Question about Epson C31C412144 Thermal Printer
Both lights were blinking alternately when my printer is switch on
When i replace the black ink of my printer , both light were blinking alternately. My printer wont print anymore, and an error message appearred in my pc every time i tried to print. I dont know why. my epson printer model is stylus c45 and my os is windows xp
  • 4 Answers
Whenever u r facing this problem do one thing switch off ur printer AND THEN SWITCH IT ON .. this problem occun due to errors not an issue dont wory
gud luck
Posted on Mar 17, 2008
Originally the black ink would not print. replaced, primed, cleaned. nothing, the same problem, no black ink. Now I can't get the cartridge light to quite blinking. It is not steady orange, but a...
First off, if you touched the metal contacts on the printer or cartridge, you could damage or leave a film on the contact surface. Take it out of the printer, with a qtip dip in rubbing alcohol, squeeze out access, rub surfaces, air dry, and reinsert again. If still no ink, turn the print end up under the very hot water tap and run for 2 minutes. Dry and replace. It may do the trick.
Mar 01, 2014 | HP DesignJet 450c InkJet Printer
Colour ink cartridge empty but the on off light and red ink light flashes alternately and the carriage will not move to allow access to remove the empty cartridge.
hello, are you sure its not the error light that is blinking alternately with the power light, or is ink light indicator blinking , and just the power light blinking. i would first problably pull the power cord. then plug back in, and try again. the alternating error light and power light would be inkjet service, maint or waste pads are full, as far as the other error, i looked it up, and that error not coming up, unless there is something else going on. maybe cover for ink cartridge is caught, and not allowing printer to cycle.
Oct 05, 2010 | Epson Stylus Photo 1290 InkJet Printer
2 red lights are blinking!!!!!
is both the light blink the same time or blink alternate ? if blink the same time, it's probably a fatal error..
if blink alternately then the waste ink counter need to be reset and the waste ink pad need to be replaced.
Jul 18, 2010 | Epson RX620 All-In-One InkJet Photo...
My both red light is blinking continuously what i do help me
both light are blinking at the same time or blinking alternatively ?
if both blinking same time, it's a fatal error.. means it could be something wrong with the carriage or board or encoder belt...
if the light blink alternatively, it means the waste ink counter need to be reset and ink pad need to be replaced.
May 26, 2010 | Epson Stylus Photo R200 InkJet Printer
Replace ink cart and amber light still blinks
Usually if the Amber light is blinking with a new cartridge, that cartridge has bad electronics.
Try replacing the cartridge with another or the old one, if the light goes out it was just a bad cartridge.
Sep 10, 2009 | HP DeskJet 932c InkJet Printer
My Canon ip1600 wont print with new ink cartridge.
Visite the support tech and try to find a answer for you probelem:
Sep 09, 2009 | Canon PIXMA iP1600 Printer
The ink light blinks all the time since I replaced the color
The ink light flashes when the top cover is open...check the switch that tells the printer when the cover is closed.
Feb 23, 2009 | HP DeskJet 842c InkJet Printer
Error code E5 / BLACK INK
Do a search for resetting ink cartridges after refilling! Hope this helps - fotobean
Feb 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My HP printer's light blinks, but it doesn't print.
two things to consider.
1. If the blinking is fast (like more than two blinks per second) then the printer is damaged. Either the main controller board is fried or the carriage/ink controller is damaged.
2. if the blinking is slow ( 1 blink per second) this means that either of your cartridges is busted. remove the black cartridge then close the top cover. If the blinking stops, then the black ink is the culprit. If not, replace the black then remove the other cartridge. THis means that one of your cartridge needs to be replaced.
Sep 27, 2008 | HP DeskJet 3940 InkJet Photo Printer
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
Epson C31C412144 Thermal Printer Logo
132 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
