Question about Haier XQG50-11 Front Load Washer / Dryer
Wash machine says E3
I washed a heavy blanket in the machine and it was really rocking around. It stopped about halfway through the cycle and beeped E3. It runs and rinses but won't spin quickly. I am in China. I don't know the exact model. It's just a small, basic washing machine. It starts with an X and ends in a 10. I can't remember the rest b/c I'm at work right now. Can you help or give me a website to download the manual? I can't find one. Thanks! Maureen
  • 43 Answers
Not sure where you can get a manual but sometimes blankets produce a lot of fluff while washing maybe the pump filter needs cleaning out the machine will not reach speed with too much water in it
Posted on Nov 11, 2008
Our miele w911 washing machine keeps stopping in the main wash cycle - red light above the tap symbol. What does it mean?
check that the water flow solenoid is operational and not blocking of the spray rinse requriement
Mar 23, 2015 | Miele Washing Machines
Kenmore 400 washer
Try redistributing the blanket evenly around the agitator.
Jun 11, 2017 | Washing Machines
LG fuzzy logic top loader leaves black marks on white. Happens when doing a large wash-eg; blanket -it looks awful. I'm thinking the insides might need cleaning? How is this done and with what product
If this is moldy looking you should use 1 cup of bleach in the drum with no clothes on the longest wash cycle with the hottest water. But I believe this is oil from the drive train and the seals on the bottom of the drum are going bad. When you wash something heavy like the blanket, it leaks.
Nov 25, 2013 | Washing Machines
Washing machine stopped and door opened and says E3. please help. machine is a bosch wae....
The machine identifies and indicates some operational errors through a series of beeps.E3 is also listed in that beep.the meaning of e3 is nothing but it is telling to call the service engineer.This error signal is due to Thermistor open/short.Thanks for your question.
Jun 19, 2011 | Washing Machines
E3 error
looks like a heater failure it statrs to heat at about this time into wash mode.
Nov 13, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
My whirlpool duet washer spins but cloths still damp after full cycle stop.
I have the same washer and it will do this if I have put a load of clothing that is not even in weight for example I washed sheets with a heavy blanket and I then had to run the Drain Spin cycle. Hope this help
Sep 06, 2009 | Washing Machines
Ariston front loading washing washing
Believe it or not.....its almost always the cloths ( heavy blankets) that one places inside.
TRY:: In the spin cycle if the load is unbalanced the TUB will rock and make that "loose drum out of alignment" noise. STOP the machine and open the door ( IF IT IS A TOP LOADER ) realign the cloths (heavy or more then one blanket) so that it is EVENLY spaced through out the tub.Start the machine again.If it does it again, stop the machine and REALIGN the cloths (blanket !!) again.
p.s. there is a simpler way of doing it but I don't want you to loose your hand in the process.
Aug 31, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Maytag heavy duty top loading washing machine stopped and won't restart
remove console screws behind timer is lid switch if you have a volt/ohm meter with washer disconnected ckd switch operation also there is a fuse on same assembly ck it
Aug 17, 2008 | Washing Machines
Stopped operating in the spin cycle
With a heavy blanket you probably have an out-of-balance condition which doesn't let the machine spin out and drain. This would keep the door lock from opening. Try hitting the Stop button twice. This should cancel the cycle and let the door lock open after a little while. Then either redistribute the load or add some items and run a Spin and Drain cycle.
Mar 05, 2008 | Kenmore Elite 45986 Front Load Washer
Open Questions:
See all Haier XQG50-11 Front Load Washer / Dryer Questions
Haier XQG50-11 Front Load Washer / Dryer Logo
369 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
