Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Shuts Off After @ 60 Seconds
We turn the TV and the screen displays the message: "Did you just change the lamp?" We've never changed the lamp or even unscrewed its cover (until yesterday). If we respond "Yes", get the message that the power will be shutting down in a few seconds; check to make sure the air flow is not blocked. If we say "No", don't get any additional message after the lamp question. Either way, the TV shuts off after about 60 seconds, and the yellow status light blinks. Hitting the re-set button re-sets the TV and we can turn it on again, but it will shut off again after 60 seconds. This is the second time we've run into this issue and we've only had the TV 17 months. The first time it happened was when the TV was brand new and although the repair place had it for three weeks, they could not re-create the issue. This is under warranty with Best Buy, whom I called two days ago, and was told it would be at least three working days until they could even coordinate with a local repair place for us. When I talked to the repair place to see if they could give me any ideas to try, they said it will be at least two weeks before they can get it in (and if this is the same problem as before, the TV will miraculously repair itself in between our home and their shop). We've cleaned the filter and removed the lamp and re-seated it. Per the repair person's suggestion over the phone, we unplugged the TV for 12 hours to see if it would re-set itself; "clear the memory" is what he called it. No luck with anything. Does anyone else have any suggestions that we could try here at home before sending it out again? Thanks much! It really is an awesome TV, but for the price we paid, I'd like to think it would work longer before breaking down....
  • 4 more comments
  • Melissa Bailey Dec 07, 2006
    Just wanted to let ya'll know how this turned out. The repair shop could not find anything wrong when ran it for a week and a half - just like the other shop that had it for three weeks last year.
    They brought it back to us on Tuesday, and as soon as we plugged it in, the problem showed up. The technician's had talked with Mitsubishi tech support, who told them it had to be related to where we have the TV, but the guy from our local shop explained that our set-up is ideal, therefore no-one had a clue what was causing it.
    So, to make a long story shorter, we ended up getting rid of the problem by plugging the TV directly into the wall, rather than into a surge protector. We've used two different surge protectors with this TV, and the problems only showed up these two times? Weird.
    Don't ask me why this resolved an "air flow" issue - our shop is contacting Mitsubishi to see what they can come up with - but so far so good; the TV is working beautifully. Now we have to come up with a surge protector that won't cause this issue - gotta have lightening protection!
    Just wanted to let ya'll know how this turned out. The repair folks could not find anything wrong when ran it in their shop for a week and a half - just like the other shop that had it for three weeks last year; they couldn't re-create the problem.
    They brought our set back to us on Tuesday, and as soon as we plugged it in, the problem showed up. The technicians had talked with Mitsubishi tech support, who told them it had to be related to where we have the TV, but the guy from our local shop explained that our set-up is ideal - therefore noone had a clue what was causing it.
    So, to make a long story a little shorter, we ended up getting rid of the problem by plugging the TV directly into the wall, rather than into a surge protector. We've used two different surge protectors with this TV, and the problems only showed up these two times? Weird.
    Don't ask me why this resolved an "air flow" issue - our shop is contacting Mitsubishi to see what they can come up with - but so far so good for us; the TV is working beautifully. Now we have to come up with a surge protector that won't cause this issue - gotta have lightening protection!
  • Melissa Bailey Aug 01, 2007
    Thanks, Phil!
    The repair guys never did figure out the root of the issue, although they even replaced two sensors that have been causing issues with the latest model of this TV, but it actually made the problem worse for us.
    We ended up invoking the Lemon policy on our service contract, and now have a totally different brand of television. So far - NO problems with this one! (Hear the sigh of relief?)
    I'm sad, because the picture on this Mitsubishi was better than any others I've seen - even the 1080P's that are out now, but what good is a beautiful image if the TV doesn't stay on! :>)
    Thanks again for your input, Phil. What's ironic is that Mitsubishi tech never did admit that this issue was anything they'd seen before (so they were of NO help), yet according to our services guys (who were awesome!) they changed the way they build the new models so this doesn't happen....
  • Melissa Bailey Nov 16, 2007
    Thanks everyone, for your help. Best Buy ended up declaring our set a "lemon". We replaced it with a Sony Wega and have had no problems with that set.
  • san11 Jun 05, 2008
    shutting off after 60 seconds happened twice in a year and half. But I am on my third lamp (cost $250.00) spent 2600.00 on tv. thought it would last a little longer. Called Mistsubishi sent them my receipt for the tv and the lamp that was replaced the second time in late Nov. Said they would send me a modified version lamp (What does that mean) Still waiting its been a week. Really just want a new tv or I'd like to know if this model has been recalled. Mitsubishi DLP HDTV WD-Y57
  • Anonymous Mar 23, 2009
    My warrenty expired last month. TV suddenly shuts down. Tried two new lamps with out success. Green light stays on for about 60 seconds, shuts down, and lamp light comes on. I have moved it, plugged it directly in to the wall, cleaned the filter. Wished I knew how to fix the sensor wire. shoot!!!!!
