Question about RCA 27V530T 27" TV
No picture powers up, no picture, red light blinking, went out suddenly after a crackling sound
  • 1 more comment
  • kriskay3 Nov 11, 2008
    thanks
  • Kennyg10 Jan 19, 2009
    My television will nott turn on, but it gives off this chimming/humming sound as though its about to come on but it is not.
  • pwalton9 May 11, 2010
    same as kriskay3
    Brigadier General:
  • 6,966 Answers
Offhand, the "red light blinking" indicates that the unit has switched to protection mode. On some models, the number and sequence of flashes indicates the general area of the fault and where initial diagnosis can begin. Eventually the unit has to be opened up for a look and see. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Incidentally, in the hope that this is a simple glitch, perhaps you can try unplugging from the mains and removing all connectors. After an extended period, reconnect and verify connections and try again. Although in cases where "crackling sound" was heard may just aggravate the problem. The "crackling sound" indicates a major component has failed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 11, 2008
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Sep 12, 2009 | Toshiba 57H81 57" Rear Projection...
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
Power on no picture
Power supply PC board must be rebuilt = replace all bad capacitors.............T.
Aug 19, 2008 | Akai LCT2716 27 in. LCD Television
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Lost picture
sounds like video card failure mode, 101..you a technically adroit person?
Apr 03, 2008 | Televison & Video
Picture and sound went out suddenly on a Sony KV-35S40
sony has problem with bad picture tubes as well as flyback transformers .if you have shorted hori output then replace it if set shorts it out again your looking at bad flyback transformer as well as maybe leaky tube.
Oct 27, 2007 | Sony KV-35S40 TV
RCA 27V530T 27" TV Logo
64 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
