Boot a Tyan Mobo from a SATA AID
I have an old system that i am trying to turn into a server. I installed SME server onto the SATA RAID that was that was controlled by a SA3114-41R controller card (PCI) from SYBA. The install seemed to go fine. The install disk was a CD and was in a standard IDE CD drive. Nothing else was connected to the IDE controllers. At first the installer (anaconda) did not see the RAID but it did offer to install drivers for various hardware it found. I sellected the SATA controller and off it went. After setting up the RAID 5 disk and installingg the os it gave the remove CD and rebootscreen. I removed the CD and rebooted the system. The bios does not recognise the OS and will not boot from it. I have looked over the BIOS setup for a fix but have not found any. Booting from SCSI does not work.
The system is:
Tyan Mobo Tsunami S1846 ATX
SATA Controller SYBASA3114-41R
4 x 250 gig Western digital drives in RAID 5
3 Suggested Answers
  • 9 Answers
SOURCE: Slow transfer from SATA II
It appears you have made an error with the RAID configuration. RAID 1 is mirroring and requires an EVEN number of drives unless one is a hot spare. Also, RAID 1 is for redundancy and is slower than a single drive or RAID 0. Verify your RAID configuration and make sure you have RAID 1 and not RAID 0 or RAID 5 which can be an even or odd number of drives.
Posted on Nov 17, 2008
  • 10406 Answers
SOURCE: Boot from non Dell raid controller
Check the Boot Sequence again -- if there are any "SCSI" devices listed, enable them, and make your CD-ROM the "primary" boot-device (so that you can install Windows) and make this "SCSI" device the SECONDARY boot-device, and disable the internal hard-drive, so that it won't be used as a boot-device.
Posted on Dec 27, 2009
Having trouble booting two Raid-0 discs on Asrock Z77 Ex4 UEFI
RAID implementations will vary from controller to controller, and even from bios to bios revision or version for the same controllers.
You should "image" the raid on the old board, then delete the raid on the old system.
In the new system, you need to treat these drives like they are new, blank hard disks. Any partitions will need to be removed, and the RAID created on the new board. Once this is done, you can use your partition imaging software to drop the data back onto the new RAID partition. Seagate I believe has imaging software available in Seatools, or you can use something like Acronis True Image or GHOST.
May 16, 2012 | Computers & Internet
Enable RAID system
use this guide, this is fo the embedded sata raid controller that comes standar with the ml150 g5.
Enabling SATA RAID functionality in the BIOS Setup Utility: 1.Boot the server, and then press F10 to enter the ROM-Based Setup Utility (RBSU).
2.Go to the advanced tab.
3.Enter the IDE configuration or hard disk configuration.
4.Change the ATA/IDE configuration to enhanced or SATA controller 2 enhanced (if not available then use enabled mode).
5.Configure SATA as RAID or configure controller 1 as RAID.
6.F10 to save and exit.
7.Reboot the server.
8.During post f8 will now show up for the embedded SATA set up.
•Creating the RAID volume.
1.Enter the embedded SATA setup by pressing f8 during post.
2.Enter the array configuration utility.
3.Enter create array.
4.Create the raid volume as desired.
5.Save and exit.
i hope it helps you!!!
Aug 11, 2010 | HP ProLiant ML150 G5 Server
Gateway e-9425r was setup to boot via PXE. I want to boot off a raid. Have 2 250gb sata drives in system. Loading raid driver from gateway site on floppy. Windows install and bios don't detect raid or...
Copy RAID driver to mini diskette.
Boot server using Windows Server 2003 CD
The moment you see the blue setup screen press F6
After the setup runs for a little while it will ask you if you have any additional drivers you need to install
Then insert your mini diskette with the RAID driver and respond to prompts to load it.
Windows should no recognize the RAID controller and let you complete the installation.
Aug 10, 2009 | Gateway Computers & Internet
Trying to create a server using the ASRock k7vt6 mobo
turns out the RAID enable in the bios is also used to enable the SATA. but this doesn't mean you have to use RAID to use SATA drives! there's a separate bios to configure the RAID that you can access after the initial boot screen by pressing tab. here, you can delete an existing array or create a new one. deleting the array makes the motherboard see both drives separately, like I wanted. problem solved :)
Aug 01, 2009 | Asrock K7VT6 (K7VT6 RAID) Motherboard
Boot problem with IBM xseries 206 - SCSI Drive and SATA drive
Refer to user's manual how to set the boot order in BIOS.
Jul 17, 2009 | IBM eServer xSeries 206
Asus P4S800D-X mobo and sata hdd problem
I believe you need to load in the SiS 180 RAID controller for this MOBO during the Windows Install.
Do this by loading the driver onto a floppy and pressing F6 when told to do so by the windows install.
Mar 20, 2009 | ASUS P4S800D-X Motherboard
Slow transfer from SATA II (IDE) drive to 3 SATA II Drives configured as RAID (1). Drives wouldn't format until we installed the OS onto the RAID -- but it wouldn't install completely. We boot from the...
Nov 17, 2008 | Computers & Internet
Tyan S5396 and Thermaltake 1500W
tyan i5400xt.. to test for ground.. pull the board from the chassis and test with a different known good power supply
if the boot works... then you have a power supply issue...
does the board have a post code lighted signal ???
if so.. a bad power supply should goto FF error code
verify you have enough power on the cpu rail with your power supply specifications also
be sure you have all cables 4 pin 8 pin and 20/24 pin connections done correctly.. lastestly check if the board is touching the chassis edge anywhere... could cause a ground
also take and loosen all the MB screws from the chassis.. just let it hang there this will test the grounds needs the screw connections
mark@omces.com
tyan specialist
Oct 31, 2008 | Tyan S5396A2NRF Dual LGA771 XEON5000 5100...
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
