Question about Whirlpool RCC3024 Electric Cooktop
Whirlpool electric Cooktop's one burner not heating
I have Whirlpool electric cooktop. It has total of 4 buners.One of the burner is not working. Light come up when I trun on the switch but no heat on that burner. What could it be?
  • ahmed_rafiqu Nov 11, 2008
    Thanks for your response.It is a 3024 Electric cooktop. Model # RCC3024LD01. How can I troubleshoot any of them?
    Rerards,
    Ahmed
    Brigadier General:
  • 6,966 Answers
Initially, it could either be:
  • open heating element (most likely);
  • open temperature limiter (least likely);
  • faulty/loose connection/wiring (a possibility).
Please confirm that it is a Whirlpool RCC3024 Electric Cooktop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 11, 2008
  • Louie  Role
    Louie Role Nov 11, 2008
    Hi again,
    Appreciate the quick postback.
    For some reason I could not locate related literature for a RCC3024LD01, although there are for LB01, LQ01 and a LT01. Most of the components in these models could be checked with the use of a continuity tester (multitester VOM/DVM). The idea is to check for continuity of each component. If we are to assume that the heating element as a likely suspect, it is a matter of checking if the coil is continuous, that is no break anywhere in between. The test prods of the continuity tester would be applied to the two (2) terminals of the heating element and the tester should deflect/display how much is the resistance. Normal reading shouold be pretty low while no deflection/reading indicates an open coil and therefore would require replacement.
    These additional documents may be of help to you:
    1. exploded parts diagram;
    2. parts list.
    Cheers.
My whirlpool gold cooktop has the control lock button lit up- i can't turn on any buners?
Hello there and welcome to fixya
This is a fairly common issue with these
These cooktops have a internal memory built into them and if they get locked they need to be reset
SO what you will need to do is to unplug the power to the cooktop and leave it sit for 1 hr and do not touch ok then after the hour is up tunr on the power to the cooktop you may hear a audiable beep sound or a click sound this is normal now press the cancel button and you should be all right from here but if not please post me back a comment and tell me what is going on and i will give you further troubleshooting steps ok ?
Best regards Mike
Dec 31, 2011 | Whirlpool 30 in.GJC3054 Electric Cooktop
Kenmore electric cooktop not working on low eat
If it was the burner element it either would work or not (no in between)
It has to be the switch
Apr 13, 2010 | Kenmore Elite 44173 30 in. Electric...
2 right burners on my Jenn-Air JEC9536 cooktop stopped working.
I have a JEC9536ADB electric Jenn-Air Cooktop. We replaced the class top and now the knobs are all spliting and won't work. 2 of the main burners will only heat in the "high" position? What do I need to replace?
Sep 25, 2009 | Jenn-Air 35 in. JEC9536 Electric Cooktop
My Kenmore cooktop will not heat properly, all 4 burners. They turn on and heat a little bit, but the burner on lights do not light up and the burners do not heat to full temperature. I closed my oven...
hi my name is mark, a service tech needs to check the voltage to the cook top. you will probably find improper voltage. check data plate for proper voltage should be 208v or 230v depending onwhere you live.
Feb 18, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
Whirlpool Flat cooktop burner not heating up
Try cleaning the knobs. I did the same thing you did (turning the circuit breaker off but that did not solve the problem.
My wife just tried turning the knobs and that seemed to work. It appears that one of the knobs may have been so sticky that the though it's in the OFF position it thinks it's still ON.
Jan 12, 2009 | Whirlpool RCC3024 Electric Cooktop
Burners of electric cooktop not getting red hot
Hello
Welcome,
Sounds like you have a bad surface heat controller.
Nothing to do but call a hands on tech to replace a part.
please remember to leave a rating before you sign off
Dec 11, 2008 | GE 30 in. JP340 Electric Cooktop
RCC3024 cooktop one burner wont heat
Hi again,
It would seem you posted anew.
For some reason I could not locate related literature for a RCC3024LD01,although there are for LB01, LQ01 and a LT01. Most of the components inthese models could be checked with the use of a continuity tester(multitester VOM/DVM). The idea is to check for continuity of eachcomponent. If we are to assume that the heating element as a likelysuspect, it is a matter of checking if the coil is continuous, that isno break anywhere in between. The test prods of the continuity testerwould be applied to the two (2) terminals of the heating element andthe tester should deflect/display how much is the resistance. Normalreading shouold be pretty low while no deflection/reading indicates anopen coil and therefore would require replacement.
  2. parts list.
Cheers.
Nov 11, 2008 | Whirlpool RCC3024 Electric Cooktop
Knob not working and some burners not heating
The switch under that knob is bad.  It's called an infinite switch.  As far as the elements go, first thing to check is for proper voltage (220) to the cooktop.  Let me know what you find.
Oct 19, 2007 | Jenn-Air JED8430 Electric Cooktop
Whirlpool RCC3024 Electric Cooktop Logo
1,322 people viewed this question
Top Whirlpool Cooktops Experts
meztang
meztang
ray gallant
cwradio73
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
