Question about Kenmore 24 in. 17602 / 17604 / 17609 Built-in Dishwasher
Power going to dishwasher but nothing happens??
I just loaded my dishwasher and pushed Start and nothing happened. Noe even a light on the control panel. My husband checked the breaker and pwer coming in to the dishwasher. I did notic there is some standing water in bottom of tub. Anyone have any ideas??? Thanks bunches! Gina
  • 1 more comment
  • Kristi Wiley Nov 26, 2007
    Could you please tell me where to find the thermal fuse?
  • dgomez Jan 07, 2008
    same exact problem
  • ldwalker Jan 15, 2008
    I think we have the same problem. I can't get the 1 1/2 year old machine to start, but the cancel button works. It almost seems to work too well. It takes several minutes (5 maybe) for it to stop. I had a hard time starting it a couple of days ago, but finally got it going (the buttons have always been difficult to push). It worked normally for a few days, then last night wouldn't start at all. Could it still be the thermal fuse? Is it possible that the fuse could go out after only a year and a half?
    President:
  • 878 Answers
Gina, you probably blew a thermal fuse that sits on the control board. Easy fix. Have your husband first check the wiring to the dishwasher. Remove the toe panel and make sure the wire nut connections are good. If that is ok, he will have to remove the inner door screws to get to the control board. Lift out the inner door. Remove the control board cover, it just snaps off. He will see the thermal fuse on the upper right side. I will attach a photo of what it looks like...Catriver...post back
Posted on Nov 05, 2006
Gina's discription of the problem was right on. And so was the solution. I didn't even need my husband who was working nights and sleeping. I just did it myself. Thanks!! --- Jennifer
Posted on Sep 03, 2007
To Catri. I have a 3 years old Kenmore built in dishwhaser Mod.15762000.In the last year the termal fuse has been replaced 4 times wires and all.Sears is not interested to do anything aboutit.I think the solution would be a heavier duty thermal fuse. I think a class action suit would wake them up as this problem is to common.They sould try to do something. Thank You. Joe.
Posted on May 23, 2007
Catriver,and anyone else. I had the exact problem described and I did as you said.Problem solved!Thank you very much.you saved me a service call from sears.
Posted on Feb 11, 2007
Kenmore dishwasher will not start
The most probable cause is the door latch (or switches in the latch) are not working right, and the controller thinks the door is open, even though it is closed.
Aug 13, 2012 | Kenmore Dishwashers
Push start button the lights go on and nothing happens
theres a start relay in the main control panel inside that is freqently going out!! you can look for a relay however is just as easy to change the control panel circuit board
Jan 13, 2010 | GE 24 in. GLD5560LSS Stainless Steel...
My GE dishwasher, when i push the start button nothing happens.
1)check any fuse had gone in electronic board.
2)check the input voltage to pcb.(normal)
Jan 08, 2010 | GE 24 in. GSD4000J Built-in Dishwasher
Just won't work!!
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
I would also advise to check the door switch as well. make sure the wires are connected to the switch and it is working. replace if found to be faulty.
Check the control as well. if the control is malfunctioning as you stated, this will be the logical solution here. replace the control board.
May 29, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Diswasher stopped working
There is a thermal fuse on the controller that commonly goes out. If you take apart the panel, and see the computer part, there is usually a part clipped on the side with 2 wires on it. When that goes out, it acts like there is no power to the unit. Very easy and in-exspensive to replace if that's it. It's pretty common on those. Good luck
Feb 15, 2009 | Dishwashers
Nothing is happening
I used the eternal last resort: Banging repeatedly on the control panel!
Jan 30, 2009 | Kenmore 24 in. 16259 / 16254 / 16252...
Miele g898 sci plus won't start (type HG01)
Button wont stay in - lights up but nothing happens. Machine three and a half years old.
Dec 23, 2008 | Miele Premier-Plus Built-in Dishwasher
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
there is a fuse in the washer that needs to be replaced reply to me and will walk you through it
Dec 31, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Open Questions:
Kenmore 24 in. 17602 / 17604 / 17609 Built-in Dishwasher Logo
534 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
