L Top Load Washer
Our Whirlpool washer won't drain
Our Whirlpool Ulitmate Care II washer won't drain. There was a leak so we took the washer apart and found our daughter's sock in the water pump. After putting it all together we did a little test run with water only and it worked fine. Then we tried a small load and it seemed to do everything normal BUT draining the water. Could it have burned out our main drive motor? ANY help would be greatly appreciated. Thanks, Andrea
  • g vox Nov 12, 2008
    Thanks again for your response, the washer is spinning, but not draining. Any ideas? Thanks!
  • kkisby Jan 20, 2009
    My wife ran a small load of clothes. When done I opened the machine and found water still in the drum. I removed the pump and ran with my drill and pumped fine. Is the pump always running when the motor is running? Even during agitation? If not, what "locks the pump in" so it pumps? The timer? I'm not absolutely sure about the model, but is an Ultimate Care II Gold with 27 cycles, " commercial quality. There is no tag on unit. Any help would be appreciated.
    President:
  • Whirlpool Master
  • 2,651 Answers
This machine has the pump directly atached to the pump assy, so if the motor is runnning your pump will drain water. more likely is that when you put the unit back together perhaps you didnt plug the lid switch assembly bak in. if there is no lid switch detected the unit will not drain or spin and when it gets to that mode it will simply stall out. no noise or anything. will fill, agitate but not spin and/or drain/ check the lid switch!
Posted on Nov 11, 2008
  • Ron Coons
    Ron Coons Nov 13, 2008
    well , if the machine is spinning, then motor is turning, and the pump is attached directly to the motor, so you either have another sock ( or other debris in pump), the bearing onthe pump has broken and no longer pumping, or there is something stuck in the drain hose/line)
  • Ron Coons
Whirlpool ultimate care heavy duty leaks underneath, not agitate or spin. only humms and fills up
Again!! Any washer that does not drain has a bad Drain Pump. Very Common. I see this in 40-50% of the problems. Replace the drain pump and your washer will be very happy
Jan 19, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a whirlpool ultimate care II washer. When I start the washer, water pours in but does not fill up the washer. The water immediately drains away. Its not leaking out of the washer. I think the...
This issue calls siphoning effect. It happens when the drain hose was somehow lower or not stand vertically. It causes no air pressure column in the drain hose to keep the water out. Check the drain hose and make sure it is high enough. Try to hold the drain hose straight up and see if it is happened before having further inspection.
Oct 05, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
My whirlpool ultimate care II is leaking water.
Use the video to see how to disassemble the washer to check for the source of the leak.
The leak is probably in the drain pump.
http://appliancejunk.com/forums/index.php?topic=5191.0
Jan 24, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Leaking washer drain pump
Yes, the drain pump is a common leak area.
2 clips, 2 hoses and it pulls off.
If it has leaked for a long time you will have to get aggressive to get it off.
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Washer LSQ9645KQ0
The washer has the sound both times but not all the time. I THINK we found all the pieces but now that you mentioned it, perhaps not. Are you thinking there may be a piece lodged somewhere and making that noise?
di_marie60
Aug 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer is leaking from underneath....
lean washer back against wall ck pump under front in center for leaks or dark gray area in pump face remove hoses remove clamp top and bottom of pump slide forward off shaft
Jul 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II GSQ9669L Top Load Washer Logo
447 people viewed this question
Dan Webster
Dan Webster
Sal De
