Question about SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready Plasma Television
Can not get closed captioning to turn off
I ma using a direct Tv remote. have access to menus but can not find out how to turn it off.
  • mitchellbaum Nov 11, 2008
    i am using a direct Tv remote. have access to the menus but no luck finding the menu to turn it off
  • RV EXTERIOR COATINGS Dec 21, 2008
    SVA HD4208Tiii-PDP 42" Plasma
    I am using a Dish Network remote controll which does not work on this SVA. I have searched for the codes to input to my Dish Remote but no success.  I did the "search" through the Dish Remote procedure and one code will turn the SVA off but not access the correct function buttons on the remote.  For example: what ever code the remote did find that turns the SVA off will also control the volume if you select the red TV off button for sound up; and the blue volume + side for sound down.  I also found that the #1button turns the SVA off.
    Now...., if I can just find the correct SVA codes to make the Dish Net Remote controll work properly I will be a happy camper!!!!
    Problem Solver:
You have to use your SVA remote controll to access the CLOSED CAPTION function to turn it off ....as I just found out myself by the Wiz..... ;)
Posted on Dec 21, 2008
How do you turn on closed caption on apex digital flat screen tv?
not all sets have the capability, not all programmes have captions.
This tell you how to turn OFF, but just choose ON.
http://captionmax.com/resources/turn-off-captions/
and I found this
Best Answer: There are two types of closed captions; analog and digital. It's possible that you turned one off and not the other. Some sets will only allow you to access the menus for the type of signal you are watching so make sure you are tuned to the offending channel when you access the menus.
Also, you might want to check other devices that the signal may go through on it's way to the TV like cable boxes and DVD players. Sometimes those have closed caption decoders, too.
Source(s): Broadcast Engineer for 30+ years.
Captioning Services Turn Off Closed Captions
Jun 11, 2016 | Apex Digital Televison & Video
Sharp Aquos LCD TV 52"
Does your cable company support CC?
Apr 08, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Don't know how to activate closed caption, and cannot find instructions
What is the TV source? For some sources (set top box), you may need to turn on the captions using the menus of the box.
Assuming you are using a source that gives captions that the TV can interpret, if you have the Proscan 26LA30Q remote, press the CC button to toggle through the caption options. Another route is to press Menu (either on the remote or the buttons on the side of the TV) then select the Feature submenu with the left/right arrows. Press Enter (menu when you use the buttons on the TV) then navigate to the Digital Closed Captions option. Here you can set the captions to on and adjust the size, style and color of the captions when they appear on-screen.
If you are using a universal remote, try the CC button. If it doesn't work, try another code for the Proscan TV on the remote. There are some codes that may not control all of the functions of the TV with the remote.
Crutchfield has the manual for the TV on the product site: http://www.crutchfield.com/S-Kaec3gBqVtM/p_68326LA30Q/Proscan-26LA30Q.html . The direct link is http://a248.e.akamai.net/pix.crutchfield.com/Manuals/683/68326LA30Q.PDF .
I hope this helps
Aug 18, 2011 | Proscan 26LA30Q 26 in. LCD Television
I have an Orion 19"
You usually need the original remote. The trouble with universal remotes is that they generally control only the basic functions of a TV (power, volume, channel) but not much else. Without the original, you often lose other functions. You can try the front panel buttons if yours has them. On some sets the on-screen menus allow you to access caption settings.
But are you sure the captions are coming from the TV? Sure, the TV is displaying them, but if you have a satellite receiver, cable box or digital set-top box, the captions may be coming from that device. This is likely to be true if the captions just mysteriously started and you don't have or aren't using the TV original remote. These devices often don't allow a TV's built-in caption decoder to work properly, so they provide captions themselves. You may have turned captions on using that device's remote. Check the menu for caption controls.
Jul 10, 2011 | Orion1934 19" TV
Unable to find how to access the closed captions section
Hi scorpiow2001
If you find the tools button on your remote you should find captions vision in the section of the menu hope this helps.. Cheers nikki
You can go to this link and download the manual for you tv
http://itg.beckman.illinois.edu/visualization_laboratory/equipment/multimedia/manuals/KDL40-46XBR2.pdf
Please take a few seconds of your time to rate my solution as i have taken time to answer your question the best i can Thank You......
Jan 17, 2011 | Sony BRAVIA KDL40XBR 40 in. LCD TV
I have a panasonic TV. direct tv remote for a . while programming the timer, somehow closed captioning got turned on & i after hours of trying to get it turned off, NO LUCK. it's driving me insane!!...
I could do better with a picture of the remote. Closed captioning is usually a multi-press button, that is each press takes you through each of the four types of closed captioning and then off.
You can enable closed captioning on a DVD Recorder, it looks like the TV, but its only on the picture from the DVD Recorder.
If you have a PVR, you could have closed captioning on on that device.
Try tuning off everything else to make sure it IS the TV.
Turn on the menu and find the closed captioning settings and set to OFF.
Press the close captioning button on the remote (If there is one) and press CC repeatedly until it says OFF.
Try and control close captioning, timer and menus with the ORIGINAL remote and not a programmable one.
Programmable remotes are not always completely compatible.
Mar 20, 2010 | RCA Universal Remote Control
Closed caption / universal remote
Couple things to try:
On the remote - Press "Clear" button
May have to turn off CC in the TV menus. Try Menu on the remote and look for closed caption there.
If remote doesn't work, can try with buttons on TV itself to get into menu and turn it off.
Here's a link to the manual for that remote:
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=innovage&dv=universalremote&md=jumboremote&kw=&st=&ar=&dt=&so=&pg=1&file=others/innovage/jumbo-manual.zip
Mar 28, 2009 | One For All URC-4330 Remote Control
Captioning
Try getting into the tv menus with the menu button on the remote or the menu button on the tv. Find closed caption or CC and turn it off in the menus.
Nov 02, 2007 | RCA Universal Remote 3 Device Remote...
Closed caption activiting on everytime tv is turned on
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
Oct 02, 2007 | Televison & Video
SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready Plasma Television Logo
793 people viewed this question
Top SVA-USA Televison & Video Experts
Henry  Thomas
Henry Thomas
Tony
Michael Galve
Michael Galve
Are you a SVA-USA Televison and Video Expert? Answer questions, earn points and help others
