I have a Laserjet 3380 that keeps jamming at the fuser and is not fusing the toner to the paper well. I have an old Laserjet 3330. They look pretty close to the same machine. When I look up the part numbers for the fuser, they show different numbers, but I was wondering if they might be interchangeable. The older 3330 has a broken scanner, but the print engine seems to be fine.
13.20 PAPER JAM CHECK REAR DOOR
Media stopped in the paper path during power on
or when the top door was closed.
Action:
1.
Open top cover and remove toner cartridge. Remove all media in the
paper path, and then re-install toner then open and close the top cover.
2.
Open read door and pinch blue latches on fuser and pull it out.
Inspect the sensor flag for correct movement and any paper obstructions in the
fuser rollers. Re-install fuser and Confirm rear door closure.
3.
Remove tray 2 and confirm paper is not jammed in the pickup area.
Confirm paper size adjusters in the tray are correctly set for paper being
used. (Do not set back paper stop to ANY)
4.
Replace any defective sensors or flags
Hope this helps. Please keep us updated and
remember to rate this answer.
TF
