The 1/8" right-angle plug on my Sennheiser ear buds broke. I was able to get the piece out of my MP3 player, but I need to replace the plug - can you help?
    Scholar:
  • 131 Answers
IF THIS IS A STANDARD .125 90 DEGREE STEREO JACK(NOT FAMILIAR WITH SENNHEISER)THEN YOU SHOULD BE ABLE TO PICK ONE UP AT ANY LOCAL ELECTRONICS OR STERIO STORE.ITS JUST A SIMPLE MATTER OF SOLDERING IT ON.THEY SHOULD CARRY SOLDERLESS ALSO.BUT BE WARNED THESE ARE NOT PRETTY.HOPE THIS HELPS.THANX FOR USING FIX-YA.PLEASE RATE.
Posted on Nov 11, 2008
How to replace ear pads?
If you use a headset frequently, it's important to change the ear cushion periodically. Ear cushions absorb a lot of sweat, dirt and makeup and can breed bacteria if not cleaned or replaced as necessary. This can lead to bacterial ear infections in extreme cases. Repeated and frequent use can also cause foam ear cushion to deteriorate and break into pieces over time.
portable mp3 player
Sep 11, 2012 | Sennheiser Ear Pad Hd497 Hd202 Ii Hd212...
I purchased this mp3 on 11th devmber. the music is not getting through to the headphones - can you help? is it powered by a battery & is one included as standard?
Hi mharrington9,
You may want to post the make and model of your mp3 player. Someone may have solved the same problem with the same player, and would then be able to give you a more specific answer than this one;
I assume you have replaced or re-charged the battery first, and that full power to your player did not help. If so, it is likely to be a problem with the headphones, the headphone receptacle, or the amplifier inside the mp3 player;
1) Headphone problem?
Get a different set of ear-bud headphones, and try them out. If the alternative set works but your headphones do not work, it's the headphones.
1a) Large headphones, small player?
If your headphones are large, but the power of your MP3 player is small, the player may not have enough power to drive the headphone speakers. If you run your MP3 player through an additional amplifier, you may then have enough power to get sound out of your headphones.
1b) Broken wire in ear bud jack?
Most of my broken ear-bud sets have failed because one or more of the wires has broken, usually at the plug-end. There are 3 thin wires; If you break the left-channel or right-channel wire, only one earbud goes out. If you break the ground wire, both earbuds stop working, or you may hear a very faint sound at full volume. If you like to solder things, it is possible to get a new plug, cut off the old one, and solder in a new one. But it may be easier to get a new set of earbuds.
2) Broken Receptacle?
Plug your ear-buds into a different, working MP3 player. If the ear-buds work, then
Plug your MP3 into a computer through the data cable, and try to play something through the computer.
If the MP3 works through the data cable, something is wrong with the receptacle for your ear-bud plug.
You may be able to get your MP3 player replaced under warranty, since the purchase was recent. Or, if no warranty and you feel adventurous, take the back off and try to re-solder or replace the receptacle-- Though this usually ends in irreparable damage to the MP3 player :-\
3) Broken MP3 player?
If you can't get any music to play through the data cable or the computer, something is seriously wrong with the guts of the MP3 player. Try for a warranty replacement if you can.
Best of luck, mharrington9
Dec 12, 2010 | Audio Players & Recorders
I have broke my headphone? now what can i do
depends on where it is broken and whether or not they are ear buds. ove ear headphones or even the on ear, can be easily repaired by soldering the leads back onto the respective speaker. however ear buds tend to be a bit tougher for a novice to solder. if you broke the cable off of the connector, you are better off buying a new pair of headphones modern wires used in the cables for headphones is coated with a colored (or clear, for the grounds) lacquer that is hard to clean off and still get a good connection. good luck, and i hope this helps.
Apr 13, 2010 | Philips GoGear Flash MP3 Player
Same issue - right earbud volume lower than the left
yh im having the same problem good to know its not just me
Jul 08, 2009 | Sennheiser CX 300 Consumer Headphones
I have a sansa mp3 player
the headphone jack inside the unit has 3 attachment solder joints the botton right connection point breaks free of the board. the way to fix it is to get a small phlips screw driver remove the 4 black screws on the back of the unit remove the metal back, then remove 4 silver screws on the outer edges inside the unit & remove the board from the front cover & with a soldering iron with a very small tip resolder the loose connector to the board be carefull not to over heat the board or plastic jack & just put the unit back together.
Apr 20, 2009 | SanDisk Sansa e250 MP3 Player
Only have sound on right side
I don't know if you used new earphones but if you did I would try to clean the inside of the mp3 player then reconnect youre earphone. If you still have the problem return to the store, then the hardware in the mp3 itself is wrong.
Dec 25, 2008 | SanDisk Sansa e260 MP3 Player
30gb ipod
More than likely the ear bud or the wiring is damaged. Try set from a friend that you know works for confirmation.
Nov 27, 2007 | Apple iPod MA446LL/A MP3 Player
 Grubhead
Grubhead
