Channels keep changing
At first did it every 20-30 mins, progressed to every minute or two, now continuous switching..............please..........
  • 927 Answers
Good Day;
Replace control button board, or unplug and use remote if possible. Big Irish.
Posted on Nov 11, 2008
Machine won't recover, it gets stuck on "clearing in progress" Also won't vacuum, it says that "pressure exist press any key to continue" Your help would be greatly appreciated
I had a similar problem with a Robinair 17800b. The machine got stuck in Clr or (Clearing) while changing from R-12 to R-134a. If the tank (R-12 or R134a) does not have at least 10 pounds of refrigerant in the tank before you change to another refrigerant, the machine will stay in the clearing process. I called tech support and they walked me through a process that resets the machine. The reset involves entering a code while in r-12 mode, then removing all hoses and switching the switch to R-134a mode and entering another code. The call to the tech line took about 5 mins. The number I called 1-800-822-5561.
Aug 18, 2015 | Robinair Cool Tech 34700Z Recovery,...
Washes indefinitely - water does not heat.
perhaps a call to a service man locally will be your best choice . none I have ever worked on had heating as an option .
Jun 02, 2015 | Bosch Washing Machines
Bosch nexxt 500 elec dryer has no heat to it
There is a switch located on the duct from the heating element. Which you are not able to reset, you have to replace it if it's defective. Do a continuity test on it and if there is no continuity then the switch has to be replaced.
Jan 04, 2012 | Bosch Nexxt 500 Dryer
It keeps changing channel with out pressing any buttons after about 5 mins it changes again even when trying to watch a dvd
Your switch is dirty it has already a resistance try to apply a contact cleaner in the switches.
Dec 06, 2010 | Toshiba 32A33 32" TV
Linksys BEFW11s4 Wireless Router Security Issues
Try changing the router's channel (play around with 1, 6 and 11) and see if it works.
Jun 28, 2009 | Linksys BEFW11S4 802.11b Wireless...
LG WD-8074fhb
Your problem is either in the control board or the water level switch.  The computer can't tell if the water has drained or the control board is stuck in the 8 minute drain cycle.  Recommend pulling the plug and wait 5 minutes to reset the computer.  If the problem persists, it will require an LG experienced tech to see what's going on.
Mar 14, 2008 | LG WM1814CW Front Load Washer
I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Feb 27, 2007 | AEG 24 in. Favorit 60870M Free-standing...
SPECIFIC FIX FOR GE 32GT660
I have the same problem, except that it would turn on by itself and then start changing channels. I had a can of compressed air and sprayed the button areas to see if there were sticking. It worked for a coupe of days, then started happening again. So I searched the web and found a response to a question someone else posted and the ensuing reply "most likely you have one of 2 things going on one is the foam between the buttons and the switches or you may have a switch getting leaky and would need replaced" Looks like I may have to taking the cover off and find some type of electronic cleaner, or replace the buttons. I find it odd that I got hits for the same issue with the same model. hhhhmmmmm?
Nov 21, 2006 | GE 32GT660 32" TV
ok, let's try the simplest things first.... unplug the tv from the wall, and remove the batteries from the remote. wait about 5 or 10 minutes. reinstall the batteries and plug the tv back in. try it again. actually since you said you tried another remote, you can skip removing the batteries from the remote. if it still does it, try unplugging the tv overnight. if it still doesn't work right then, you have a processor problem, and need to have it looked at by a service tech.
Jul 07, 2006 | Toshiba 36A40 36" TV
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
