My oven is not heating up but the fan and light are still working.. Any suggestions??
It is one of 4 things.
1. The heating element is out.
2. The dial temp control is bad
3. Only half of the breaker is on in the breaker box
4 If it is digital it could be your Control panel
In most cases we first check all breakers in the breaker panel if all is good. Then most likely one of your heating elements has burnt out. Try turning it to Broil to see if that one works if it does not work it is either your thermostat or control panel.
SOURCE: fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
SOURCE: fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
SOURCE: Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
SOURCE: No heat from oven but fan and light works
Timer might be blocked on auto, you need to get it back to a manual setting.
SOURCE: indesit fde20 main oven wont heat up
sounds like the circular element at the back of oven has blown.
