Question about GE Washing Machines
Clothes Very Wet
Our six month washing machine appears to run it's full cycle including spin but when we take the clothes out they are soaking to the point they drip on the floor even thought all the water has drained out. We had the GE repairman out and he said it was the way our hose was set up. We fixed that but it still does the same thing. Help! Thanks
  • 4 Answers
HES RITE MAYBE THE HOSE IS KINKED,IT DEPENDS WHAT KIND OF MACH. IT IS TOO,THERES COULD BE A BLOCK ON THE DRAIN HOLE INSIDE THE TUB,OR YOUR BELT SLIPPING OR TO BIG OF A LOAD,OR YOUR DRIVE COUPLING ARE WORN OUT IF YOUR WASHER IS A WP,KENMORE,THE PUMP COULD HAVE SOMETHING IN IT TO THAT CANT GO THRU,YOU MAY HAVE A WIRE FROM A BRA INSIDE YOUR PUMP,YOU COULD BE GETTING OFF BALANCE EVERY TIME GOES TO SPIN.CHECK THE HOSE THAT GOES TO THE PUMP YOU MAY HAVE QUARTER THAT GOT STUCK THERE WHEN IT DRAIN THE QUARTER GOES FLAT AND BLOCK THE DRAINAGE.
Posted on Nov 11, 2008
Maytag bravos mct washer keeps filling with water on drain and spin cycly
first thing to do is a reset. unplug it for 5 min and plug back in to see if it resets to factory settings.
Jan 21, 2018 | Maytag Washing Machines
Hotpoint WF250 clothes coming out soaking wet after spin?
The fast wash cycle is for a reduced capacity load of approximately 3kg , it does not pump or spin long enough for a full capacity load
Jun 15, 2016 | Hotpoint Washing Machines
Soaking wet clothes after spin cycle
Check and choose a longer spin cycle and see if the fault changes. If so the SPIN cycle is too less or there is less action or speed in the cycle, check the motor speed, check the capacitor to the motor, the spindle friction - if so reset the spindle and drive.
Jan 17, 2013 | Washing Machines
My clothes are soak and wet after the spinning cycle ends
Could be a gearcase problem or a motor coupler problem or a clutch problem .Best off to call a reputable service company such as Sears.
Feb 06, 2010 | Washing Machines
Clothes are soaking wet after done
You may need a belt or a pump. Call sears they will help more.
Oct 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Whirpool Duet Was. WFW9400SZ01--Spin cycle leaves clothes soaked.
the problem is your spin program is normal but the machine could not do its job usually there is broken pin clucth under the spinning tube and sometimes the spin gear.this is due to overlload problem. you should brought the machine to your trusted machine repairer as this cost you around US 100-200 in comparison if you buy new one
Sep 25, 2017 | Whirlpool Washing Machines
Load remains wet after full cycle (including spin @ 1400 rpm)
Hi Paul, Assuming it is pumping out ok, Unplug the machine tip it back at an angle, underneath you will see a black hose that is attached to the bottom of the drum, remove this, take out the ball and discard it and remove anything that may be in the filter, replace the hose and try the machine.
Nov 30, 2007 | Hotpoint WMA64 Front Load Washer
Washing Machines Logo
24 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