Some of the Mitsu *25's are covered by a factory recall of the optical engine, even if it is out of warranty.
The airflow message is a faulty temperature sensor located near the lamp. Temporary fixes (that will not void your warranty), are as follows:
Find the inlet vent, clean the filter, then place a small fan in front of said filter.
Call a repair company thats an ASC for mitsu, they will replace the sensor (not repair).
Sometimes, when the change lamp message appears, and you try a reset, it does not work. Unfortunately, this is a known problem without a known solution, other than just keep resetting it.
Posted on Dec 06, 2007
If anyone is still having this problem go to Mitsubishi's web sight. It is being caused by a loose connection. They need to replace a thermal sensor and this is covered under manufacturer's warranty. MDEA has also extended the warranty for this problem alone. Hope this helps someone.
CJ
Chicago, IL
Posted on Nov 16, 2007
  • 3 Answers
The problem is not caused by faulty surge protectors or lack of air flow. It is a temperature sensor located near the lamp housing. The problem is intermittent, which makes it more difficult to trouble shoot. Mitsubishi was doing everything from replacing the DLP engine to replacing just the sensor. Some techs were claiming to "fix" the problem by relocating the wire. This is not a fix. This is an excuse to abandon the problem. It does eventually go away, only to resurface later. My WD-Y57 does it about 5 times a week. You have to power cycle the set nearly 10 times, which I hate to do because arcing the lamp shortens its life substantially. Unplugging the set for 12 hours is retarded. It's a way to get you off the phone quickly. Nothing requires that amount of time to "reset". A minute or two is good enough to discharge most all of the capacitors in the unit. I only hope that there is a service bulletin on Mitsubishi?s service website that the tech can use. The service manual is no help for this problem. Sorry I am not able to offer a fix, other than to replace the sensor with a new one. The company I work for services commercial and broadcast equipment, not consumer. Attempting to service this outside of the normal channels for me will result in non payment for the warranty claim. Phil St. Louis, MO
Posted on Aug 01, 2007
  • 65 Answers
I see a lot of cheap surge protectors with internal wiring problems they sometimes introduce more problems than they are worth that may have been your problem all along with a possible loose ground returns in your electrical box the bus bars for all the wiring get noisy in an older house and need to retightened the mitsu tv has a little round reset button on the front panel it is only accessible with something like a ball point pen there is also a new style lamp for the tv , make sure you get one and keep the filter clean in the back it will extend the life of the tv dont attempt to constantly restart the tv if you suspect the lamp then follow the directions on the front panel and inspect the lamp you know when you see a bad lamp this product also has an intermediate mirror that likes to get dirty make sure you have them clean it or replace it itll help the pic quality
Posted on Dec 09, 2006
  • beldar conehead Dec 09, 2006
    another problem i see is dlps around fireplaces
    these products have fans and thermostats that like to shut down in higher than normal room temps
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
My sony sxrd 60 comes on only for a sec than go off and red stanby lamp blinks 4 times,i have cleanned vents and checked bulb door,can only turn tv off and back on ,and still onlly get screen to show...
4 times red light blinking indicates problem with exhaust fan that is not running and tv shuts down instantly due to protection mode activation.
Please check exhaust fan and make sure its connector is plugged in and fan runs freely.
Thanks.
Apr 19, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    Hi I have a Sony Grand WEGA KDF-60XS955 TV
    Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
    May 04, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
    I have a large screen panasonic tv. The lamp
    Turn On tv.
    Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
    Hope this info will help you.
    Thanks.
    Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
    How do i reset the lamp meter after i change the lamp
    Press and hold "Volume Down" button on TV front and press "Play/Split" button on TV remote control for 6 seconds, Lamp Timer Reset message will come in screen.
    Aug 07, 2009 | Panasonic PT-60LC14 60" Rear Projection...
    Tv plays for a few minutes then shuts down. the red light blinks.
    You need reset the lamp timer after
    replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
    Feb 14, 2009 | Sony KDF42E2000 42" HDTV
    Samsung DLP HL-P5063W
    you have the same problem I have. The problem is fixed by changing the new light bulb. The problem appears again after 1500 hours of use. You can keep buying new light bulbs or avoid it by not buying another Samsung TV.
    Sep 23, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
    TV shuts down
    Remove the lamp assembly, There will be a screen on the top and bottom of the assy remove all dust from these screens. also check the tube at the top of of the lamp receptical this is an air cooling pathway. reassemble and fire it up. This worked for me and saved some serious coin judging from some of the other solutions I have seen (lamp and balast) ouch!!!
    Jun 21, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
    Mitsubishi WD-52525 52" Rear Projection HDTV Logo
    520 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
