Question about HP Office Equipment & Supplies
Hello , I'm trying to help my sister to resolve her problem since she doesn't have internet , she has an IMAC version 9.2 and a printer HP psc 1310 which always functioned very well till she got this message one of the two cartridges stopped working , check that they are well in place . That was verified amd we also disinstalled the printer and installed it again and we restarted the computer often and also we changed both the ink cartridges and we also disconnected the printer and the computer and we still have the same message so we c'ant print anymore, please help us .thank you in advance Pauline
  • HP Master
  • 4,338 Answers
If the message on the computer does not identify a particular cartridge (it says only Print cartridge error ), follow the steps below to determine which cartridge is causing the problem.
  1. Open the cartridge access door.
  2. Remove either cartridge (not both).
  3. Close the cartridge access door.
    • If the computer message is Print Cartridge Error , then the print cartridge that is still in the printer is the problem cartridge.
    • If the computer message is NOT Print Cartridge Error (instead, it says that the cartridge you have removed is ...Either missing, not detected, or incorrectly installed ), then the cartridge you have removed is the problem cartridge.
    • If the problem still occurs, the electrical contact between the cartridges and the printer might be bad. Removing and reseating the cartridges might help.
      1. Open the cartridge access door and wait a moment for the cartridges to come to the center.
      2. Press down on the end of the problem cartridge to snap it out of the carriage.
      3. If there is tape on the cartridge, remove it. Do not remove the copper-colored strip.
      4. Replace the cartridge. Place it in its slot at a slight angle, and then press up and forward until the cartridge snaps into position.
        • The black or photo cartridge goes on the right.
        • The tricolor cartridge goes on the left.
        • If the light is still blinking, clean the electrical contacts by the procedure below:
          1. Gather the following items to clean the cartridge and print carriage:
            • Clean distilled water. Use bottled or filtered water if distilled water is not available.
            • Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
          2. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up. NOTE: Try to clean the contacts quickly enough that the cartridge is not outside of the printer for more than 30 minutes. The ink can dry and clog the nozzles if the cartridge is outside of the printer for too long.
          3. Unplug the printer.
          4. Dip a swab in the clean water, then squeeze it to remove most of the moisture. The swab should only be slightly damp.Clean the contacts in the print carriage, inside the printer.
          5. Clean the print cartridge contacts. Avoid touching the nozzles.
          6. Wait ten minutes to allow the cartridge to dry, then reinstall the cartridge, plug the printer back in, and close the cartridge access door
          7. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
            Thanks, Joe
Posted on Nov 11, 2008
After installig windows 7 the scanner on my hp 1310 printer is not working
maybe your printer software not compatible to your OS try to download latest version of your printer on the manufacturer website.
Oct 07, 2010 | HP psc 1310 series
I need a driver for my hp psc 1310 series printer can you help!
Check the link below and download the driver for free:
http://download.cnet.com/hp-psc-1310-series/3000-2116_4-63186.html
Have a great day!
Nov 10, 2009 | HP PSC 1315 All-In-One InkJet Printer
I have a HP psc 1310 series all=in-one and am not able to get into hp director.I have uninstalled and reinstalled on a number of occasions without success.HP Image and HP document viewer are OK.The...
Do you have internet explorer version 7 installed on your computer?
HP Director has a compatibility issue with Internet Explorer 7. Please refer to this document if u have Internet Explorer 7 installed on your PC.
thank you.
Oct 12, 2008 | Office Equipment & Supplies
We have a HP printer series 1310 and have recently purchased an ASUS notebook. We have attempted to install this printer to the laptop with difficulty as we continually rec've an error msg stating it is...
Hello
The printer should be compatible with both vista and XP
your printer is a serie 1310 but if you look closer you should find a more exakt nr like
» HP PSC 1311 All-in-One Printer
» HP PSC 1312 All-in-One Printer
» HP PSC 1315 All-in-One Printer
» HP PSC 1315v All-in-One Printer
» HP PSC 1315xi All-in-One Printer
» HP PSC 1317 All-in-One Printer
» HP PSC 1318 All-in-One Printer
or something like it. check for the serie nr or a mark somewere on the printer and you should find the right printer model.
you can download the drivers here when you find the right model.
good luck.
hope I helped.
Sep 04, 2008 | HP Computers & Internet
Need to reinstall hp psc 1310 series all-in=one printer/scanner/copier
try going to the HP website hp.com
sometimes they have more than one driver, so if one is not working you can try a different version.
Jul 30, 2008 | Office Equipment & Supplies
I just got a new Dell with windows 7 and my HP 1310 printer will not work with it what do I do
Nov 23, 2007 | HP PSC 1315 All-In-One InkJet Printer
310 people viewed this question
Seeker5211
Seeker5211
