Question about ValuSoft Let's Ride: Corral Club for Windows
Let's Ride Corral Club will not run
Game is new. Computer uses Windows Vista. What should I do to play?
  • MarvelGirl1 Mar 15, 2009
    I bought this game for windows 98/ME/XP instead of the one for Vista which is what I have and I did everything that "jwalant" said but it still does not work...what should I do now?
  • Anonymous Mar 14, 2014
    I,m using a new tablet,am a club member and son,t know how to get to Club Pogo
  • 17 Answers
To make the all the files of the game compatible to Windows Vista you need to install the game and then make changes to the game exe file.
Some game ".exe" file (executeable file) would let you make changes in the Compatibility option, whereas older games might not give that option at all.
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
9. After the game is installed go to the game directory and find the "LetsRide.exe" and click on "Properties" and repeat step no.7
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
There are lot of files that need to be changed in order to get full functionality and to communicate with operating system and the hardware, hence there is no guarantee that the game might run even in cases where you will successfully install an older version of the game with the above mentioned steps.
The same set of steps can be used for installation of older games installation on Windows Vista.
Posted on Nov 11, 2008
I have windows 7 and i want to install Corral Club. I changed the compatibility to windows xp service pack2 . the install wizard says stalling, but then it goes away again and nothing happens
I have seen others with this same issue. Apparently you have to run the installation as an administrator. Simply right-click the setup icon and select run as administrator.
Jan 01, 2014 | ValuSoft Let's Ride: Corral Club for...
I put the disc into my Windows 7 laptop. It let me install the Let's Ride Dreamer Game with no problem. But when I try to install the Let's Ride Corral Club the InstallShield Wizard comes up then...
windows 7 is no longer supported by Microsoft so there may be conflicts between the systems
put the disc for the game in a cd and go to computer and run the disc from the cd icon
Oct 28, 2017 | ValuSoft Let's Ride: Corral Club for...
I've had my Let's Ride!: Silver Buckle Stables game for a few years now. It's been installed on my PC, but the PC crashed. So, I tried installing it on my laptop running on Windows 7, and when I attempt...
Hey 1323164 you were right. I was having this same problem trying to run this game on Windows 10 but what ended up fixing it was opening up the folder on the disk, running the setup file in compatibility mode for Win XP (service pack 3), and running it in administrator mode. Then in the setup I ran custom install, and selected the Direct X install and selected "will not be available for program". Basically it would not be installed with the program. Then I pressed next and it installed and runs great! :D Thank you so much for that hint!
Dec 27, 2010 | ValuSoft Let's Ride: Corral Club for...
Lets ride corral club wont download on to my apple mac, can anyone help me with this so i can get it working? thanks!
You need to make sure it is MAC compatible, then if it is, check your OS (operating system) generally mac games require Snow Leopard or higher, but I would make sure. I have a mac too, and those are my 2 main problems. Good Luck and Have Fun!
Dec 09, 2010 | ValuSoft Let's Ride: Corral Club for...
My game wont install
If you are using Win 7, right click on the setup icon and run as administrator.
Jan 07, 2010 | ValuSoft Let's Ride: Corral Club for...
I have downloaded let's ride corral club but when i started installing they tell me "O.S. not supported"
Kindly let me know what OS you are using and kindly go through the readme file of your game wether it supports your OS or is it made exclusively for few OS. or just paste a link from where u downloaded the game.
Jun 27, 2009 | Video Game Consoles & Games
How do I access "let's Ride! Corral Club" game on a Mac OSX 10?
game might not be compatable with your system. check to see on the game box.
May 03, 2009 | Computers & Internet
ValuSoft Let's Ride: Corral Club for Windows Logo
1,828 people viewed this question
Top ValuSoft Video Game Consoles & Games Experts
James Wishart
MegaByteMe
MegaByteMe
Tom Chichester
Are you a ValuSoft Video Game Console and Game Expert? Answer questions, earn points and help others
