Question about Nintendo DS Lite - Onyx
Nintendo ds touch screen
The touch screen won't respond to touch even during recalibration,I have tried cleaning it
  • Anonymous Nov 14, 2008
    my touchscreen won't respond so I can't even calibrate it.
  • shvlhed Nov 25, 2008
    my son's DS started doing the same thing today. you can use the abxy buttons & the toggle but the screen isn't responding
Actually, I didn't need to replace the screen. I removed & replaced the screen saver sheet & the problem was solved...
Posted on Nov 28, 2008
  • 103 Answers
All 3, your touchscreen is defective and must be replaced. If you can, you can order one at the well known auction site and replace it.
Hi. The touch screen on my wee girls touch screen has stopped working. Can I fix this myself or can do I need to send away?
You can try sorting the problem yourself before you decide to send it in to Nintendo.
Most DS touch screens stop working if there is dust, hair, sand etc gets under the frame of the DS. They stop working because the particles get pushed down on the touch scream making the DS think that screens already been touched and won't respond.
Get a toothbrush with straight bristles and with your thumb gently press down the touch screen along the frame, use the touch brush to clean under the frame but be vary careful not to press down too much as you could cause damage to DS.
If the screen still doesn't work then you'll have to send it in for repair.
Hope this helps.
Regards.
Apr 24, 2011 | Nintendo DS Lite Console
Touch screen is all over the place on Nintendo DS Console
It may need to be recalibrated. If you already know exactly what I'm talking about, and have already tried, then this sometimes happens with the DS. If not, start your DS without a game in either of the slots. then when you get to the screen where it says pictochat, download play, and all the other stuff, look at the middle of the bottom of the bottom screen. Press the tiny DS there. then touch the recalibrate button. Then touch the things it tells you to touch. All these steps can be done with the buttons, but use the touch screen to recalibrate. Hope this helped.
Feb 13, 2011 | Nintendo DS Lite Console
Most of my ds lite touch screen is not responding
try getting to the calibration menu with the buttons and calibrate if u can if not send it in to nintendo for repairs
Sep 21, 2009 | Nintendo DS Lite Console
Touch screen is blank
I am not sure which DS your daughter has. There is the DS original, lite, etc.
You can try recalibrating the touch screen, to do this follow these instructions:
http://www.nintendo.com/consumer/systems/dslite/en_la/recalibrate.jsp
If this does not help, you may need to send your DS in for service. The problem may be something with the hardware where only professionals should be performing maintenance on.
Give a call to Nintendo's 1-800-255-3700 (6 am - 7 pm Pacific, everyday) Customer Service number, or use their web form ( http://www.nintendo.com/corp/contact.jsp ) to contact them, and they can set up the repair process for you.
- Neal
Apr 27, 2009 | Nintendo DS Lite Console
DS Lite bottom touchscreen seems "stuck"
i think you should either get a new ds or tap the touch screen hard. if tapping the touch sreen harder does not work then that means it is time for a new ds.
Jan 18, 2009 | Nintendo DS Lite Console
Touch screen on ds lite does not work
I would buy new screens.I heard somebody on this site sells screens for $24.
Dec 26, 2008 | Nintendo DS Lite Console
Nintendo ds lite
First try to recalibrate the screen (start up the DS, and do the following--text from nintendo.com):
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Press the A Button when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button.
  5. Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button.
  6. Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves.
    • You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start.
    • Ifthe touch screen is not responding properly, hold the Nintendo DS at anangle so that you can see where the edges of the Touch Screen meet thehousing of the system. Look around the entire edge of the Touch Screenfor any foreign material (such as crumbs, etc.) that may be wedged inbetween the Touch Screen and the housing of the DS. Foreign material inthis area can cause the Touch Screen to work incorrectly.
If the screen still does not work, you need to buy a new touchscreen. Many vendors sell these, here's an example:
http://store.richspsxparts.com/nidslito.html
You will need a good tri-wing screwdriver to do this repair (don't buy a cheap knockoff--they will strip your screws). Try one like this: http://www.play-asia.com/paOS-13-71-1e-49-en-15-tri_wing-70-1fe.html
Then follow the step by step tutorial at:
http://www.instructables.com/id/Repairing-a-Nintendo-DS-Lite/
Dec 07, 2008 | Nintendo DS Lite Console
Touch screen problems
Hi penny_od.....The following excerpts has been extracted from the Nintendo Help Site. If you would like to view the entire document, please click on the URL below....Please update your post of any progress, whether positive or negative so that I may learn from this too.....good luck my friend. http://www.nintendo.com/consumer/systems/ds/trouble_screen.jsp#touch ============================================= Touch Screen doesn't respond or is inaccurate when touched * Be sure that you're using only the bottom screen of the Nintendo DS with the stylus. The upper screen is not a touch screen. * Use only licensed Nintendo DS styluses and screen protectors. * Unlicensed screen protectors can lower the sensitivity of the touch screen. If the problem you are experiencing started happening after you attached a screen protector, you may want to remove it. Please note that some screen protectors can leave behind a residue that may be difficult to clean. If you are planning on removing a screen protector that has been placed on your Nintendo DS, click here for tips on cleaning your screens. * If the touch screen is not responding when touched, or the accuracy of the screen is off, you may need to recalibrate the touch screen. Click here for help recalibrating the Touch Screen. * If recalibrating the screen didn't solve the problem (see above step), hold the Nintendo DS at an angle so that you can see where the edges of the Touch Screen meet the housing of the system. Look around the entire edge of the Touch Screen for any foreign material (such as crumbs, etc.) that may be wedged in between the Touch Screen and the housing of the DS. Foreign material in this area can cause the Touch Screen to work incorrectly. If there are any visible particles, please follow these steps for cleaning the screen. If the above steps do not solve the problem, your system will need to be repaired. Click here for repair information.
Jul 20, 2007 | Nintendo DS Console
Nintendo DS Lite - Onyx Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
