Question about Gateway Computers & Internet
I just purchased a model T-6330U notebook from best buy.It is equiped with wireless internet access.I am useing a verizon fiber optics router,with wireless capabilities.I activated the wireless networking on the computer.I am still unable to get a wireless connection.can you help me?
    Scholar:
  • 152 Answers
Have you installed all the softwares (drivers) that goes with your laptop? Some laptops have specific softwares that need to be installed to make the components (hardwares) work.
Posted on Nov 11, 2008
I need to know how to make my printer print after installing TWC fiber-optic Internet. It worked great with AT&T broadband. TWC guy said I needed a basic router, without DSL, to attach to the...
First off I believe the usb port on the back of that access point is for management only, and will not connect a device...not positive though. If this gateway is not itself a wireless access point. The best thing you can do is purchase a wireless router/switch. In this configuration you would plug the gateway you received from Time Watner into the new router, Then you can plug any wired device directly into the new router, as well as broadcast your own secure wireless network. A good recommendation would be a D-LINK HD1000 Media router. It is very versatile, not to mention I just picked one up from EBAY for 19.99 with free shipping, took a little while to arrive though. But any router would work, I only suggest a wireless router because of the versatility, and I suggested the HD1000 because it is equipped with a usb port and SD card slot for sharing media(pictures, videos, music, printers...ect..) across your entire network. Hope this helps.
Apr 09, 2013 | Computers & Internet
Using External Wireless Card with an Internal wireless laptop
5fa34b4.jpg this works on it's own. like it is needed to connect to verizon wireless internet. your internal on the other hand is designed to work with a home networking equipment such a wireless router (one that is connected to the internet via DSL / Fiber / Cable / etc).
Jun 19, 2008 | Toshiba Satellite A105 Notebook
Tip
Nintendo wii Error Code 61070 fix
Error Code 61070
  • Make sure that your Internet connection is compatible with the Wii console's online service. You must have broadband Internet (Cable, DSL, or Fiber Optic) and a compatible wireless router. For more information, click here.
  • If you have verified that you are using a compatible Internet connection, then it appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
    • Change your wireless router's channel to 1 or 11
      Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab.
    • Where is your wireless router located?
      Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference.
    • Look for other devices
      Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies
on Sep 03, 2010 | Nintendo Wii Console
D-Link router switches off internet connection when tv/DVD remote is used
Hi, Your question is not so clear. For giving the proper solution I need to know something. As per my knowledge a fiber optic cable doesn't connect a router directly without a Media Converter. Secondly please tell me the model number and the brand name of your television. Third do you configure your internet connection on your television through IP address??
Jun 06, 2012 | D-Link DIR-300 Wireless Router
How to make the toshiba satellite a15-129 pc notebook wireless?
The first thing that you need tohave in order to get wireless internet is a wireless networking adapter.If you own a newer laptop, this is probably inside your computer as we speak.
If you don't own a wireless carddon't panic.
You can easily purchase oneseparately. They are relatively inexpensive. The best place to purchase a wirelesscard is eBay (opens new window).
There are two important thing thingsto look for in your wireless card.
1.Make sure it is a 802.11g card. They have 802.11b, 802.11a, and several others.Having an 802.11g will enable you to connect at much faster speeds and fromfarther away.
2.Purchase a wireless card that connects in the PCMCIA slot.
The next thing you are going to wantto get is high speed internet. It is possible to have wireless internet withdial-up, but it will be so slow it simply isn't worth it.
In order to have high speedinternet, you are going to need a cableor dsl modem depending on what internet you have. This type of modemwill not be found in your laptop.
There are many different types andbrands of modems out there. I have had no problems or complaints with the Motorola Surfboard. It's easyto set up and has lasted a long time now.
Other well known modems are Linksys and Netgear.
You can get cable/dsl modems muchcheaper on eBay. But make sure that all of the equipment comes in the box.Either order one that says new or contact the seller and ask them if all of thewires and cables are included.
