Question about JVC AV-48WP30 48" Rear Projection Television
Green Shade on tv screen
I have this greeen shade on my JVC projection screen tv. It seems to me the green is where th color black should be. For example, if a show on tv is showing a black sky on my tv it will have a green haze to it. My buddy says I need a colo adjustment,but it doesn't go away when I try to adjust the color form the tv menu. I'm allout of answers at this point.
  • Anonymous Nov 16, 2008
    Same problem here, everything has a greenish tint to it despite all adjustments. T.V. is fine otherwise. A friend says it might be a gamma adjustment? but I dont know how to go about doing this.
    Got the same problem, light green tint all the time despite adjustments. Could it be a gamma problem and if so how would I adjust it?
This is a typical example of a convergence amplifier failing (any brand would be the same).
More than likely there are 3 amps and they should all be replaced together. Parts shouldn't be too
expensive but I would expect approx $100 US in North America and about £100 UK. Bear in mind thats for the repair not any transportation costs to/from the repair centre.
Posted on Nov 27, 2008
Television screen is green
Is the picture in a green shade or the whole screen is simply green?
if the second one is currect - the connection to the video source is lost. some tv do a blue or a green screen in order to prevent that anoying sound that the old tv used to make.
try to reconnet your source (PC or a DVD player, whatever you can).
if it works on other devices - your device is probably damaged.
Jun 10, 2012 | Sony KP-53HS30 53" Rear Projection...
Samsung DLP TV- colors seem to mess up -Faces have green streaks
sounds like you are haveing an issue with th color wheel timing. either the color wheel is bad or the dmd board is bad.only way to know is to have a technician look at it.
Oct 22, 2007 | Samsung HCN4226W 42" Rear Projection...
Principle of lcd
Liquid Crystal Display - LCD
There is a Flo recent light that shines behind the screen. This light is what passes through the window or LCD when the shades are open or partly opened.
Think of each colored individual LCD (pixel) as a Window Shade. You have pixels that are made up of 1-red, 1- green and 1-blue light shade.
Your main control board will tell each light shade how much/far to open each colored light shade so it will make the color it needs to.
If the shades are closed (black) if the shades are all open (white)
Hope this helps.
May 24, 2012 | Sony BRAVIA KDL-40S2010 40 in. LCD...
We have a JVC LT-32JM30 and recently for no reason at all, the picture color has messed up, we have tried resetting and adjusting the tinit, etc but nothing works. Everything is a varying shade of green or...
an internal degaussing coil circuit is already installed in the unit to neutralized color pattern...a loose solder connection may have caused this because as it operates temperature increases between the thermistor..
Jul 15, 2011 | JVC AV-27530 27" TV
Philips 60PP9363 colors not right. TV is 5 years old, the convergence appears to be fine in that all of the colors line up fine, but they are not the right shade. The green and blue are both teal, with...
Ur tv look dull in pictures?Ur tv might need it CRT tube coolant replacement.Tries websites like Tvrepairworld.com,Tvrepairkit.com to buy a coolant kit to replaced CRT tube coolant replacement.
Aug 04, 2010 | Philips 60PP9363 60" Rear Projection...
My picture is now always a pink to red shade on my
unplug your TV look on the back for a three controls marked red / blue / green "screen" turn / tap on them; watch the screen when you find the "dirty" control clean it with "TV tuner cleaner spray"
Mar 20, 2010 | Hitachi 57UWX20B 57" Rear Projection...
Green shade color on screen over tyhe program that is been broadcast
its a loose connections to you color amplifier RGB. cold solder in that board section.
May 30, 2009 | Samsung HL-R6167W 61" HDTV
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Sony Trinitron K29 inch CRT TV screen shows green shade!
i have the same problem with my sony trinton tv 36 inch if you know how to fix this please email me on amir.dhawan@gmail.com
Dec 30, 2007 | LG Flatron 295LM 22" LCD Monitor
Color of picture
turn off the color completely and see it the picture is black and white or has a shade of green,if so your gayscale needs to be adjusted
Sep 09, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
JVC AV-48WP30 48" Rear Projection Television Logo
394 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
