Question about Brother LS-2125 Mechanical Sewing Machine
Brother LOCK-523N overlocker threading
Just the simple way to thread the 3 cottons, with settings of the tensioners , would be great. (many thanks)
Looking for the manual for the brother lock-523
Posted on May 28, 2010
    New Friend:
Please display a diagram showing how to thread a Brother,Model No.523 Overlocker.
Posted on Aug 13, 2013
Tension settings on empisal overlocker 754d, pulse ?
The standard tension for a 3 or 4 thread overlock is to set each tension dial at the midway point and then tweak it from there. It helps to use different colors of thread so you can distinguish what each thread is doing.
The Anatomy of The Best Serger Tension My Tips Bonus Unpick it Serger...
Make It Handmade Perfecting Serger Overlocker Tension
Mar 13, 2017 | Sewing Machines
How do I get a balanced tension with my Elna 624 overlocker?
The best way is to thread with 4 separate colors of thread and then studying the stitch result. With the 4 colors, you can easily tell which thread tension is "off" and whether it should be tightened or loosened. However, a serger is not like a sewing machine where you can set the tension and use that setting for most projects. With a serger, a change in one or a couple of thread tensions will create a totally different stitch.
For most machines, there is a mark at the midway point on each tension control that is the "optimal" tension for a 4-thread overlock. HOWEVER, every machine differs, so these settings may need to be tweaked.
How to Adjust Thread Tension on an Overlocker Singer Australia
Different Serger Stitches and How to Use Them
You may want to download the serger workbooks at this site (Bernina), and work through each of the stitches. Make notes in the workbook as to how you have set up your machine to get the best of each stitch. This will be a great reference manual for many years.
Bernina Mastery Workbooks
Feb 23, 2017 | Elna Sewing Machines
Has been threaded but will not sew
check needle thread tension --too tight
check bobbin has cotton on it and is threaded correctly in the bobbin carrier
check bobbin thread tension ---too tight
Feb 10, 2016 | Sewing Machines
How can I set the right tension on an overlocker globe lock m-34?
The right tension on an overlocker will vary depending on the result that you want. The standard tension for just a plain 4-thread overlock stitch would generally have all the thread tensions set at the halfway mark between the high and lower number. From that point, you may need to tighten or loosen each thread tension to get all the threads to stitch evenly.
Probably the best advice would be consult your owner's manual. It should have instructions on adjusting the tensions and what to look for.
Another suggestion would be to search YouTube for a video that shows how to adjust overlocker tension.
Nov 14, 2015 | Sewing Machines
How do I stop the needle thread on my industrial overlocker ef4B531. from breaking as soon as I start sewing. I think I have the threading right.
ensure the tensioners are not too tight, reduce the tensioner to see if this helps. depending on thread type nylon or cotton etc the tension needs to match to control the feed to the needle if it is too high the thread who stick and when the needle makes the next stitch it can break the thread.
I hope this was useful.
Feb 18, 2015 | Brother Sewing Machines
I have a brother vx-1125 the cotton keeps snapping..but the tension is correct..please advise..
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Aug 17, 2012 | Janome Sewing Machines
Brother LS-2125 Mechanical Sewing Machine Logo
2,008 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
