Question about Nvidia GeForce 6800 PCI Express Graphic Card
Fan Stopped Working...?
Utility partition says its getting power toall parts of my computer but the cards fan wont work all of a sudden. What can i do?? my graphics are working just fine...its literally just the fanwont work. Got it to spin a little last night but only for like 20seconds then it stopped again. Sounded like a sick engine revving alittle then dieing.Thanks!
  • demonrich Nov 11, 2008
    Thanks, was hope it could be oiled or something but if figures that its not going to be easy :P. I'm going to keep the case open and window craked all through winter (nothing new lol) and hope it lasts past X-Mas before i buy a new one, since its PCIe-1 they arnt easy to find or cheap when i do find one lol. If you know of any other ideas that could help id love to try anything!
  • Anonymous Feb 20, 2009
    My Fan stopped as well does cause rashes sometimes
    Novelist:
  • 93 Answers
Sounds like the fan has died (the bearings will go out, just like on a case fan). I assume you made sure the power is connected to it (usually a little cable, on Nvidia cards), so... you are left with a few options:
1) Do nothing. Make sure your case has adequate cooling, and the Graphics Card should be fine.
2) Send it back and have it repaired. Unless it is under warranty, it will probably make more sense to...
3) Just go buy a new card.
Unfortunately, even if you could get the old fan off, finding a replacement would be seriously difficult. I like option 1 the best - if the card does overheat and die, then you still have options 2 and 3.
Cheers
Posted on Nov 11, 2008
Whining fan dell E520 computer
Replace the fan as soon as possible. If the noise suddenly stops, DON'T assume the problem corrected itself. More likely, the fan completely froze and stopped spinning entirely and you're at risk of overheating something inside. Generally, there are usually 3 fans in a desktop computer (cpu/heatsink, case, and power supply) and sometimes a 4th fan if the computer has a separate graphics card. Laptops usually only have one fan.
Apr 27, 2014 | Dell Dimension E520 PC Desktop
N610C computer-fan evidently stopped working. DVD-Rom works, Display does not power up nor the Hard drive. Hard drive works on other commputers. Battery light does not show charge, but DMM confirms power...
If the fan stopped working then..none of the things will work because there is no cooling system for the processor...take this computer to a local tech..or if you cacn do..upside down the laptop at the bottom remove the cover(small partitions) check for the dust there...clean that area with a vacum cleaner..
Aug 18, 2011 | Compaq Evo N610C Notebook
When i start games on my pc the temperature increases to 100 degrees and pc turned off this start today before that i've played a lot of games and there was no problems like that
There is a chance your fans and heat sinks may be clogged with dust. This would definitely cause over heating and turn off your machine, if occurring within your CPU or the CPU on your graphics card.
Mar 03, 2011 | ASUS K50AF Notebook
Hi there my computer wont start up it just comes up blank on the monitor and it says entering power save mode, i can hear the computer working and everything, ive taken the case apart and the fan on the...
I'm sorry to be be the one to tell you this, but your card has burt out. It will never work again, the fan stopped while the card was in operation hence it overheated and died. You will need to purchase another.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
Nov 03, 2010 | Nvidia GeForce 6600 Graphic Card
Casablanca fan stopped working suddenly, both fan & light
You must 'reset' the remote. I've had it happen quite a few times.
1. Turn off power to fan. Then back on.
2. Using remote cycle the following fan buttons from high to med to low, then from low to med to high again. That 'should' fix the problem.
Sep 29, 2009 | Casablanca Fan Versa Touch2 W-72 Remote...
Fan and light does not turn on .
FAN AND LIGHT DOES NOT WORK
my zephyr typhoon stopped working. Neither light not the fan come up. I am sure there is power going into the unit. I turned on the light one day , the light cam on and suddenly went away. From then even the fan stopped working. any information on what happened is appreciated. Thanks
Jan 22, 2009 | Zephyr Typhoon AK2100 Kitchen Hood
GeForce 6800 Fan Stopped?
Greetings!
Remove the graphic card from the board, at the top of the fan of your graphic card there is a sticker remove it slowly, then put a small amount of oil (the finner oil for machine) in it, turn the fan so that oil may goes to the bearings.
Return the sticker, and install the graphic card on the board.
Thanks
Nov 09, 2008 | XFX GeForce 6800 GT, (256 MB) Graphic Card
Nvidia GeForce 6800 PCI Express Graphic Card Logo
131 people viewed this question
Top Nvidia Computers & Internet Experts
David
David
Alun Cox
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
