Question about Goodman GMS90703BXA Heater
3ton heat pump googman 14 seer
Ac works great super heat set at 12 . winter comes will not heat house have to reclaim around 1 and half pounds of freon to get heat furnace was install same time 3 ton blower drive chage txv still same problem
    Problem Solver:
  • 17 Answers
Give me the model numbers on the heat pump and the coil, I would expect its a really poor match.
Posted on Nov 17, 2008
Dear Sir,I have an Amana Distinction 2.0 Ton heat pump, SEER 14 installed in my department about 4 months ago. I've noticed that the AC has a regular pattern running in the on/off cycle and that i
You need a tech. All 14 seer units have an X13 motor which speeds up and down on start up. A tech will adjust your tstat programing. Fan stays on after unit is done cooling to help drain water in cooling and cool off heat strips in heating,
Jun 15, 2013 | Heating & Cooling
Where is the reset button on an Amana ASZ14 unit?
I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
Here are some more repair tips...
Heat Pump Troubleshooting & Repair:
http://www.hometips.com/repair-fix/heat-pump.html
Heat Pump Troubleshooting Repair
Amana ASZ14 web page:
http://www.amana-hac.com/products/heat-pumps/14-seer-asz14
ASZ14 Heat Pumps
Amana ASZ 14 SEER Technical Manual
(45-page PDF):
http://www.manualslib.com/manual/877256/Amana-Asz-14-Seer.html
Amana ASZ (and ASX) Service Instructions (66-page PDF):
http://www.acdirect.com/media/catalog/files/RS6200006.PDF
Jan 11, 2011 | Amana PTH123B25AJ Heat Pump Air...
I have a Hayward super pump. I just changed the housing gasket, but it is still leaking from somewhere at the bottom. I can't see where it is exactly leaking because there is no clearance between the pump...
You forgot to replace the most important part...The" shaft seal".It is behind the impeller. Be sure to remove all the pieces of the old seal off the impeller ,(they always come off in pieces) and put silicone on the rubber part that sets in the pump housing. Make sure you keep the white porcelain surface perfectly clean, and you will also need to replace the ribbon gasket again.
Sep 30, 2010 | Hayward 1 12 Hp Super Swimming Pool Pump...
My heat willnot come on all i here is humm in the unit under the house and nothing inthe outside unit it is a "Googman-ARUF02400A1"
Ok, If you don't have a heat pump, you should not be hearing anything from the outside unit. I assume you have electric heat. I feel strongly that you have a bad fan motor capacitor. This is what sends a jolt of power to start the fan motor. Good luck and have a great day.
Oct 18, 2009 | Goodman Heating & Cooling
I am trying to determine the specs on my Rheem Criterion II lx2000 heating/AC unit unit installed in Sept 99, I blieve it was manufactured 2/5/99 based on AC Pump serial number 6263F259928697 Model RAMB...
rheems site is secure for dealers only but i can tell you. its a 3 ton unit 12 SEER R22 unit. The coil (rcga) is a 3 ton coil The AC is a 1999 and coil 1998. the # you have for the heater is accually just the honeywell gas valve. the model for the heater would be on the inside wall near the gas valve.
Sep 19, 2009 | Heating & Cooling
I have a heat pump AC unit. Amana ASZ140241 SEER 14. The AC is not working; no cold air is blowing. I checked the unit outside and there is a block of ice around the pipe leading into the house. Is there...
The ice shows that you have freon so that to me is an indicator of an inside problem. Could be dirty air filter. Dirty a-coil, or bad blower motor.
I may need a little freon but do the cleaning yourself before you call anyone. It don't take an HVAC guy to wash coils. Use a foaming coil cleaner that is specifically for indoor use and go by the directions. The no rinse formula will draw out the coils and open the drain.
Jun 24, 2009 | Heating & Cooling
I need help selecting the best Amana 5 ton furnace/ac.
I believe you are asking which furnace to go with?
Just some clarification first.
The "condensor" is the outdoor unit.
A "Compressor" is the device inside the outdoor unit that pumps and "compresses" the refridgerant.
An evaporator is the indoor coil, it has refridgerant running through it.
The furnace is completely seperat from the condensor and evaporator.
I "THINK" you are saying that you are looking to buy an AMANA system with a 5 ton 14 to 16 SEER condensor, and a furnace, but you need suggestions on the furnace.
typically when you purchace a condensor, the evaporator coil is simply matched by the manufacturer to the specific condensor you purchace, there is no choosing to deal with. All condensors ofcourse come with a compressor already installed.
If my assumption about your request is correct, maybe this will help.
Amana's 90+ furnaces are great units. I would recomend them to anyone. The 80+ uses a somewhat inferior heat exchanger, and is ofcourse less efficient.
Anything higher than a 90+ can take quite a while to recoup the costs of the enitial purchace through your efficiency savings.
If it were my home, I would go with the 90+ furnace, and the 16 SEER Condensor/evaporator system. But ultimatly, its up to you, your efficiency standards and your wallets potential.
If you live in a northern state where AC is little needed, I'd go with the 14 SEER AC.
Again, an initial cost verses long term savings issue.
Dec 09, 2008 | Amana Heating & Cooling
Power consumption excessively high
Yes a higher SEER can help reduce electric costs. However. In most cases this will require changing both the indoor and outdoor units. In other words if you have a 10 SEER matched system and only upgrade the outdoor unit to a 14 SEER you will not get exactly 14 SEER efficiency. They must match.
Before excepting bids on new equipment I would first higher a licensed company to measure the Heat gain/loss from you house. This information will tell you if the current system was originally sized correctly. The improper sizing can lead to high electric bills as well. I hope this helps.
Jun 16, 2008 | Weather King 10AJA6001AH Air Conditioner
Goodman GMS90703BXA Heater Logo
119 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