The next thing on how to set upwireless internet is getting a wirelessrouter (opens new window).
This is the piece of equipment thatmakes things wireless. You can have high speed internet without a router. Butto be able to connect multiple computers and have your laptop have a wirelessconnection you are going to have to purchase a router.
Fortunately, routers are gettingcheaper and cheaper by the day now.
You can certainly find a nice wireless router on eBay forunder $30.
Similar to the wireless card, makesure you get a router that is 802.11g. This will allow you to connect fasterand from farther away.
Also, try to look for a routerthat has a connection of at least 54 Mbps. Ifseveral people will be using the internet at one time you may consider gettinga router even faster then that.
Once you have all of the necessaryequipment, it's time to hook everything up.
It's hard to explain precisely howto do this because each modem and router may need to be hooked up differently.
But the main steps on how to set upwireless internet are this...
1.Hook up wherever your internet is coming from to your modem. Your internetsource will vary depending on whether you have Cable or DSL.
2.Connect your modem to your router. This is the essential part of makingwireless possible.
3. Turn on whatever computer you havethat has a wireless card and enjoy your wireless internet experience!
Sep 25, 2009 | Toshiba Satellite A15-S129 Notebook
Wireless Router Advice
what kind do you have right now? verizon fios offers some great wireless routers that are very strong
Dec 06, 2008 | Computers & Internet
Interconnect two remote sites
500m ethernet cable is at its max.
you can use 4 pair (8lines)telephone wire to semulate ethernet cable (unshield). you will pickup noise on the line.
only one unit can be the moderm to access the Internet the other has to be a router. (Lan port only). and you cansetup both to have wireless access.
Sep 22, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
To: Verizon Central Many Problems: Please help! I have Verizon Fios for my television and Internet. (1) I am unable to access the Internet online on my laptop. That's the first problem. (2)I have...
Verizon Fios Fiber Optic Television http://www22.verison.com/residentialhelp/
Verizon Internet and Verizon Wireless Internet
Verizon | Yahoo!
Verison | AOL
Verison | Live
Verison with MSN premium
Verison Online
Vonage Phone number suggests to me a that you have been sent a ( Router )
Check to see that your particular router supports wireless
If wireless is supported on your router you may wish to contact verison over the phone for farther instructions.
Selah :-)
Sep 14, 2008 | Computers & Internet
I just got my first notebook it is a compaq evo n400c with a belkin 802.11b (32 bit cardbus)wi-fi card. i am trying to find out how i can get/have internet access where ever i go. how do i go about setting...
Hi Obadiah,
U can take ur laptop to any of the hotspots and u need to turn on the wireless switch in ur laptop so that u can automatically connect to the wireless internet..i think u r aware about hotspots...
If u want to use internet in ur home..u can buy a wireless router..there are lot of companies providing wireless routers..u can buy Linksys..model no is Wrt54g..this wrt54g is a wireless router where u can connect 4 wired desktops and 20 wireless laptops..its cheaper and best.u need to buy a internet connection to connect this router...I suggest u to go for a cable Internet..Cable internet providers are comcast,shah.go for comcast.Hope this info will be useful for u.for further clarifications revert back as soon as possible
Jul 09, 2008 | Belkin Computers & Internet
Laptop
If all you're looking for is wireless internet within your home, then you can simply buy a wireless router off the shelf from Best Buy. However, a wireless router will only provide a range of a couple hundred feet, perhaps a couple of hundred yards. Essentially, it only provides internet access at a single fixed location. I'm getting the impression you're looking for something more.
If you're looking to have internet access wherever you go, no matter how far from home, you're going to need a subscription to wireless internet from a cellular provider such as AT&T or Sprint. They sell both internet access as well as the cards used to connect to the network, so check out their websites to explore your options.
May 15, 2008 | HP Smart Buy - HP Compaq 8710w Mobile...
Computers & Internet Logo
88 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
