Question about Kodak EASYSHARE 300 Photo Printer
Cartridge light blinks.
When printer is turned on it runs through the start up and cartridge light will blink. Printer will print beautiful test page when directed via control panel. Cartridge light comes back on afterwards, then whole thing shuts down. Will not print from Kodak software, tried cleaning timing belt, still happens. Help?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 214 Answers
Try printing a testpage to see if the problem is w/ the printer, press print + cancel
Posted on Dec 28, 2009
Hi im having some problems my aunt just gave me her lexmark 1250 and the paper keeps jamming i think i have that fixed but now i go to print a test page to see if its working and all i get is a flashing...
The flashing power light could be to a faulty cartridge or the cartridge carrier has stalled. Follow the steps below to fix the problem:
  1. Open the printer cover.
  2. Ensure there is no jammed paper in the cartridge area and the cartridge carrier is free from any obstructions (any foreign objects or debris)
  3. Remove both cartridges from the printer.
  4. Close the printer cover.
  5. Unplug and replug the printer into the power source to reset it.
  6. When the printer turns on, re-insert 1 cartridge first. Close the printer cover.
  7. Check the light pattern on the power. If not blinking, open the printer cover and re-insert the other cartridge.
  8. Replace whichever cartridge is causing the power light to blink.
Hope this information has been helpful.
Jul 28, 2011 | Lexmark X1270 All-In-One InkJet Printer
I bought a replacement black ink cartridge and the cartridge light won't stop blinking or respond at all. Are these cartridges defective?
1.) Reset your printer
2.) Make sure the cartridge are properly inserted.
3.) Does the light still blinking? Try printing a test page if it can print.
Mar 18, 2011 | Office Equipment & Supplies
My X8350 stopped working this week. I have power
HI,
Please follow the instructions given below to know exactly when the light is blinking:
1. Disconnect the USB cable and the printer power cable.
2. Please disconnect the power supply from the back of the printer.
3. Then remove the cartridges from the printer.
4. Please reconnect the power supply back and turn on the printer.
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the
power from the printer. Open the front cover and move the cartridge carrier to the center.
You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the
cartridge carrier that you will not be able to see. Reach in with the first finger of
either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be
careful not to break the strip or your printer will not function. Once you believe the
strip is set correctly, plug the power back and let us know if the lights are still
blinking.
8. If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting,
if the strip breaks, you will not be able to use the printer. We will replace the printer,
only if it is under warranty.
9. However, if lights are not blinking then try inserting one cartridge at a time and check
if you can see any lights blinking. If light blinks with one cartridge then that cartridge
is defective.
Next, lets try to print the self test.
Begin by disconnecting the power supply from the wall (not the back of the printer) for at
least "30 seconds." This is essential. Then plug the printer back in and follow these
steps:
1. Press the "Copy" button.
2. Press the "Menu" button.
3. Press the down arrow button once or until the screen displays "Maintenance."
4. Press the check mark button to select the "Maintenance" menu.
5. Press the down arrow button three times until the screen displays "Print Test Page."
6. Press the check mark button to select this. The Self-Test will start printing.
The self-test should at least print out a set of either black or color bars, if not both
(if you have a printer with both color and black installed simultaneously.) Should this
test fail, try it again without cartridges installed. If the self-test still fails to take
paper in and make sounds like the carrier is moving across the paper, this is a hardware
issue, and the printer will require service. If the self-test completes without any
cartridges installed, run the self-test again with the color cartridge installed. (If you
have both black and color cartridges, after this test, run the test again with just the
black cartridge installed.) If you find that either cartridge causes the self-test to fail,
please let me know.
your's tech expert
Jeeth
Sep 25, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
K 7100/7103 cartridge light blinking
Gill:
I have the same problem as Sheillz (Sept.15, 2009)
I have installed a color ink printer and both black and color lights of cartriges are still blinking and I cannot print anything at all. Not even a test page.
Can anybody help me pls?
Sep 15, 2009 | HP OfficeJet K7100 Photo inkJet Printer
Try cleaning the print head first in the software options on the printer and then lightly with a qtip and alcohol or electronics cleaner. The ink jets sometimes dry up and cause the nozzels to get plugged.
Sep 02, 2009 | HP DeskJet 845c Printer
Blinking teardrop light blinking
Blinking drop light on HP6122 signifies an ink cartridge is out of ink. There are two cartridges -- color (larger of two) and black (smaller of two). Blinking drop light only indicates either, but not which. HP6122 service software and print driver are available from HP website http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=83027&lc=en&cc=us&dlc=en&lang=en&cc=us. HP6122 service software has a printer maintenance utility which includes ink cartridge monitor. Use the maitenance service utility to determine which (or both) cartridge is out of ink. With cartridge replacement, printer should automatically print test page, then reset and be ready for printing from your computer. To clear printed documents from print que, open the HP6122 print que via control panel > printers > double-click on HP6122 driver to show que > select document tab > select cancel.
Mar 26, 2009 | HP DeskJet 6122 InkJet Printer
LEXMARK 7350 IS NOT WORKING
HI,
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let us know if the lights are still blinking.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer. We will replace the printer, only if it is under warranty.
9. However, if lights are not blinking then try inserting one cartridge at a time and check if you can see any lights blinking. If light blinks with one cartridge then that cartridge is defective.
Begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." This is essential. Then plug the printer back in and follow these steps:
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously.) Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let me know.
your's tech expert
Jeeth
Dec 28, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
HP DESKJET 1180C
HP Deskjet 1180c and1220c Professional Series Printer and HP Deskjet 9300 and 1280 Printer - Troubleshooting a Blinking Print Cartridge Light Introduction The Print Cartridge light continues to blink with both cartridges properly installed and the Access Cover (also known as the top cover or lid) closed. Instructions The blinking Print Cartridge light may be caused by a faulty cartridge, the plastic case of the printer being dislodged or slightly out of position (which prevents the Access Cover from seating properly), the Access Cover sensor (also known as the top cover sensor or lid sensor), or by the actuator on the Access Cover. Follow the steps below to resolve the issue.
  1. With the printer turned on, open the Access Cover. The carriage will move out of the capping station and stop at one of the cartridge status icons located inside the printer under the Access Cover. The yellow arrow on top of the carriage will point to one of the cartridge status icons to indicate a good, empty, or faulty cartridge. See Figure 1 below.
    1. If the carriage stops in the cartridge’s OK position, indicated by the happy face in Figure 1, continue with Step 2.
    2. If a problem is indicated with one of the cartridges, remove the cartridge and verify that the cartridge part number is correct. The black cartridge part number is 51645A and the color cartridge part number is C6578A or C6578D.
    3. If the cartridge part number is correct, clean the electrical contacts on the cartridge with a soft, lint-free cloth. Do not touch or wipe the nozzle plate.
    4. If a faulty cartridge is still indicated after verifying the cartridge part number and cleaning the contacts on the cartridge, replace the cartridge.
    5. After replacing the cartridge, turn off and then turn on the printer to clear the cartridge error from the printer's memory. If the cartridge error cannot be cleared, the printer will require repair. If the carriage stops in the cartridge’s OK position, indicated by the happy-face in Figure 1, continue with Step 2. NOTE: The printer checks the status of both print cartridges before printing. Both the black and color cartridge must be functional and installed in the printer in order to print.
    Figure 1: Cartridge status icons c00001225.jpg Icon/Drawing Problem identified by the symbol Solution c00001226.jpg The color cartridge is missing, improperly installed, defective, or the wrong print cartridge is installed. 1. If there is no color cartridge in the cartridge cradle, insert a color cartridge.
    2. If there is a color cartridge in the cradle, remove the color cartridge and firmly reinsert it.
    3. Check to make sure the color cartridge is appropriate for the printer.
    4. If the problem persists, replace the color cartridge. c00001227.jpg The black cartridge is missing, improperly installed, the wrong print cartridge, or is defective. 1. If there is no black cartridge in the cartridge cradle, insert a black cartridge.
    2. If there is a black cartridge in the cradle, remove the black cartridge and firmly reinsert it.
    3. Check to make sure the black cartridge is appropriate for the printer.
    4. If the problem persists, replace the black cartridge. c00001228.jpg The color print cartridge is running low on ink. Replace the color print cartridge with a new color print cartridge. c00001229.jpg The black print cartridge is running low on ink. Replace the black print cartridge with a new black print cartridge. c00001230.jpg None. The print cartridges are working correctly. None. The print cartridges are working correctly.
  2. Close the Access Cover and wait for the printer to initialize. If the Print Cartridge light is still blinking, remove the Access Cover by following the steps below:
    1. Open the Access Cover and hold it open.
    2. Dislodge the Access Cover from the hinges with a sharp blow to the hinge area of the Access Cover and then remove the Access Cover.
  3. Install the Access Cover by following the steps below:
    1. Align the hinges on the Access Cover with the hinge pins on the printer.
    2. Push down firmly on the Access Cover until the hinges snap into position.
  4. Close the top cover and wait for the printer to initialize. If the Print Cartridge light is still blinking, the printer case may be dislodged or slightly out of position. To restore the printer case to the proper position, squeeze the printer by applying pressure to the front and back pressure points shown in Figure 2. Figure 2: Pressure points c00006497.jpg Firmly squeeze the pressure points on the printer case as shown in Figure 3. If the Print Cartridge light continues to blink, continue with step 5. Figure 3: Squeezing the pressure points c00006498.jpg
  5. If the Print Cartridge light is still blinking, push down firmly on the center of the Access Cover (the extra pressure may engage the sensor). If the Print Cartridge light quits blinking, remove the pressure from the Access Cover to see if the Print Cartridge light starts blinking again. Re-apply the pressure to the center of the Access Cover to see if the Print Cartridge light stops blinking again.
    1. If the Print Cartridge light quits blinking with pressure applied, the Access Cover is faulty and should be replaced.
    2. If the Print Cartridge light continues to blink even with pressure applied, the Access Cover sensor may be faulty and the printer will require repair.
Oct 18, 2007 | Office Equipment & Supplies
HP PSC 1410 will not print, printer icon is no longer on the bottom right hand corner of screen either. When i turn off the printer and turn it back on it prints the test page only.
Dear kappa, It is the problem related "Alignment of cartridge" your printer is working properly, I am suggesting a method, with the help of this method you will never get test page until you lift out your cartridge from your printer. When next time printer print a test page, take it and put it into the scanner, remember the printing area should be the side of mirror and the printer prints on the above side of the paper should be left side of the scanner. And press scan button, you will see the green light will be blink and a voice of scanner you will hear. After 30 seconds light will stop blinking, Next time when you will turn on your printer, it will not print test page.
Sep 24, 2007 | HP PSC 1410 All-In-One InkJet Printer
Kodak EASYSHARE 300 Photo Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
