Question about Garmin eTrex GPS Receiver
Problem with USB connection Garmin Etrex Legend Cx
I have a Garmin Etrex Legend Cx that I use mostly for geocaching. It powers up normally and works fine when I am out hunting for caches.  For several months I have been using Garmin Communicator software on my PC (Vista) to send cache sites from my PC to my GPS.  Suddenly 2 days ago I encountered a problem.  When I hook up my powered-on GPS to my computer using a USB to Mini USB connector the GPS turns off immediately and wont come back on until I disconnect the connector.  I have tested the connector on my digital camera and on my Garmin Nuvi from my car and everything works just fine.  Plese let me know if anyone else has experienced this problem and might know cause and/or solution.  Thanks
  • 2 more comments
  • Tahoerob Nov 14, 2008
    No one had a clue how to help me with this, so I Emailed Garmin tech support.  The tech had me try a few things and then determined it was probably a short in the GPS.  Luckily it is still under warranty.  I sent it to Garmin today and am hoping for the best.
  • Anonymous Feb 05, 2009
    My etrex vista cx does the same thing
  • Anonymous Feb 25, 2009
    I have exactly the same Problem.
  • phillyofish Mar 14, 2009
    I have the same problem with the Legend Hcx updated mapsource on the computer then unit just switched itself off.
  • 638 Answers
SOURCE: Geocaching with Garmin Etrex Legend CX
The preloaded maps are VERY generic, mostly major highways. They are not useful for geocaching.
The good news is that you can download free topo maps created by a very generous Canadian soul, Dale Atkin. The maps are free but donations are accepted. He is also working on US topo maps. I've used Ibycus and Garmin topo maps and prefer the Ibycus version.
If this solves your situation, please come back and rate our answer. Thankyou.
Posted on Jan 08, 2009
My eTrex Legend cx beeps constantly when turning off. The only solution I have found is to remove a battery. Any ideas?
I have the same problem. The unit is only 1 week old and I have used it maybe 5 times. The problem started a couple of days ago when I removed the USB connection from my Mac without ejecting it first. I think this might have screwed up the microSD card. I noticed that if I remove the microSD card the unit turns on and off normally. but is I have the microSD inserted, it turns on oK, works (apparnetly) Ok, but freezes with a constant beep when I turn it off.
Will try to reformat the card (any idea how to do that on the unit itself?)
Aug 18, 2009 | Garmin eTrex Legend Cx GPS Receiver
My etrex legend develops a verticle black line during use and then shuts off. removing and replacing the batteries gets the gps restarted but then the problem repeats
Mine also was doing this while geocaching. I downloaded and installed the newest firmware(v3.90) using the WebUpdater from the Garmin site and it fixed the issue for me.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Aug 12, 2009 | Garmin eTrex Legend GPS Receiver
Won't acquire satellites
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} make sure you are in view of clear sky, large buildings, trees and even clouds will make it harder to track satellites.
May 19, 2009 | Garmin eTrex Venture Cx GPS Receiver
Dec 27, 2008 | Garmin eTrex Legend Cx GPS Receiver
Garmin Etrex Legend Cx - no signal
Have you tried upgrading the unit's software. Go to Garmin.com and download the latest software for your unit. This will sometimes fix satellite reception problems.
Sep 28, 2008 | Garmin eTrex Legend GPS Receiver
My Garmin Etrex wont turn on on batteries but it works fine on external usb power.
I have the same problem. The unit works until I connect it to whatever computer via USB (Mac or PC). The screen blanks out as soon as I plug in the USB cable. I have to disconnect the device and only then I am able to turn it on again. That started after Firmware update from V 2.90 to 3.00 . I am not sure this is causing problem. What about the firmware versions of your devices ? Are they all on the latest ?
However, does anybody know if there is a way to go back to firmware version 2.9 if it is not possible anymore to connect the device to any computer (evtl. through putting data on the microSD card ?).
Thanks,
Martin
Jul 04, 2008 | Garmin eTrex Legend Cx GPS Receiver
Will not turn on
I contacted Garmin and they had me remove the microchip inside and see if that would fix the problem. It did not. So they instructed me to send it back in for repair. They gave me a return number and then ended up replacing the unit with a new one. My unit was under a year old so it was no charge.
Jun 15, 2008 | Garmin eTrex Legend Cx GPS Receiver
Wet garmin
Does the unit power up when attached via USB cable to your PC?
May 11, 2008 | Garmin eTrex Legend Cx GPS Receiver
Won't give me the correct location
you should search for mapdate (kaartdatum in dutch) and select WGS84, it's a preference all geocachers use
Nov 27, 2007 | Garmin eTrex Legend GPS Receiver
Garmin eTrex GPS Receiver Logo
377 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
